Modelism - RHC Forum: Mono 2 DF, prima mea barca... - Modelism - RHC Forum
  • 5 Pagini +
Mono 2 DF, prima mea barca... ... de la Johnny Cheung
#61 Useril este offline   CornelP
  • Postari: 538
  • Inregistrat: 13-June 09
Postat 09 September 2009 - 06:23 PM
Daca vrei sa vezi si un mono mai adevarat, vezi: http://www.rsconcept.../el-fuego-v2-1/
Am scris deja la baieti sa intreb preturi... asteptam
#62 Useril este offline   iony
  • Postari: 2346
  • Inregistrat: 06-April 07
Postat 09 September 2009 - 06:24 PM
Click here for a dimension chart B40 S Series B40 8S w/4.4:1 B40 10S w/4.4:1 B40 12S w/4.4:1
Kv (rpm/V) 5325 4260 3550
Max Power (W) 660W 575W 550W
Max Amp (15sec) 60A 50A 40A
Max Efficiency 87% 87% 87%
Io (No load A) 3.16A 2.07A 1.47A
Rm (Resistance) 0.090Ohm 0.015Ohm 0.213Ohm
Shaft Diameter 4mm 4mm 4mm
Gearbox 4.4:1 4.4:1 4.4:1
Motor Diameter 27.6mm 27.6mm 27.6mm
Motor Length 69.15mm 69.15mm 69.15mm
Motor Weight 172g 172g 172g
Built in Fan N/A N/A N/A
Max Rpm 60,000 60,000 60,000
Poles 2 2 2
Case Smooth Smooth Smooth
ESC Timing 0-5 deg 0-5 deg 0-5 deg
ESC Switching Freq. 8KHz 8KHz 8KHz
un haker dasta de care zici tu este 280dolari
#63 Useril este offline   fulgerica
  • Postari: 2235
  • Inregistrat: 31-July 07
  • Interests:vintage
Postat 09 September 2009 - 06:41 PM
e mai putin. cel de care zici are si reductor. asta era o varianta mai ieftina.
Laser frate!
#64 Useril este offline   fulgerica
  • Postari: 2235
  • Interests:vintage
Postat 09 September 2009 - 06:43 PM
 CornelP, la Sep 9 2009, 07:23 PM, a spus:
pai e fibra. cat sa coste?
Laser frate!
#65 Useril este offline   RC1
  • Postari: 453
  • Inregistrat: 25-July 08
Postat 09 September 2009 - 10:30 PM
 fulgerica, la Sep 9 2009, 07:43 PM, a spus:
eu zic 200
iar hackerasul e nasol ca e in 2 poli trebuie cautat un pic mai sus...
Si ca sa revenim la subiect citeva poze cu al meu..
Imagine atasata: monodf1.jpgImagine atasata: monodf2.jpg
#66 Useril este offline   Wubu
  • Postari: 188
  • Inregistrat: 07-November 07
Postat 09 September 2009 - 10:59 PM
 RC1, la Sep 9 2009, 10:30 PM, a spus:
eu zic 200
Salut, crezi ca hackerasul ar mai fi costat atat daca era prost?
Lehnerul are tot 2 poli si este mult mai tare decat cele cu mai multi poli.
Polii nu sunt criteriul principal.
Bye!
#67 Useril este offline   RC1
  • Postari: 453
Postat 10 September 2009 - 12:21 AM
 Wubu, la Sep 9 2009, 11:59 PM, a spus:
Mda vad ca lumea chiar e seriosa pe aici..
Ceva mai multe detalii...
Suntem intr-un topic inceput cu barci chinezesti si in care am inceput sa vorbim de barci care castiga campionatul mondial si de motoare destul de scumpe...
Ma simteam dator sa spun ca strugurii sunt acri ;)
Si culmea cred ca ar fi sa incepem sa dezbatem care motor e mai bun plett,lehner sau hacker ;)
#68 Useril este offline   Primus
  • Postari: 3026
  • Inregistrat: 14-June 07
Postat 10 September 2009 - 04:22 AM
RC1, hai ca vine weekend-ul si n-ai terminat-o ;)
Aceasta postare a fost editata de Primus: 10 September 2009 - 08:42 AM
#69 Useril este offline   iony
  • Postari: 2346
Postat 10 September 2009 - 07:34 AM
 RC1, la Sep 9 2009, 11:30 PM, a spus:
eu zic 200
lol raoul de la un catamaran pe care nu vroiai sa il ti ai ajuns la o adevarata flota :D ai grija ca il depasesti pe zue
asta ultima este df30 sau 25 ?
a iesit bine si cu amo ala va merge super tare
cred ca este cel de 2300kv
#70 Useril este offline   Primus
  • Postari: 3026
Postat 10 September 2009 - 08:54 AM
Am comandat ieri niste magneti neodim, de AICI, pentru a incerca si varianta asta de prindere a capacului.
Voi pune 6 perechi, cate doua pe lateral, una in fata si alta in spate.
Trebuie sa mai iau o garnitura alba pentru etansare... ceva idei, un profil care etanseaza mai bine?
#71 Useril este offline   RC1
  • Postari: 453
Postat 10 September 2009 - 09:04 AM
 iony, la Sep 10 2009, 08:34 AM, a spus:
Mda am zis ca o barca ajunge apoi doua acum sunt la patru si ma straduiesc cu ceva eforturi sa ramin aici. Deci pina la flota lui zue mai e ceva:)
Barcuta e DF-ul de 25 am mers pe varianta coca si hardware separat desi ar fi doar a doua barca pe care o ansamblez..
Ca setup am mers pe stinger, cele mai mici trim tab-uri pe care le-am gasit la johnny si un singur turnfin ca sa am loc de o eventuala camera de inundare.
Motor Ammo 3656 -2600Kv parca de 55 amp care sper sa fie potrivit pe o configuratie 4s. Am un regualtor de 120 prin casa care ar trebui sa fie mai mult decit suficient pt motor.
Lipo 5000 mah 30/50 care sper sa tina mai mult de 5 min pe motorul asta
La elice o sa incep cu un x637 si sper sa urc spre un x640 in functie de ce zice motorul..
Si sper sa fie gata pina duminica :D
#72 Useril este offline   Primus
  • Postari: 3026
Postat 10 September 2009 - 10:13 AM
:D
... Fac cinste!!!! :D
#73 Useril este offline   CornelP
  • Postari: 538
Postat 10 September 2009 - 11:13 AM
Hai ca vezi duminica cum am facut-o eu pe a mea... iti ia maxim 2 ore... :D
#74 Useril este offline   iony
  • Postari: 2346
Postat 10 September 2009 - 12:13 PM
 RC1, la Sep 10 2009, 10:04 AM, a spus:
Si sper sa fie gata pina duminica :)
super tare oricum octura face diferenta :lol:
#75 Useril este offline   RC1
  • Postari: 453
Postat 10 September 2009 - 01:23 PM
 Primus, la Sep 10 2009, 09:54 AM, a spus:
Pai in primul rind trebuie sa pui un miner pe capac. Altfel nu-l mai scoti de acolo :lol:
@iony chiar stateam si ma gindeam de unde naiba mi-a venit mie ideea sa cumpar un 637...
Aceasta postare a fost editata de RC1: 10 September 2009 - 01:26 PM
#76 Useril este offline   Primus
  • Postari: 3026
Postat 10 September 2009 - 07:15 PM
Pai in primul rind trebuie sa pui un miner pe capac. Altfel nu-l mai scoti de acolo smile.gif
Pai are un stift de metal, de care pot trage, crezi ca e insuficient?
#77 Useril este offline   Primus
  • Postari: 3026
Postat 15 September 2009 - 05:57 PM
Revin la ideea cu magnetii, au sosit ieri, dar sunt muuult prea mici pentru capac.
Ideal ar fi sa gasesc unii cam de 10x4x2mm.
Am mai coborat inca trimtab-urile si acum sta pe apa super bine.
Duminica seara m-am dat cu ea in Tei, pe o apa ca oglinda, pana la lasarea intunericului.
Aceasta postare a fost editata de Primus: 15 September 2009 - 05:59 PM
#78 Useril este offline   OldMann
  • Postari: 1762
Postat 15 September 2009 - 06:05 PM
 Primus, la Sep 15 2009, 06:57 PM, a spus:
pune-i mai desi...
#79 Useril este offline   Primus
  • Postari: 3026
Postat 16 September 2009 - 08:38 AM
As avea 7 perechi, insa si din cauza dimensiunii (diam 4x2) sunt destul de greu de fixat in pozitia in care trebuie.
Ma uit sa vad unde gasesc unii mai mari.
#80 Useril este offline   petcanu
  • Postari: 123
  • Inregistrat: 10-January 09
Postat 20 September 2009 - 02:31 PM
 Primus, la Aug 26 2009, 03:48 PM, a spus:
Deep Vee-ul meu de 25 de inch de la Johnny Cheung, se afla pe drum. Pana la urma am optat pentru culoarea alba.
Intrebare, ca nu mie clar, cum prindem capacul, astfel incat sa nu intre apa in barca?
dc ai optat pt deep vee, cel mai bun la viteza si stabilitatee e catamaranul si johnny are si catamarane bune.
#81 Useril este offline   Primus
  • Postari: 3026
Postat 20 September 2009 - 04:03 PM
Pentru ca nu imi place cum l-a vopsit :angry2:
#82 Useril este offline   Primus
  • Postari: 3026
Postat 20 September 2009 - 04:13 PM
Ok, astazi a fost prima zi in care am pus pack-uri 3S 4000mAh, 20C, si dupa cam 4-5 minute, barca se oprea brusc.
Cred ca regulatorul intra in failsafe din cauza ca era incins rau, la fel si motorul. La fel cablurile dintre ESC si motor erau incinse.
Dupa ce se raceau pe mal, totul mergea OK.
Packul e abia caldut.
Mentionez ca si la packurile de 2200 se incalzeau, nu asa tare, dar niciodata nu mi-a taiat regulatorul.
Ce-i de facut? Cineva mi-a recomandat sa incerc cu o elice mai mica.
Acum am una din bronz, de 35, pe ax de 4mm. Ce sa pun in loc?
Orice idee e binevenita.
Multumesc,
Aceasta postare a fost editata de Primus: 20 September 2009 - 04:21 PM
#83 Useril este offline   iony
  • Postari: 2346
Postat 20 September 2009 - 07:20 PM
ce motor ai pe barca ?
si cum statea barca in apa
si am inteles ca elicea afost de 35 metal ?
si ce regulator ?
Aceasta postare a fost editata de iony: 20 September 2009 - 07:21 PM
#84 Useril este offline   sonic xz
  • Postari: 797
  • Inregistrat: 26-October 07
Postat 20 September 2009 - 07:50 PM
In primul rand motoarele gen seria 380 sunt nepotrivite pentru aceste barci. Problema revine in calitatea manufacturarii produselor. Un no-name nu se va putea compara cu un Feigao 380 chiar daca pe hartie au aceleasi specificatii. De obicei cele no-mane consuma mai mult curent dacat trebuie iar randamentul este slab. Aceiasi poveste este si cu esc-urile. Aici e problema de noroc. Un esc poate sa mearga fie cativa ani fara sa ai probleme legate de supraincalzire, fie cateva zile pana sa iasa fum din el.
Lasand problema calitatii putem vorbi despre o elice prea mare si setari gresite din strut si flaps-uri. Cg-ul trebuie sa se afle intre 27-30% din lungimea barci masurata din pupa. Apuparea sau aprovarea excesiva duce la cresterea drag-ului si curentului in sarcina. Modificarea unghiului strutului si adancimii elicii modica atitudinea barcii.
Incearca sa schimbi motorul cu un 540 S sau L.
#85 Useril este offline   Primus
  • Postari: 3026
Postat 20 September 2009 - 10:18 PM
Va salut,
Motorul si ESC-ul sunt cele care vin cu coca, in versiunea ARTR de AICI
ESC de 70A, motor inrunner de 2881KV, ambele no name.
Cu trimtab-urile setate pe zero, la viteza maxima barca se desprinde cam jumatate, poate 60%, de apa.
Strut-ul este foarte putin coborat (cred ca un milimetru sau doi fata de setarea initiala).
Elicea e de bronz, de 35mm diametru.
Cu pack-ul de 2200 rulam cam 3 minute, probabil ESC-ul nu ajungea sa se incinga asa de tare.
Acum la 4 minute si un pic, a "papat" cam 3100 din packurile de 4000 inainte de a taia ESC-ul.
#86 Useril este offline   fulgerica
  • Postari: 2235
  • Interests:vintage
Postat 20 September 2009 - 11:00 PM
pai daca o sa cobori cu elicea sub 35, nu mai e barca de viteza. la mono 2, cam cat ar fi barca ta, elicea minima e 40 si asta doar pt un motor de cca 5000 rpv si 4s. in rest, elicea pt mono2 e de cca 42-48 mm diam si cca 28.000 - 35.000 rpm.
in cazul tau motorul e prea mic. nu ar trebui sa consumi mai mult de 40-50A pt o elice de 42-45. la concursuri pana anul trecut mergea cam toata lumea pe 12/14 nimh 3300 mA intr-o cursa de 5 min.
scoate si tu un motor si un esc de pe trex si pune-le in barca. sigur o sa vezi diferenta.
Laser frate!
#87 Useril este offline   Primus
  • Postari: 3026
Postat 21 September 2009 - 02:42 PM
ok, ziceti ca motorul e mic, ce sa punem in loc?
Am vazut ca Feigao sunt laudate de voi, ma ajutati sa aleg unul?
In legatura cu ESC, ce parere aveti de ACESTA?
Alte optiuni?
Mersi
p.s. nu merg esc-urile aero ca nu au racire cu apa.
#88 Useril este offline   fulgerica
  • Postari: 2235
  • Interests:vintage
Postat 21 September 2009 - 03:11 PM
"optiuni" nu-i decat una in cazul motoarelor china: Hobbywing EZRUN-150A-SD
restul nu pot controla turatia si se ard.
varianta urmatoare este Yge-120, dar deja e made in germany.
la un esc aero ii pui o cutiuta de racire (se gasesc si la noi) si imbraci totul intr-o camasa contractibila.
Aceasta postare a fost editata de fulgerica: 21 September 2009 - 03:13 PM
Laser frate!
#89 Useril este offline   Primus
  • Postari: 3026
Postat 21 September 2009 - 03:22 PM
M-am hotarat la un Feigao 540, care din ele sa fie?
Desprea ESC-ul asta ce ziceti?
http://www.hobbywing.com/english/ArticleSh...p?ArticleID=451
Mai mai gandeam si la X-power:
http://www.offshoreelectrics.com/proddetai...rod=xpo-blb100a
Aceasta postare a fost editata de Primus: 21 September 2009 - 03:23 PM
#90 Useril este offline   andriu
  • Postari: 884
  • Inregistrat: 06-March 07
Postat 21 September 2009 - 03:26 PM
Vezi postareaPrimus, la Sep 21 2009, 04:22 PM, a spus:
dezavantaj e BEC-ul. faptul ca nu are (zic eu)
"That's sooo oshemmm !!!!!"
  • 5 Pagini +
21 useri citesc topicul
