Modelism - RHC Forum: Skookum SK720 - Modelism - RHC Forum
Skookum SK720 6-Axis Self Leveling Flybarless Gyro
#1 Useril este offline   morph
  • Postari: 951
  • Inregistrat: 18-May 08
Postat 02 April 2010 - 08:03 PM
-8.5 volt capable
-Optional 25 amp external power bus (included) for larger than 50-size and nitro helis (15 grams). Make brownouts a thing of the past!
-3-axis accelerometer + 3 gyros, allowing self-leveling
-High-power 32 bit processor (for future upgradeability)
-Expansion port for GPS or a third sat-receiver
-Built in micro-SD card (2 GB flight-data logging)
-Built in USB mass storage device – Connect the unit to your computer without having to install drivers
-Flight data logs can be played back on your PC with analysis of tuning and heli health
-Compatible with the Skookum SK-LCD terminaltesc
-Existing SK360 setup files can be easily up-converted for the new unit
Wow! Daca o sa mearga si foarte bine, toata lumea o sa zboare elicopterele in 6-7 canale la fel de usor ca un coaxial :blush:
Puteti citi primele impresii aici.
#2 Useril este offline   firedragon
  • Postari: 502
  • Inregistrat: 04-January 09
Postat 03 April 2010 - 08:59 AM
Vezi postareamorph, la Apr 2 2010, 07:03 PM, a spus:
Wow! Daca o sa mearga si foarte bine, toata lumea o sa zboare elicopterele in 6-7 canale la fel de usor ca un coaxial :rolleyes:
cred ca voiai sa spui ca toata lumea o sa zboare coaxiale cu aspect de heli de 6 canale. pilotatul stabilizat nu e pilotat si nu te invata nimic. poate directiile stickurilor ceea ce face un coaxial.daca vrei sa zbori si tai stabilizarea o sa ai o alta chestie la mana. singurul avantaj la skookum e ca ai flybarless, receptor, stabilizator si logview in acelasi produs si nu platesti mai multe. flybarless e la moda, fac economie la receptor ca iau numai sateliti, stabilizator pot sa il las pe un coleg sa se joace cu el si sa creada ca zboara un heli dar si salvare la dezorientare, si logview sa vad parametrii de zbor.
am gresit ceva in impresia mea?? oricum skookum imi pare cel mai complet flybarless stabilizator de pe piata. daca mai puneau si un canal de transmisie video chiar ca ne multumeau de tot
Aceasta postare a fost editata de firedragon: 03 April 2010 - 09:00 AM
Videoclipurile mele Spektrum DX8
planor multiplex cularis
)Imagine postata
#3 Useril este offline   morph
  • Postari: 951
Postat 03 April 2010 - 02:50 PM
Vroiam sa zic exact ce am zis :lol:
De altfel citez din cei care au pus mana pe asa ceva:
"For beginners or those learning 3D, the SK-720’s built-in 3-axis accelerometer means you can set it to self-level, like a coaxial heli"
#4 Useril este offline   patrocle
  • Postari: 319
  • Inregistrat: 07-September 08
Postat 04 April 2010 - 10:23 PM
daca nu e o schema de marketing, se vine bine pe nv....
Skookum SK-720 Flybarless System
UPDATE SK-720:
FIRST BATCH HAS SOLD OUT. (ETA First Batch: 4/12/2010)
SECOND BATCH HAS SOLD OUT. (ETA: 4/26/2010)
ALL NEW PRE-ORDER NOW WILL BE PUT ON THE THIRD BATCH (ETA: 5/15/2010)
http://www.helidirect.com/skookum-sk720-fl...tem-p-18576.hdx
si eu zic ca are sanse mari sa fie bun. fiindca Skookum face asta de ceva vreme (fara coada) destul de bine. Daca au nimerit si coada o sa fie un concurent serios pentru v-bar
Mircea
Blade 400 3D, Gaui 200V2, Spektrum DX6i 2,4 GHz
Trez 450 Pro FBL, Mikado 400 FBL
  • Postari: 8306
Postat 18 April 2010 - 09:14 PM
Am inceput sa citesc cate ceva din primele impresii despre unitatea asta si e prima oara cand ma entuziasmez pe alectronica flybarless.
Trebuie sa incep sa pun bani deoparte ca nu e ieftina.
Un mic filmulet:
http://www.youtube.c...h?v=PJKCmLlNlVk
O chestie in plus care imi place teribil este log-ul de vibratii. Am o obsesie cu vibratiile si de multe ori nu se vad decat daca sunt dramatice. Aici vezi in log ce vibrati ai. Peste asta ai monitorizare de tensiune.
Cei care deja il au se jura ca e cea mai buna unitate ce au avut vreodata. Se vedem cine il are primul in Romania. Eu as paria pe Serban de la aeropower.
#6 Useril este offline   patrocle
  • Postari: 319
Postat 19 April 2010 - 02:04 PM
eu nu prea am gasit impresii decat de la cei care au fost/sunt beta testeri Skookum, n-as baga mana in foc ca sunt obiectivi...
sau tu ai alta sursa?
sigur o sa incerc si eu FBL, dar mai stau, ca nu e graba. din curiozitate, ca nu o sa zbor eu mai bine cu FBL decat fara... nu acolo e problema ;)
Din pacate, nu mai cred ca or sa fie scaderi de pret la cele considerate de top (V-bar, sk720, totalg, etc) prea curand.
Mircea
#7 Useril este offline   patrocle
  • Postari: 319
Postat 09 July 2010 - 09:18 AM
a inceput sa se gasesca in stoc, pana acum era cu asteptat 20-30 zile. Pret $415-$425
Mikado avem... pe asta cine il incerca?
Mircea
