Modelism - RHC Forum: modul Graupner 4157 - conexiuni - Modelism - RHC Forum
modul Graupner 4157 - conexiuni Multi-Mix
#1 Useril este offline   fulgerica
  • Postari: 2235
  • Inregistrat: 31-July 07
  • Interests:vintage
Postat 06 July 2009 - 01:25 AM
Ma poate ajuta cineva cu schema conexiunilor pentru modulul 4157 multi-mix de la Graupner?
Intuitiv am descoperit numai cum sa fac conexiunea pt flaperon, dar ma interesa mai mult cea de elevon. pe net n-am gasit nicio schema, decat descrierea de mai jos. multumesc!
Imagine atasata: gr4157.jpg
Cross mixer, mixing ratio two-fold adjustable, uni- and bi-directionally. Can be switched to V-mix (Delta models, V-tails), aileron mix (flaperons), Combi-mix, Flap-mix and Heli-mix. When used in conjunction with two (optional retrofit) extern switches (Ref. N°. 4160 and 4160.1 resp.) permits mix functions to be coupled/uncoupled individually or - using an extern double switch (Ref. N°. 4160.2) - together. A supplementary mixer input permits adding a further proportional or switch function, such as flaperon trim or coupling additional function modules.
Laser frate!
