Modelism - RHC Forum: BEAST-X Flybarless la 140 EUR - Modelism - RHC Forum
BEAST-X Flybarless la 140 EUR Made in Germany - MEMS senzor
#31 Useril este offline   morph
  • Postari: 951
  • Inregistrat: 18-May 08
Postat 23 February 2012 - 06:37 PM
Pai e simplu. Muta bilele de pe servo o gaura mai inspre centru ca sa maresti rezolutia. Ciclic throwul va fi mai mic.
  Similar to setup point J, the color of the Status-LED indicates whether the adjusted limit allows
sufficient cyclic throw. In the ideal case, the swashplate is limited only to the extent where the StatusLED still lights blue.
In particular, for models that are intended to be used in 3D aerobatics, 10° to 12°
cyclic throw should be possible. But even for all the other helicopters, it is recommended to adjust as
much throw as possible, because otherwise the control loop may not work properly. Here, the color of
the Status-LED provides a clue. If you get only purple or even no light at all, it is essential that you
change the mechanical setting of your model to increase the available throw.
Vezi ca trebuie sa reiei setarile daca umblii la mecanica. :)
Aceasta postare a fost editata de morph: 23 February 2012 - 06:38 PM
#32 Useril este offline   radulp
  • Postari: 832
  • Inregistrat: 09-August 08
  • Interests:elicoptere
Postat 25 February 2012 - 09:27 AM
au ajuns in sfarsit si noile servo MKS -DS92A+ .inainte cu servourile Hitec am avut bila pe bratul servo montate la 13mm de centrul bratului si nu prea i-mi iesea setarile.Acum am montat bila la 10 mm de centru.Am 12 grade pe colectiv si tot 12 grade pe ciclic.Comportamentul elicopterului este total altul -cel putin in hover.Nu mai are acele razbucniri pe verticala.Este calm si tot in acest timp i-l simt ager.Vedem astazi afara in zbor....
#33 Useril este offline   radulp
  • Postari: 832
Postat 28 February 2012 - 11:45 AM
Am reusit duminica sa descarc cativa acumulatori.La inceput numa nu ma intelegeam cu el.Era prea lent pe ciclic.Cu ajutorul lui Morph (i-i multumesc mult ptr. ajutor) am reusit in final sa-i dau de capat.In al doilea meniu-Parametri- la punctul< B. Control Behavior> am trecut pe Transmiter mode - si din statie i-am dat 20%exponential pe aileron si elevator.Aici ma simt impacat cu el.Oricum si cu investitia servourilor a fost un lucru pozitiv.
#34 Useril este offline   takeoff
  • Postari: 1029
  • Inregistrat: 25-July 08
Postat 29 February 2012 - 06:48 PM
Vezi postarearadulp, la 28 February 2012 - 11:45 AM, a spus:
Sa inteleg ca pe pozitia Sport are prea mult expo?Problema e ca nu am folosit expo(cu exceptia ruderrului)la nici un heli si acum sunt indecis,sa folosesc sau nu expo
sa merg pe default lor sau sa folosesc statia.Heli este totusi mai mare,clasa 500.
Aceasta postare a fost editata de takeoff: 29 February 2012 - 06:49 PM
#35 Useril este offline   Ice9
  • Postari: 1361
  • Inregistrat: 06-April 10
  • Interests:RC Helicopters
Postat 29 February 2012 - 07:39 PM
Eu merg pe "Pro", si nici eu folosesc la nici un alt heli expo (pe nici un canal). Pe "sport" mi se pare extrem de lenes.
#36 Useril este offline   radulp
  • Postari: 832
Postat 29 February 2012 - 09:43 PM
Vezi postareatakeoff, la 29 February 2012 - 06:48 PM, a spus:
ceva de genul acesta.sunt niste presetari din fabrica .pe pozitia default<sport> este foarte lenes pe ciclic.ceva mai bine pe <extreme> dar nu indeajuns.am trecut pe <transmiter mode> si aici i-am dat expo pe aileron si elevator.in configuratia asta este mai aproape de <adevar>.da, la mine este montat pe 450V2
#37 Useril este offline   takeoff
  • Postari: 1029
Postat 29 February 2012 - 10:02 PM
Oricum,spuneai ca ai bagat 20% expo,care mi se pare mare,insmnand ca ei au folosit valori foarte mari.Am sa merg si eu pe Transmiter si o sa
vad cu ce procent va merge bine.Multumesc pentru raspunsuri.
#38 Useril este offline   radulp
  • Postari: 832
Postat 04 March 2012 - 09:06 AM
a aparut pe youtube o descriere despre parametrii de la beastX
http://www.youtube.c...&v=mW22FDo0_3c#!
#39 Useril este offline   radulp
  • Postari: 832
Postat 26 December 2013 - 09:09 PM
La interfata ptr. Beast-x - am gasit doua modele la vanzare.
http://www.ebay.com/...=item53fffd51b2
http://www.ebay.com/...=item19e3bfe034
Care dintre ele merge si la Beast-x si la Ar7200BX ?? Sau nu este nici o diferenta intre ele??Doresc sa achizitionez o interfata din UK dar nu gasesc numai cu codul BXA76007
Sugestii???-multumesc
#40 Useril este offline   stiganas
  • Postari: 8308
Postat 26 December 2013 - 09:54 PM
Din cate stiu toate interfetele sunt identice, nu conteaza pe care o cumperi.
Vezi postarearadulp, la 26 December 2013 - 09:09 PM, a spus:
#41 Useril este offline   Ice9
  • Postari: 1361
Postat 26 December 2013 - 11:20 PM
Eu am facut update la AR7200 BX cu interfata BeastX, deci banuiesc ca nu este nici o diferenta.
#42 Useril este offline   Ice9
  • Postari: 1361
Postat 09 March 2014 - 12:44 PM
A aparut varianta "plus" si "plus HD". Sunt tare curios sa vad ce poate.
http://www.beastx.co...obeast_plus.php
  • Imagine atasata: BeastX plus.jpg
