  • 201 Pagini +
  • 191
  • 192
  • 193
  • 194
  • 195
#5761 Useril este offline   soarece
  • Postari: 2860
  • Inregistrat: 03-January 13
Postat 15 June 2015 - 12:12 AM
ceva interesant de citit :
http://www.hpibajafo...ad.php?t=144332
Aceasta postare a fost editata de soarece: 15 June 2015 - 12:13 AM
alta culeasa din popor :
R: Pen`ca poate."
#5762 Useril este offline   master
  • Postari: 816
Postat 15 June 2015 - 08:58 PM
Am vorbit la HPI, s-a rezolvat. Imi vor trimite un set de sateliti nou. Super! ASA DA! Bravo HPI! :clapping:
In tara asta prost facuta,
#5763 Useril este offline   revolt
  • Postari: 590
  • Inregistrat: 25-February 15
Postat 15 June 2015 - 09:14 PM
Vezi postareamaster, la 15 June 2015 - 08:58 PM, a spus:
Andrei de la HPI e de zahar. http://www.rhcforum.ro/public/style_emoticons/default/good.gifhttp://www.rhcforum.ro/public/style_emoticons/default/good.gif
Hpi Savage Flux XL 3 diffs
Hpi Savage Flux XL
Hpi Savage Flux
#5764 Useril este offline   soarece
  • Postari: 2860
Postat 15 June 2015 - 11:13 PM
Vezi postarearevolt, la 15 June 2015 - 09:14 PM, a spus:
confirm :good: :good: :good:
Aceasta postare a fost editata de soarece: 15 June 2015 - 11:13 PM
R: Pen`ca poate."
#5765 Useril este offline   master
  • Postari: 816
Postat 17 June 2015 - 08:05 PM
A ajuns astazi dupa-amiaza setul de sateliti. Acum l-am montat, pare totul ok. Sper sa tina!
Oricum ii multumesc lui Andrei dar si intregii echipe de la HPI!
Aceasta postare a fost editata de master: 17 June 2015 - 08:05 PM
#5766 Useril este offline   revolt
  • Postari: 590
Postat 18 June 2015 - 09:28 AM
da-i talpa
Hpi Savage Flux XL
Hpi Savage Flux
#5767 Useril este offline   soarece
  • Postari: 2860
Postat 18 June 2015 - 10:16 AM
Vezi postarearevolt, la 18 June 2015 - 09:28 AM, a spus:
talpa
deget adica ^_^
R: Pen`ca poate."
#5768 Useril este offline   revolt
  • Postari: 590
Postat 21 June 2015 - 01:50 PM
damage report :((
Hpi Savage Flux XL
Hpi Savage Flux
#5769 Useril este offline   master
  • Postari: 816
Postat 21 June 2015 - 07:10 PM
Ce s-a întâmplat? S-a dus esc-ul? Cum asta?
#5770 Useril este offline   revolt
  • Postari: 590
Postat 21 June 2015 - 08:13 PM
Vezi postareamaster, la 21 June 2015 - 07:10 PM, a spus:
esc-ul e alive, ventilatorul a pierdut o pala :))
Hpi Savage Flux XL
Hpi Savage Flux
#5771 Useril este offline   maneta
  • Postari: 1579
  • Inregistrat: 02-February 11
Postat 24 June 2015 - 07:59 PM
La o iesire am pierdut imbusul pe fata la cupa ce iese din diferential inspre cutie.
Si ce sa vezi ,doar cu tractiunea spate nu se mai ridica pe doua roti desi nu are dif central.
team durango dex410 V4
team durango desc410
savage flux
vorza flux
Tel. 0748382727
#5772 Useril este offline   revolt
  • Postari: 590
Postat 24 June 2015 - 08:52 PM
eu am pierdut invers...
adik tragea doar fata..
si surpriza.. rotile erau balon si masina 5km la ora :))
Hpi Savage Flux XL
Hpi Savage Flux
#5773 Useril este offline   hassel
  • Postari: 2464
  • Inregistrat: 02-February 12
Postat 25 June 2015 - 10:27 AM
Pot sa zic ca am pierdut pe rand si fata si spatele, dar cand am pierdut fata, savage facea totusi whelie cu pinion de 20 si spur de 47 pe termic . in schimb cand am pierdut spatele, masina nu mai avea nici un farmec ... baloons in the front, si nu mai avea nici control pe directie.
BAJA
5SC 30cc gas
#5774 Useril este offline   Mihai Pall
  • Postari: 754
  • Inregistrat: 07-December 14
Postat 26 June 2015 - 05:43 PM
Oarecum e normal ca nu mai trage modelul fara tractiunea spate, ce greutate apasa pe puntea spate? Aproape nimic. Deci tractiunea aproape ca nu exista.
1/8 Summit Highway Police Patrol on Castle 2200kV / ELC 6S
1/8 Brushless E-Revo
#5775 Useril este offline   master
  • Postari: 816
Postat 26 June 2015 - 08:53 PM
Adică cum ce tracțiune să aibă pe spate? La Savage tocmai ca este mai mare greutatea pe spate decât pe față. Iar aderență roților pe spate este semnificativ mai mare decât cea de pe față.
#5776 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
  • Inregistrat: 31-May 12
Postat 26 June 2015 - 09:12 PM
A bagat omu' gresit des'tu' in tastatura, voia sa spuna ca ce greutate apasa pe puntea fata...
Si la orice are doua punti, una fata si una spate, la accelerare greutatea se muta spre spate. Nu doar la Savage. Ca asa vrea fizica! :)
Axial Yeti XL
Losi LST XXL
Imagine postata
#5777 Useril este offline   Mihai Pall
  • Postari: 754
Postat 27 June 2015 - 12:51 PM
Corect, multumesc tzicul.
Ciudat este ca in viata reala, o masina cu tractiune spate de ex, va intampina mai multe probleme si va rupe mai usor aderenta pe traseu cu aderenta scazuta, noroi, zapada, decat una cu tractiune fata. De ex cu Jetta am urcat fara probleme pasul Tihuta pe zapada de 20cm.
Cu BMW-ul, nu am putut iesi din parcare cand a inghetat zapada care a cazut de pe masina si a facut o bordura de 10 cm.
#5778 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 27 June 2015 - 01:14 PM
Nu e chiar așa de ciudat. În viața reală toată greutatea motorului apasă pe puntea față, acolo unde ai și tracțiunea. La BMW ai greutatea pe puntea față și tracțiunea pe spate. Așa că fără un pic de electronică ajutătoare e normal să nu faci mare lucru cu ea. Așa că ia-ți o Dacia 1100, unde ai și greutate și tracțiune pe spate :)
Axial Yeti XL
Losi LST XXL
Imagine postata
#5779 Useril este offline   master
  • Postari: 816
Postat 27 June 2015 - 04:12 PM
Un Porsche nu-l l-ai pune să își ia.....😜
#5780 Useril este offline   soarece
  • Postari: 2860
Postat 27 June 2015 - 10:32 PM
Vezi postareaTzicul, la 27 June 2015 - 01:14 PM, a spus:
un clio v6 ph1/ph2 will do the trick ....motor spate-tractiune spate,cai multi = distractie maxima :lol:
Aceasta postare a fost editata de soarece: 27 June 2015 - 10:33 PM
R: Pen`ca poate."
#5781 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 28 June 2015 - 12:30 AM
Sau un Tico cu W12. Așa ai motorul cât mașina și gata treaba :))))
Axial Yeti XL
Losi LST XXL
Imagine postata
#5782 Useril este offline   Mihai Pall
  • Postari: 754
Postat 28 June 2015 - 10:11 AM
Cred ca discutia e ceva mai complexa de ce in realitate comportamentul este altul.
Alta chestie interesanta, este ca pot sa numar pe degetele de la maini oamenii care folosesc topicurile astea, indiferent ca suntem la Revo, Savage, Slash, sau alte minuni :))
Revolt, tzicul, soarece, hassel, master, radu94, ice_2k si cu ala, Mihai Pall ;))
#5783 Useril este offline   master
  • Postari: 816
Postat 28 June 2015 - 12:35 PM
Apopos de tracțiune, astăzi vreau să scot mașina la câteva ture.....să văd cum se comporta cu diferențialele în care am pus ulei 7000k. Cu burta in sus daca îl accelerez și țin una din roți apoi îi dau drumul și nu mai accelerez, roțile nu se mai învârt în sensuri opuse una față de cealaltă așa de mult ca la vaselină drept fiind ca uleiul este mai vâscos.
Deci aderența ar trebui să fie mai bună st traiectoria mult mai precisă.
#5784 Useril este offline   soarece
  • Postari: 2860
Postat 28 June 2015 - 02:56 PM
Vezi postareaMihai Pall, la 28 June 2015 - 10:11 AM, a spus:
...pot sa numar pe degetele de la maini oamenii care folosesc topicurile astea, indiferent ca suntem la Revo, Savage, Slash, sau alte minuni :))
da,ceilalti citesc,baga la cap ce-i bun si pleaca.... -_-
BTW : am si eu cateva topice p-aci pe care la iubesc pentru ca am detinut si eu cateva dihanii de Savage ,doua baja si un WR8 .....
Aceasta postare a fost editata de soarece: 28 June 2015 - 02:58 PM
R: Pen`ca poate."
#5785 Useril este offline   revolt
  • Postari: 590
Postat 28 June 2015 - 05:30 PM
dupa ce am setat cutoff-ul din esc la 3.2v pe celula ..
intra 6400/ 6200 mah in bateriile de 6000mah, deci urcam inapoi la 3.4v pe celula :D
Hpi Savage Flux XL
Hpi Savage Flux
#5786 Useril este offline   revolt
  • Postari: 590
Postat 28 June 2015 - 05:31 PM
ceva mentenanta la amortizoare ..
Hpi Savage Flux XL
Hpi Savage Flux
#5787 Useril este offline   revolt
  • Postari: 590
Postat 28 June 2015 - 05:33 PM
a intrat transparent si in 5 sedinte cu :
a iesit :
dupa ce se depune toata mizeria aia la fund, intra inapoi in amortizoare :D
Aceasta postare a fost editata de revolt: 28 June 2015 - 05:33 PM
Hpi Savage Flux XL
Hpi Savage Flux
#5788 Useril este offline   revolt
  • Postari: 590
Postat 28 June 2015 - 05:36 PM
si cand te dai printre copaci, risti sa nu-i poti ocoli pe toti.
Hpi Savage Flux XL
Hpi Savage Flux
#5789 Useril este offline   revolt
  • Postari: 590
Postat 28 June 2015 - 05:42 PM
oare daca dau savage-ul cu asa ceva http://www.brakedustrepellent.com/ se mai prinde praful pe el ??
Hpi Savage Flux XL
Hpi Savage Flux
#5790 Useril este offline   revolt
  • Postari: 590
Postat 28 June 2015 - 06:01 PM
sa fie praf :
am zis.
Hpi Savage Flux XL
Hpi Savage Flux
  • 201 Pagini +
  • 191
  • 192
  • 193
  • 194
  • 195
82 useri citesc topicul
0 membri, 82 vizitatori, 0 utilizatori anonimi
