SUNDOWNER 50 SA VINA IN HANGARUL MEU!
Postat 10 February 2009 - 11:55 PM
Postat 10 February 2009 - 11:56 PM
Postat 11 February 2009 - 12:04 AM
Aceasta postare a fost editata de TUROK: 11 February 2009 - 12:05 AM
Postat 11 February 2009 - 12:13 AM
* Wing Span:63 in. (1600mm)
* Overall Length:47.4 in. (1204mm)
* Wing Area:572 sq. in. (36.9 sq. dm.)
* Flying Weight:6-7 lbs (2.7-3.2 kg.)
* Engine Size:.40 -.52 2-stroke glow or .56 - .82 4-stroke glow
* Motor Size:E-Flight Power 46BL Outrunner Motor (EFLM4046A)
* Radio:4 channels minimum; 5 recomended
* Servos:requires 5 standard servos
* Trim Scheme Colors:Pearl Charcoal HANU846, Silver HANU881, White HANU870, Orange HANU877
* CG (center of gravity):2 1/2 in. back from the leading edge at the fuselage
* Wing Loading:24.2 - 28.2oz per sq. ft.
Aceasta postare a fost editata de TUROK: 11 February 2009 - 12:15 AM
Postat 11 February 2009 - 12:23 AM
The .50-size Sundowner can be powered for performance using a variety of 2- or 4-stroke glow engines or converted to electric power for clean, no-fuss flying. The two-piece plug-in wing makes transporting this aircraft an easier process. A removable top hatch provides access to the plane’s interior to make it easy to get to the electronics and/or fuel tank. The Sundowner also includes installed high-quality prehinged hardware and a heavy-duty anodized aluminum wing tube which provides extreme durability at low weight.
So take the Sundowner 50 ARF to the flying field—and enjoy all the stares you get as it streaks into a turn at mach speed.
Aceasta postare a fost editata de TUROK: 11 February 2009 - 12:26 AM
Postat 11 February 2009 - 12:39 AM
http://www.youtube.c...mcc8Yd5Rno&NR=1
Postat 11 February 2009 - 09:01 AM
Daca vei urmarii filmele cu ele o sa observi ca au piste de beton sau iarba
perfect nivelata ( iar de multe ori pt. reclama pilotii lor sunt foarte buni ).
Daca il urmaresti pe Silvestri in filmele lui nu se vor asemana aterizarile cu
ce a patit Romulus cu Sebart-ul lui ( si de Romulus nu poti spune ca nu stie sa piloteze )
La fel se intampla si cu modelele militare scale.
Oricum alegerea se face si cu sufletul ! Bafta !
Postat 12 February 2009 - 08:26 AM
Postat 12 February 2009 - 09:46 AM
TUROK, la Feb 11 2009, 12:39 AM, a spus:
Astept si eu sa zica cineva ce statie e. Piloteaza foarte bine, si la o singura mana.
E super avionul, dar vitezoman nonstop, cam greu cu aterizarile.
Aceasta postare a fost editata de protheus: 12 February 2009 - 09:47 AM
Postat 12 February 2009 - 10:15 AM
Postat 12 February 2009 - 10:21 AM
# Wing Span:80.5 in (2045mm)
# Overall Length:60.6 in (1539mm)
# Wing Area:933 sq in (60.2 sq dm)
# Flying Weight:12.0-14.0 lb (5.4-6.4 kg)
# Engine Size:26-35cc gas; 1.20-1.80 4-stroke; 1.00-2.10 2-stroke
Postat 12 February 2009 - 10:39 AM
si care o zboara doar pe Clinceni , pe Chitila au spus ca s-ar putea sa nu ajunga pista
lasand la o parte gropile ( iar ei cand vin la aterizare o aduc langa picior daca vor ) ...
io l-as fi adus langa bunicu poate. ...
Oricum ce e frumos e frumos !
Postat 12 February 2009 - 01:57 PM
TUROK, la Feb 11 2009, 01:39 AM, a spus:
eu unul nu am gasit nimic dar poate ne lamureste cineva !
Postat 12 February 2009 - 08:55 PM
minutul 2:26 al filmuletului .
Aceasta postare a fost editata de TUROK: 12 February 2009 - 08:58 PM
Postat 12 February 2009 - 09:52 PM
Oricum, mosulica poate avea orice in cutia aceea. E derutant cum o tine.
Pareri?
#19
Postat 12 February 2009 - 09:57 PM
#20
Postat 12 February 2009 - 10:01 PM
#22
Postat 13 February 2009 - 12:50 AM
#23
Postat 13 February 2009 - 12:44 PM
#24
Postat 15 July 2009 - 07:32 PM
