Modelism - RHC Forum: Rock Crawling si Trail Trucks - Modelism - RHC Forum
  • 55 Pagini +
  • 19
  • 20
  • 21
  • 22
  • 23
#601 Useril este offline   florin m
  • Postari: 69
  • Inregistrat: 12-May 10
  • Interests:automodelismul,aeromodelismul
Postat 07 May 2011 - 12:29 PM
Am numerotat,pozele Nr,1 si Nr2.In poza 1este ridicat la maxim la fel se ridica si pe obstacole,dupa care se lasa jos,fiind tras de un elastic,deocamdata improvizatie,in a doua poza,este pozitia normala.Asputea sa-l fac sa fie tot timpu ridicat,dar la inclinati mari se rastoarna.In concluzie,vreau sa-l fac sa se ridice numai cind trece peste obstacole,dupa care sa-si revina la pozitia initiala,adica aproape de pamint.Asta incerc sa gasesc o solutie ,adica un arculet ceva,mai inventez eu ceva.
  • Imagine atasata: P070511_13.040001 Nr.1.JPG
  • Imagine atasata: P070511_13.040002 Nr.2.JPG
#602 Useril este offline   florin m
  • Postari: 69
Postat 07 May 2011 - 01:17 PM
Vezi postareaDaemonus Modelus, la 03 May 2011 - 11:31 PM, a spus:
https://lh6.googleusercontent.com/_KHsUz479rII/TcBrc1xiOTI/AAAAAAAAHSE/0sB2dPyGb-4/s1440/01.jpg
https://lh6.googleusercontent.com/_KHsUz479rII/TcBuBSKYDnI/AAAAAAAAHSc/XwvQpG91GAg/s1024/03.jpg
https://lh3.googleusercontent.com/_KHsUz479rII/TcBuK2vLPiI/AAAAAAAAHSs/ZZ8MA1qylaE/s576/05.jpg
https://lh3.googleusercontent.com/_KHsUz479rII/TcBuPAxe7lI/AAAAAAAAHS0/2FZG9pdiAjA/s800/06.jpg
https://lh3.googleusercontent.com/_KHsUz479rII/TcBu9iXYWKI/AAAAAAAAHTE/kHuxcbsJLuQ/s1024/08.jpg
https://lh3.googleusercontent.com/_KHsUz479rII/TcBuFeERFiI/AAAAAAAAHSk/hjTErLg0S2Q/s800/04.jpg
Ai facut cam tot ce se poate face pe el,upgrade sau cum se zice.
#603 Useril este offline   Daemonus Modelus
  • Postari: 421
  • Inregistrat: 21-June 10
Postat 07 May 2011 - 02:18 PM
Vezi postareaflorin m, la 07 May 2011 - 01:17 PM, a spus:
Este un custom build, in afara de osii si cutia de transfer nu mai este nimic AXIAL pe el...de la planetare la sasiu, jenti, anvelope etc etc.
Murdar poate....insa nu JEGOS !!!
#604 Useril este offline   florin m
  • Postari: 69
Postat 08 May 2011 - 12:42 PM
Poti sa-mi spui de unde,de pe care sait ti-ai comandat piesele?
#605 Useril este offline   florin m
  • Postari: 69
Postat 08 May 2011 - 12:52 PM
In viitor vreau sa-mi procur un XR10 si electronica pentru el... [am vazut ca au preturi bune pe http://www.ckrccrawlers.com/]mai bune ca pe TAWER SAU MODELSPORT UK,astea mi se par mai convenabile s-au cel putin astea le stiu eu.Daca sti tu altele da-mi ceva adrese.
#606 Useril este offline   florin m
  • Postari: 69
Postat 20 May 2011 - 11:40 AM
Sal,cataline,frumos xr10,cred ca esti primu-l posesor la ora actuala de pe forum.Se ridica standardelor sau mai bine zis la inaltimea asteptarilor tale?.Sa-l stapinesti SANATOS.
Aceasta postare a fost editata de florin m: 20 May 2011 - 11:41 AM
#607 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 21 May 2011 - 08:25 AM
Vezi postareaflorin m, la 20 May 2011 - 11:40 AM, a spus:
Da este OK desi destul de costisitor.
#608 Useril este offline   davidd
  • Postari: 371
  • Inregistrat: 23-March 10
  • Interests:Everything
Postat 21 May 2011 - 09:05 PM
Vezi postareaDaemonus Modelus, la 21 May 2011 - 08:25 AM, a spus:
Am o intrebare, daca ma poti ajuta te rog frumos. La crawlerul tau custom build, la partea sasiului de deasupra care-i de plastic alb, ce ai folosit (tub de plastic cred) ca sa imbini cu suruburi partea stanga cu partea dreapta, ca am si eu un proiect, si nu stiu ce sa folosesc/de unde sa imi cumpar (de preferat nu de pe net). Multumesc anticipat!
Aceasta postare a fost editata de davidd: 21 May 2011 - 09:06 PM
"I reject your reality and substitute my own"
david_dinamovistu@yahoo.com
0742128727
#609 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 21 May 2011 - 09:31 PM
Vezi postareadavidd, la 21 May 2011 - 09:05 PM, a spus:
Sunt bari de delrin, filetate 3mm. Nu as sti sa te indrum catre un magazin din RO, multe din acel custom build sunt componente refolosite din "parcul" meu rc. Daca vrei ceva care nu e costisitor, incearca teava de alu de 6 si bara filetata de 3 la interior - este varianta care functioneaza bine, desi nu arata asa extraordinar. In plus - mai ieftin de asa nu se poate. Vrei ceva mai finut un pic - bara de 6, filetezi cu 3 (daca ai tarozi si stii cum sa faci).
Mie mi-a facut cineva rost de Delrin de 5mm (o placa de 50x50cm) insa este prea subtire, un minim de 7 as recomanda. Chiar, daca stie cineva de unde pot cumpara niste Delrin, grosime 7mm....raman indatorat (nu vreau insa coala de 3m2),,,
#610 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 21 May 2011 - 09:47 PM
Custom se refera la faptul ca nu e un sasiu standard, produs de vreun mare nume in RC (crawling). Gearing-ul ales de mine, steering, transmisia etc - sunt alte elemente ce tin de custom si-mi apartin :clapping: Alea sunt secretul de fapt, nu modul in care arata....
La Bucuresti am avut un ghinion teribil sa ma lase bateria pe linia de start si in plus, eroare umana - am strans prea tare o roata in spate si un pin care-mi tinea hexul s-a indoit si mi-a facut o gramda de probleme, fapt ce a culminat la sfarsit cu ruperea cardanului spate.
#611 Useril este offline   MarinMircea
  • Postari: 580
  • Inregistrat: 20-May 10
  • Interests:Automodelism
    Ciclism (in portii moderate)
Postat 21 May 2011 - 09:52 PM
sa inteleg ca la crawler trebuie sa ai mereu grija din cauza cuplului mare?
Firestorm 10t - la vanzare
Traxxas slash ultimate 4x4 VXL
#612 Useril este offline   davidd
  • Postari: 371
Postat 21 May 2011 - 10:03 PM
Vezi postareaDaemonus Modelus, la 21 May 2011 - 09:31 PM, a spus:
Multumesc de lamuriri, am sa vad ce varianta aleg pana la urma si voi pune niste poze cu ce a iesit... oricum, sa nu va asteptati sa fie ceva extraordinar, l-am facut din piese de bonzer si diferential de rustler, la care ma avut un noroc extraordinar sa se potriveasca perfect imbinarile catre cele doua punti. Am umplut diferentialele cu Poxipol, am citit pe net ca se practica metoda si in afara, dar cu J-B Weld.
Multumesc inca odata de sfaturi!
0742128727
#613 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 21 May 2011 - 10:04 PM
Vezi postareaMarinMircea, la 21 May 2011 - 09:52 PM, a spus:
Crawlingul este o disciplina la care orice chestie cat de mica are o importanta majora pe pietre. Nu vreau sa-mi pun lumea in cap, dar nu prea se compara cu nici o alta ramura a (auto)modelismului.
Cuplul este dupa cum ti-l faci :clapping: Din pinioane, din pinioanele din diferentialele fata/spate. Locurile pe care (inca) ma dau pentru testarea modificarilor aduse sunt extreme fara nici un fel de exagerare si le prefer asa pentru ca daca rezista acolo, rezista oriunde. Axial Scorpionul are un slipper clutch, menit sa protejeze crawlerul atunci cand apar fortaje/blocaje. Se poate scapa de el, insa atentie maxima la cardane, planetare.:) Mie mi-au ramas blocate rotile intre pietre si am tot fortat....nu s-au dus nici cardanele, nici planetarele (erau Heavy Duty, dar nu asta a fost motivul). Motivul a fost ca rotile nefiind din ALU si nici foarte bine stranse, hexul de pe planetara a inceput sa "sape" in roata....si de aici pana la slabirea surubului nu a mai fost decat un pas mic....
#614 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 21 May 2011 - 10:06 PM
Vezi postareadavidd, la 21 May 2011 - 10:03 PM, a spus:
Asteptam video :).
Sa stii totusi ca Poxipol este casant (daca-mi aduc bine aminte) si nu stiu daca te tine cine stie ce. oricum este mult pana cand te prinde febra crawlingului, cati iti vei vinde celelalte modele :clapping:
#615 Useril este offline   davidd
  • Postari: 371
Postat 21 May 2011 - 10:32 PM
Vezi postareaDaemonus Modelus, la 21 May 2011 - 10:06 PM, a spus:
Asteptam video :D.
Cu siguranta voi face si un video cand il termin, am gasit niste locuri superbe pe micutul nostru munte Meses. :)
0742128727
#616 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 21 May 2011 - 10:53 PM
Vezi postareadavidd, la 21 May 2011 - 10:32 PM, a spus:
Daca aveti loc de crawling....este pacat sa nu practicati :) Nu va mai chinuiti ca mine :)
#617 Useril este offline   davidd
  • Postari: 371
Postat 22 May 2011 - 10:40 AM
Vezi postareaDaemonus Modelus, la 21 May 2011 - 10:53 PM, a spus:
nu cred ca ii cazul sa vb la plural, ca in Zalau sunt numai eu :)
Insa desigur, mai sunt cei din Cluj, care mi-ar face placere sa-i invit odata la o iesire aici...
0742128727
#618 Useril este offline   davidd
  • Postari: 371
Postat 22 May 2011 - 11:37 AM
Sau daca folosesc numai tija filetata si cu piulite pe ambele parti a unei jumatati de sasiu ar merge?
0742128727
#619 Useril este offline   ovidiugm
  • Postari: 1031
Postat 22 May 2011 - 01:07 PM
Merge dar e mai inestetic si trebuie sa ai grija la ajustarea distantei dintre placi. Daca folosesti mai multe astfel de tije in diverse puncte ale sasiului, masoara cu atentie ca la infiletat distantele sa fie egale, piulitele de pe interior se mai misca la montaj. De asemenea, distantierul rigidizeaza structura mai bine.
#620 Useril este offline   davidd
  • Postari: 371
Postat 22 May 2011 - 01:16 PM
Vezi postareaovidiugm, la 22 May 2011 - 01:07 PM, a spus:
Ca-i inestetic nu-i problema, caroseria sa arate estectic. O sa am grija cu distanta, deasemenea ma gandeam ca pe interior, sa lipesc cu superglue piulitele...
Aceasta postare a fost editata de davidd: 22 May 2011 - 01:17 PM
0742128727
#621 Useril este offline   davidd
  • Postari: 371
Postat 27 May 2011 - 09:51 PM
pentru directie pe ambele punti este neaparat nevoie de 2 servo-uri identice? Eu am un Futaba S3305 si un TowerPro MG995, ambele cu angrenaje metalice...
0742128727
#622 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 27 May 2011 - 10:14 PM
Vezi postareadavidd, la 27 May 2011 - 09:51 PM, a spus:
Din ce stiu eu nu e neaparat nevoie sa fie identice. Nu am avut niciodata dual steering asa ca s-ar putea sa ma insel. Oricum, la noi in RO inca nu este cazul dar intr-o competitie dual steeringul nu este permis.
#623 Useril este offline   davidd
  • Postari: 371
Postat 27 May 2011 - 10:33 PM
Si care ar fi recomandat sa-l pun pe fata si care pe spate?
0742128727
#624 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 27 May 2011 - 11:19 PM
Vezi postareadavidd, la 27 May 2011 - 10:33 PM, a spus:
L-as pune pe cel puternic pe fata.
#625 Useril este offline   davidd
  • Postari: 371
Postat 27 May 2011 - 11:33 PM
Mersi, acuma mai astept saptaman viitoare niste articulatii sferice, teva de aluminiu, etc... weekend-ul viitor sper sa fie gata.
0742128727
#626 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 28 May 2011 - 12:29 AM
Foto & video si neaparat la recensamant crawler :)
#627 Useril este offline   mizzone
  • Postari: 2182
  • Inregistrat: 07-May 03
Postat 29 May 2011 - 08:52 AM
Daca aveti loc de crawling....este pacat sa nu practicati :rofl: Nu va mai chinuiti ca mine :yahoo:
noi am cautat si am gasit....e drept, am mers vreo 150 km...
dar am facut teste, verificari, sa intelegem mai mult din ceea ce pot sau nu pot masinile, deasemenea sa putem calibra cu mai multa acuratete viitoarele trasee competitionale...
bafta si minuni!
  • Imagine atasata: DSC00437.JPG
#628 Useril este offline   Alfa
  • Postari: 706
  • Inregistrat: 03-November 06
Postat 29 May 2011 - 09:05 AM
Salutare baieti!
Am si eu o intrebare unde ar exista locuri unde sa ne putem antrena in Bucuresti sau pe langa. Eu am parcul asta IOR de langa mine unde noroc ca sunt astia in constructii si am pe unde sa ma dau si cu crawlerul, dar un loc special exista?
Multumesc!
Favourite racing class:
electric: buggy 2wd,4wd & SC 1:10 off-road
nitro: 1/8 truggy,buggy
CSTA Bucuresti
“If everything seems under control, you're not going fast enough.”
― Mario Andretti
#629 Useril este offline   mizzone
  • Postari: 2182
Postat 29 May 2011 - 12:26 PM
Vezi postareaAlfa, la 29 May 2011 - 09:05 AM, a spus:
Salutare baieti!
Multumesc!
salut.
hai sa ne vedem la miez, la debarcader, are si el crawler acolo, in plus exista linga el o zona de pietre pe care o putem incerca...vom discuta si despre gasirea/amenajarea unui loc, mai mult sau mai putin permanent, de crawlere
propun miercuri spre sfirsitul zilei...
bafta si minuni!
#630 Useril este offline   Daemonus Modelus
  • Postari: 421
Postat 29 May 2011 - 11:56 PM
  • 55 Pagini +
  • 19
  • 20
  • 21
  • 22
  • 23
14 useri citesc topicul
