Modelism - RHC Forum: Graupner SUPERAIR 2 - Modelism - RHC Forum
Graupner SUPERAIR 2 trainer cu aripa joasa
#1 Useril este offline   shogi
  • Postari: 2753
  • Inregistrat: 08-March 06
  • Interests:pussy
Postat 16 July 2009 - 03:51 PM
Cu ajutorul lui mobi am intrat in posesia unui Graupner SuperAir 2.Este un trainer termic cu aripa joasa destinat zborului acrobatic.
Detalii:
Wingspan approx. 1460 mm
Overall length approx. 1200 mm
Wing area approx. 38 dm²
Tailplane area approx. 9 dm²
Total surface area approx. 47 dm²
All-up weight according to fittings approx. 2400 g
Description
- Almost Ready to Fly (ARTF)
- Conventional all-wood construction
- DSS linkage system on elevator and rudder
- Rudder coupled to steerable nosewheel
- Pre-painted GRP canopy
- Film-covered fuselage, wings and tail panels
- Fueltank, small items, linkage hardware pack
link catre producator
Cand l`am luat modelul avea vreo 3 zboruri din zisele proprietarului.In afara de o mica crapatura pe fuselaj nu avea nimic busit.Folia era umflata si pe fuselaj si pe aripi dar s`a rezolvat intr`o jumatate de ora cu fierul de calcat.Acum este ca nou.
Echipare:
5 bucati servo s3003
motor 9cmc ASP cu toba pitts
elice APC 10x6
O sa revin cu poze dupa ce imi ajunge toba si elicea.
  • Fisier atasat  G9374.jpg (17.49K)
Aceasta postare a fost editata de shogi: 16 July 2009 - 03:53 PM
#2 Useril este offline   RedBaron
  • Postari: 1639
  • Inregistrat: 30-April 06
Postat 16 July 2009 - 03:54 PM
hey...felicitari de achizitie...
elicea e prea mica... 12*6 iti recomand eu si de acolo poti varia (11*8 (viteza) , sau 12*5,13*4 (tractiune))...
spor la zbor :)
KIT GUPPY
#3 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 16 July 2009 - 03:56 PM
multam ..pai 12x6 am dar problema e ca e prea mare ...mai are vreo 2 cmc pana la sol
Aceasta postare a fost editata de shogi: 16 July 2009 - 03:56 PM
#4 Useril este offline   Rontaila
  • Postari: 324
  • Inregistrat: 29-May 07
  • Interests:Tot ce zboara cu motor sau se scufunda in mare
Postat 16 July 2009 - 08:09 PM
am si eu unul la fel ,dar cu motorizare de 7,5 cc ,pentru a mari garda eliciei pune o roata cu diametru mai mare in fata si ai grije la aterizare sa nu vii prea tare pe coada ca se rupe foarte repede, exact din spatele cabinei. Te rog sa dai ceva amanunte ,cand montezi motorul, despre cum ti-a iesit centrajul.
Bafta si CAVOK
Primul sosit ,ultimul plecat..
#5 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 16 July 2009 - 11:05 PM
multam de sfaturi ..o sa tin cont ..poze:
rontaila ..tu unde ai centrul de greutate ?exact unde zici ca se poate rupe am crapatura aia in solar ..m`am uitat mai atent si era plesnita si balsa putin dar s`ar rezolvat repede.
Aceasta postare a fost editata de shogi: 16 July 2009 - 11:07 PM
#6 Useril este offline   RedBaron
  • Postari: 1639
Postat 16 July 2009 - 11:08 PM
are jamba anterioara nu ar trebui sa fie problema... pune o roate mai mare eventual ...
rulezi in decoalre cu profundorul maxim tras, dar cu grija cand ridica roata sa dai drumul incet , si nu ar trebui sa fie probleme...
cu 10*6 omori motorul la ce turatie o sa aiba...
KIT GUPPY
#7 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 16 July 2009 - 11:09 PM
producatorul recomanda elici de la 10x6 in sus ..d`aia m`am axat pe asta.am zis sa fac un compromis intre tractiune si garda la sol.Daca o sa fie probleme pun roata mai mare si elice cu diametru mai mare.
#8 Useril este offline   Abburo
  • Postari: 1317
  • Inregistrat: 02-June 07
Postat 16 July 2009 - 11:10 PM
da' stiu ca le schimbi nu gluma ;)
Ce s-a intamplat cu Spitul... care a fost problema?
#9 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 16 July 2009 - 11:12 PM
ala chiar nu era de mine ..pe langa faptul ca a iesit si destul de greut nu ma intelegeam cu el in aer.era bun pentru un motor mai mare si nu imi permiteam asa ca l`am dat,posesorul actual urmand sa`l motorizeze mai puternic.era pacat de el sa il fac zdrente ca era un model foarte frumos.
#10 Useril este offline   RedBaron
  • Postari: 1639
Postat 16 July 2009 - 11:18 PM
o recomanda producatorul de la 10 in sus , dar eu tot zic ca il omori inutil... ia o roata de neam prost, pune-o acolo , si pune o elice de MINIM 11...
KIT GUPPY
#11 Useril este offline   Marton Csaba
  • Postari: 35
  • Inregistrat: 08-October 08
Postat 17 July 2009 - 07:32 AM
Salut!
Este un model exceptional, am avut si eu una, nu graupner, dar tot acelasi model. http://www.rhc.ro/forumrhc2/index.php?show...1&hl=canter
Zboara foarte cuminte, face tot ce vrei de la ea.
Din pacate, al meu nu mai e intre noi :blush:
#12 Useril este offline   Rontaila
  • Postari: 324
Postat 17 July 2009 - 08:24 AM
Vezi postareashogi, la Jul 17 2009, 12:05 AM, a spus:
La mine a iesit cam usor de bot ,motorul este un AVIASTAR de .46 ,a trebuit sa pun 20g de plumb in capota ,grije mare la pornire ca motorul pus invers se ineaca repede si am ars o bujie din neatentie . Ruptura a aparut exact dupa cadrul inclinat al cabinei ,tot ce este dupa acel cadru este facut doar din balsa de 2mm si lipt cu mare zgarcenie. La zbor sa comportat bine ,CANTER-u care este acelas avion este dat ca F3A incepatori :blush: ,la aterizare daca esti obisnuit sa vii fara motor sa fii atent ca are viteza verticala cam mare si trebuie sa redresezi din timp.Legat de montaj renunta la sarma scurta din ansamblul de comanda al profundorului ,elimini o veriga slaba in lantul comenzilor ,in caz ca se slabesc suruburile in piesa hexagonala ramai cu jumatate de profundor, in rest zbor placut!
#13 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 17 July 2009 - 11:49 AM
imi pare rau marton pentru modelul tau ...acum am vazut ca aveai pe el acelasi motor care o sa il pun si eu
@rontaila..mi`am comandat toba pitts deci nu o sa pun motorul invers.o sa aiba chiuloasa in partea dreapta
#14 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 17 July 2009 - 08:14 PM
RTF ...tre sa mai cosmetizez cablurile.
mi`a iesit putin greu de bot dar am compensat punand acumulatorul in spatele cabinei ..se vede in poze.acum CGul este aproape la 1 treime de bordul de atac.Elicea e 10x6 ..vedem cum se comporta cu ea si apoi mai urc diametrul (atat al elicii cat si al rotii frontale :) )
Aceasta postare a fost editata de shogi: 17 July 2009 - 08:18 PM
#15 Useril este offline   Abburo
  • Postari: 1317
Postat 17 July 2009 - 08:23 PM
se va supratura si incinge motorul cam tare cu 10x6 .... macar 11x7
Aceasta postare a fost editata de Abburo: 17 July 2009 - 08:24 PM
#16 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 17 July 2009 - 08:25 PM
am zis mai sus ...11*x nu am ..am 12x6 dar nu am jamba mai mare.Ma gandeam sa iau de la yak ...da pana mea vad ca si astea au acelasi diametru.Vedem ..poate fac rost de una mai maricica.
#17 Useril este offline   RedBaron
  • Postari: 1639
Postat 17 July 2009 - 08:35 PM
cumpara un 11... chiar si de lemn daca nu ai cum mai repede altceva dar nu pune 11 ... o sa te doara mai tarziu daca faci 2-3 zboruri cu el supraturat...
incearca si cu 12 ca 2 cm e totusi destul cat sa o ia...mai lung dar o ia(mai lung pt ca probabil va atinge putin iarba)
orium io zic, ca sincer sa nu zbori cu 10... desi ar zbura, sunt sigur de asta ,dar omori motorul
KIT GUPPY
#18 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 17 July 2009 - 09:15 PM
ok...o sa pun 12`le si vedem cum se comporta
#19 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 21 July 2009 - 08:51 PM
siiiiiii azi a zburat ...am facut 2 zboruri realizate cu succes.Problema e la aterizare ca vine al naibii de tare.Pe cer nu am depasit 40% din mansa si era racheta.L`am zburat cu elicea 12x6.o sa incerc sa ii micsorez pasu sa vedem ce iese asa.Din pacate nu a avut cine sa ma filmeze.Are o tinuta de zbor excelenta,e perfect trimat,decoleaza in 2 metrii ...aterizeaza in de vreo 50 de ori mai mult :blink:) ,cu expo -100% pe futaba tot face ca nebunu probabil din cauza suprafetelor mari.In concluzie sunt multumit de el.
8 useri citesc topicul
