Modelism - RHC Forum: Outrage 550 - Modelism - RHC Forum
Outrage 550 tare la clasa 550.........
#1 Useril este offline   takeoff
  • Postari: 1029
  • Inregistrat: 25-July 08
Postat 24 January 2010 - 06:51 PM
Daca tot este frig,vreme de surubarit,am comandat un chit de Outrage550.
De ce l-am ales?Nu este foarte scump(undeva intre Trex 500 si 600) se gaseste in apropiere,UK,piese de schimb la discretie si nu foarte scumpe.Nu are upgradeuri,din start este full ball bearings,full alloy,aluminium,carbon,toate cnc.Electronica are locuri bine stabilite si generoase.Rotorul este programabil mecanic,adica fiecare parghie are 2/3 pozitii de montaj de la mild la wild.Este cu 5cm mai mic decat Trex600 dar cu aprox. 4/500g mai usor.
• Length: 1077mm
• Height: 344mm
• Main Rotor Diameter: 1250mm
• Tail Rotor Diameter: 228.8mm
• Blade Length: 550-575mm
• Tail Blade Length: 82-95mm
• Main Gear 140T 0.7 Mod gear
• Auto Rotation 42t
• Tail rotor ratio: 4.66:1
• Approximate flying weight: 6.5lbs (2,7kg)depending on equipment used.
• Beautifully crafted CNC anodized part
• 120 Degree CCPM Servo layout for precision control
• 140 Degree CCPM Servo layout (Optional)
• Light weight compact frame designs for extreme 3D fight
• Rigid motor mount and middle bearing design for Extreme Power Systems
• New 3rd bearing designs for motor shaft support
• Large battery tray opening for various battery shapes and sizes
• 15 Degrees +/- achievable pitch ranges
• Fully programmable head designs that can be set From Mild to Wild
• Thrust bearings on Main and Tail Blade Grips
• One piece 3D dampers
• Ball raced double pivot tail control system
• High quality tail rotor drive belt
• Fiberglass painted canopy.
Asa a sosit:
Imagine atasata: P1000489.JPG
Ambalarea foarte buna 3 cutii pline de pungulite numerotate,bagate in alte pungi mai mari.Gradul de ansamblare al chitului este 0,deci mult de munca
Imagine atasata: P1000490.JPG
  • Postari: 1029
Postat 24 January 2010 - 08:00 PM
Motorizarea:Scorpion HK4020-1390KV,esc tot Scorpion 90A/6s
alte poze
Imagine atasata: P1000492.JPG
Imagine atasata: P1000493.JPG
axul principal sustinut de 3 rulmenti
Imagine atasata: P1000498.JPG
#3 Useril este offline   Primus
  • Postari: 3026
  • Inregistrat: 14-June 07
Postat 24 January 2010 - 08:03 PM
Super, ma bucur ca apar si alte branduri de heli pe la noi. Modelul se bucura de multa popularitate peste mari si tari.
Abia astept sa il vedem in zbor. Spor la montat... :rolleyes:
#4 Useril este offline   takeoff
  • Postari: 1029
Postat 24 January 2010 - 08:11 PM
Imagine atasata: P1000497.JPG
Imagine atasata: P1000499.JPG
#5 Useril este offline   takeoff
  • Postari: 1029
Postat 25 January 2010 - 08:33 PM
Am surubarit putin,ansamblu de coada tapetat cu 20 de rulmenti
Imagine atasata: P1000509.JPG
chiar e cnc
Imagine atasata: P1000504.JPG
#6 Useril este offline   Primus
  • Postari: 3026
Postat 25 January 2010 - 08:36 PM
CNC-ul arata foarte bine, da-i bataie :) In noaptea asta n-ai somn... un pic de grija la rulmenti sa nu ajunga tread-lock pe ei...
Aceasta postare a fost editata de Primus: 25 January 2010 - 08:37 PM
#7 Useril este offline   takeoff
  • Postari: 1029
Postat 25 January 2010 - 08:41 PM
Vezi postareaPrimus, la Jan 25 2010, 08:36 PM, a spus:
Ce ma "seaca" sunt acumulatorii,nu am 6s si pe unde ma uit,aia ieftini nu cred ca fac fata,iar aia mai de firma au niste preturiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
#8 Useril este offline   takeoff
  • Postari: 1029
Postat 01 February 2010 - 05:22 PM
niste poze:
Imagine atasata: P1000516.JPG
Imagine atasata: P1000521.JPG
#9 Useril este offline   takeoff
  • Postari: 1029
Postat 01 February 2010 - 05:33 PM
Imagine atasata: P1000520.JPG
axul motorului trece printr-un rulment fixat pe motor/mount.
Imagine atasata: P1000522.JPG
#10 Useril este offline   takeoff
  • Postari: 1029
Postat 01 February 2010 - 05:43 PM
Pentru coada ce servo ar merge?Ceva ieftin si bun,ca 3D............ioc
#11 Useril este offline   radulp
  • Postari: 832
  • Inregistrat: 09-August 08
  • Interests:elicoptere
Postat 01 February 2010 - 07:24 PM
Vezi postareatakeoff, la Feb 1 2010, 05:43 PM, a spus:
depinde de giro pe care-l vei lua...la ce te gandesti?gy401,gy520,gy611,spartan quark,spartan 760,logictech 6100t,gp780,g770 ...sa. Dintre ele merg cu servouri mai "speciale"-
Ce am afisat aici,toate ar face fata la heliul tau.Bafta la alegere.
#12 Useril este offline   Primus
  • Postari: 3026
Postat 01 February 2010 - 08:06 PM
Orice giroscop ai pune, e pacat de kitul asta sa pui ceva mai slab decat Futaba 9254 / BLS251, sau Align DS620 / DS650.
Frame-ul arata deosebit.
Aceasta postare a fost editata de Primus: 01 February 2010 - 08:08 PM
  • Postari: 8333
Postat 01 February 2010 - 08:27 PM
Daca as avea bani as cumpara un Futaba BLS251:
http://www.hobbycity.com/hobbycity/store/u...idProduct=10695
cred ca la un pilot de placere, cum suntem noi toti, tine vesnic
Daca as fi pe buget mai subtire am vazut combo GP750/650 la 160 USD cu totul.
Cine stie un servo de coada ieftin si bun, standard, sa-mi zica si mie.
Stefan
#14 Useril este offline   takeoff
  • Postari: 1029
Postat 01 February 2010 - 09:33 PM
Inrebare:un servo mini de 1,5kg,mg,0,06sec,ar fi de ajuns?
#15 Useril este offline   stiganas
  • Postari: 8333
Postat 01 February 2010 - 10:21 PM
Am vazut ca de obicei lumea merge in sus. La 450 pun servo mini si la 500 pun servo standard. Am gasit servo ieftin de coada. De fapt il am deja si are pareri la superlativ peste tot:
HYPERION ATLAS DS 20 GMD
specificatii precum Futaba 9254 la 35 USD. Eu inca nu pot sa zic nimic ca il am pe Raptor E550 si practic nu l-am zburat, uitasem de el. Stefan
#16 Useril este offline   takeoff
  • Postari: 1029
Postat 02 February 2010 - 07:18 PM
Vezi postareastiganas, la Feb 1 2010, 10:21 PM, a spus:
Nu cumva mai ai unu "uitat".Mai tii minte de unde l-ai cumparat?
#17 Useril este offline   firedragon
  • Postari: 502
  • Inregistrat: 04-January 09
  Postat 02 February 2010 - 07:29 PM
Vezi postareatakeoff, la Feb 2 2010, 06:18 PM, a spus:
specificatii hyperion de la main hobby la 38.99dolari
Specifications:
Speed: 0.07 sec/deg @ 4.8V; 0.05 sec/deg @ 6V
Dynamic Torque: 22 oz/in @ 4.8V, 28 oz/in @ 6V
Holding Torque: 44 oz/in @ 4.8V, 55 oz/in @ 6V
Gears: Metal
Weight: 49g
Dimensions: 40 x 19.5 x 37.8mm (1.57 x 0.77" x 1.48")
Videoclipurile mele Spektrum DX8
planor multiplex cularis
)Imagine postata
  • Postari: 8333
Postat 02 February 2010 - 07:48 PM
<_< As vrea eu.
Dar au la aircraft world in Japonia (care de fapt este acelasi lucru cu Hyperion, nippon Dave este patronul la amadoua). Partea cea mai buna, transportul costa 2.5 USD pana in 500g (adica 5 servo).
Alta chestie buna, vin destul de repede, mai repede decat HK. Au si servo de platou bune cam la acelasi pret.
La amainhobby e mai scump transportul.
Stefan
Vezi postareatakeoff, la Feb 2 2010, 07:18 PM, a spus:
#19 Useril este offline   takeoff
  • Postari: 1029
Postat 05 February 2010 - 09:13 PM
A sosit motorul,e urias,comparatie cu unul de 450
Imagine atasata: P1000529.JPG
Am impresia ca ESC preconizat(Scorpion 90A/6s) e cam slab pt. motorul asta.Ceva bun si ieftin pe unde gasesc?
Imagine atasata: P1000532.JPG
  • Postari: 8333
Postat 05 February 2010 - 11:05 PM
Motor sanatos. Cred ca cel mai ieftin ESC bun e cel de Align de la Trex 600 ESP. Se gaseste si la anunturi (nu in RO), destul de multi trec la 8s sau 12s si vand ESC-ul din kit. Si de nou daca il cumperi cred ca are un pret acceptabil.
Altfel ca specificatii un Phoeni_x ICE la 100A e fenomenal
Daca vrei la blana poti sa incerci:
Hobbyking SS Series 90-100A ESC - 25 USD
Eu am fost uimit de ESC-ul:
Hobbyking SS Heli Series 70-80A ESC w/UBEC - 20 USD
are soft start mai bun ca cele scumpe si BEC serios.
Frumos heli, sper sa nu ai nevoie de piese curand. Stefan
[quote name='takeoff' post='367565' date='Feb 5 2010, 09:13 PM']A sosit motorul,e urias,comparatie cu unul de 450
Aceasta postare a fost editata de stiganas: 05 February 2010 - 11:06 PM
#21 Useril este offline   morph
  • Postari: 951
  • Inregistrat: 18-May 08
Postat 06 February 2010 - 07:32 PM
Vezi postareastiganas, la Feb 5 2010, 11:05 PM, a spus:
Si e si mai ieftin ca unul align care nu prea e stralucit (cel de 100A).
#22 Useril este offline   Iceman575
  • Postari: 182
  • Inregistrat: 31-August 06
Postat 08 February 2010 - 11:18 AM
Esc Align nu as cumpara.
Te uiti pe forumu cu oameni obsedati de heli din US si vezi foarte multe posturi cu ESC-uri Align care au luat foc sau pur si simplu nu functioneaza.
Si cel mai frumos... nu ai garantie :rolleyes:
CC Ice 100A (cel normal nu varianta Lite) e cel mai bun pentru heli 6S si costa "numai" 120$. Un kontronik Jive care este si mai bun este putintel mai scump...
Daca cumperi Esc Align sau HK ar fi bine sa stii cum se face o autorotatie inainte sa te apuci sa zbori prea agresiv cu heli... Nu o zic in batjocora sau de rautate e doar un sfat...
PS. In general e bine sa stii sa autorotezi ca si astea scumpe mai crapa doar ca mai rar...
PPS. Pana acuma arata fain heli si imi place cum au facut motoru mountu sa se miste cu totu. Sa ne zici cum zboara cat de curand :)
Aceasta postare a fost editata de Iceman575: 08 February 2010 - 11:18 AM
#23 Useril este offline   takeoff
  • Postari: 1029
Postat 08 February 2010 - 11:41 AM
Castle Creation o sa fie,ca prea o spuneti cu foc.
#24 Useril este offline   Primus
  • Postari: 3026
Postat 08 February 2010 - 12:59 PM
Si la mine e pe lista de cumparaturi un ICE pentru 500. :rolleyes:
#25 Useril este offline   nen77
  • --tadadam--
  • Postari: 1566
  • Inregistrat: 08-March 06
Postat 08 February 2010 - 01:09 PM
Vezi postareatakeoff, la Feb 8 2010, 11:41 AM, a spus:
alutarea de foc si esc in aceasi propozitie nu imi place persoal ,daca era vorba de align era chiar urat.
Cred ca CC e o alegere buna.
p.s. desi pe huricane 550 un heli de aceasi clasa am folosit la destule zboruri un align de 75 amperi si ca motor un z-power
West Hobby Team
#26 Useril este offline   takeoff
  • Postari: 1029
Postat 17 February 2010 - 04:57 PM
Vezi postareastiganas, la Feb 2 2010, 07:48 PM, a spus:
:lol: As vrea eu.
Stefan
Am ascultat de sfatul tau si am luat Hiperion-DS20-GDM.Prima impresie,plastic banal,eticheta vai mama ei,dar...extraordinar de precis si rapid.Multumesc pt. indicatie,merita toti banii.
Imagine atasata: P1000537.JPG
#27 Useril este offline   stiganas
  • Postari: 8333
Postat 18 February 2010 - 08:18 PM
Cool; Cateva intrebari:
- de unde l-ai luat si in cat timp a venit (poate imi mai cumpar si eu)
- ai o scula pe care eu nu o am si sunt plin de invidie (Jeti servo tester) - 2 rugaminti:
1. Daca tot faci munca patriotica si testezi servo care iti trec prin mana posteaza aici, sa stim si noi. Ce scrie pe cutie nu e intotdeauna adevarat. Eventual fa un post separat in care adaugi pe masura ce testezi, daca au si altii tester pot posta si ei.
2. Am si eu o durere HXT900 - sunt doritor sa donez unul nou sa il pui pe tester la munca sa vedem cate cicluri tine (asta daca testerul tine la tavaleala). Am vazut un test de acest gen cu un servo Align, 610 parca. A tinut vreo 900 de cicluri si a murit. Pe avioane nu mi-a murit nici unul dar pe heli au murit 2 cu consecinte proaste.
Stefan
Vezi postareatakeoff, la Feb 17 2010, 04:57 PM, a spus:
#28 Useril este offline   takeoff
  • Postari: 1029
Postat 19 February 2010 - 05:03 PM
stiganas
Comanda facuta la Air Craft,cu EMS,15usd,4zile de la ei la Bucuresti,8zile de la Buc. la Calarasi.
Jeti box-ul l-am luat pt a programa niste night blade,nu stiam ca are mai multe facilitati.Ai dreptate,ce scrie pe cutia de servo,de foarte putine ori corespunde cu realitatea.Probabil se fac teste la punerea in productie si rezultatele raman pe tot parcursul fabricarii,plus ca se vand licentele si asa..............Pe tester am 400 de cicluri,as putea face un test cu htx900,dar nu cred ca va fi concludent,depinde,de fabricant,de lot,de fiecare bucata.
numai bine
#29 Useril este offline   takeoff
  • Postari: 1029
Postat 08 March 2010 - 06:22 PM
Pe ultima suta.......
Imagine atasata: P1000549.JPG Imagine atasata: P1000550.JPG
#30 Useril este offline   takeoff
  • Postari: 1029
Postat 08 March 2010 - 06:32 PM
inca....
Imagine atasata: P1000554.JPG Imagine atasata: P1000553.JPG
3 useri citesc topicul
