  • 201 Pagini +
  • 110
  • 111
  • 112
  • 113
  • 114
#3331 Useril este offline   e.cata
  • Banned
  • Postari: 3386
  • Inregistrat: 22-October 12
Postat 01 September 2013 - 09:37 PM
Vezi postareae.cata, la 01 September 2013 - 09:29 PM, a spus:
ei bine al meu e diferit...
found it... After a long run, you bring the vehicle back in and listen. If the idle sounds funny......sort of sizzling, or it has been described as a frying egg sound, then you may be having pre-ignition (or detonation....never was sure of the difference).
cred ca am gasit cauza..
pe motor vad ca am o bujie fierbinte...
mai fac o baie!
#3332 Useril este offline   soarece
  • Postari: 2860
  • Inregistrat: 03-January 13
Postat 01 September 2013 - 09:39 PM
ti-ai/am raspuns.....
Aceasta postare a fost editata de soarece: 01 September 2013 - 09:39 PM
alta culeasa din popor :
R: Pen`ca poate."
#3333 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 01 September 2013 - 09:40 PM
Vezi postareasoarece, la 01 September 2013 - 09:36 PM, a spus:
Nu-s convins dar ca si cauze:
1- amestec prea sarac
2- temperatura de lucru a motorului prea mare
3- raport de compresie prea mare
care ofi ? :rolleyes:
1 = nu cred, fumul si temperatura au fost pana in 116 grade
2 = o sg data am avut 130
3 = am 4 saibe,
cred ca bujia e de vina..
am sa o schimb maine si am sa incerc din nou!
mai fac o baie!
#3334 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 01 September 2013 - 09:43 PM
oare daca pun doua saibe de cupru sub bujie?
mai fac o baie!
#3335 Useril este offline   Zeus
  • Postari: 2455
  • Inregistrat: 15-January 09
Postat 01 September 2013 - 09:55 PM
Cata, facem maine o iesire?
#3336 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 01 September 2013 - 09:58 PM
3 poze... 1000 de cuvinte!
..maine nu pot.. am un program foarte aglomerat, marti sau miercuri, dar pana in ora 13..
Aceasta postare a fost editata de e.cata: 01 September 2013 - 09:59 PM
mai fac o baie!
#3337 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 01 September 2013 - 10:02 PM
si dupa o trecere usoara cu un servetel peste suprafete...
mai fac o baie!
#3338 Useril este offline   soarece
  • Postari: 2860
Postat 01 September 2013 - 10:11 PM
te-ai apucat la ora asta sa desfaci savageul ? :clapping:
R: Pen`ca poate."
#3339 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 01 September 2013 - 10:12 PM
Vezi postareasoarece, la 01 September 2013 - 10:11 PM, a spus:
nope.. am scos doar radiatorul.. sa vad care ar fi fost cauza performantelor extrem de slabe de astazi..
Aceasta postare a fost editata de e.cata: 01 September 2013 - 10:13 PM
mai fac o baie!
#3340 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
  • Inregistrat: 31-May 12
Postat 01 September 2013 - 10:22 PM
Mi-am cumparat astazi diverse de pe amainhobbies, de vreo 50$. Stiti cat am platit transportul? 0.79$ :clapping:
Asa ca daca aveti ceva de luat, bagati repede. S-ar putea sa fie datorita Labor Day, ziceau ca este promotional. Si, in plus, daca luati peste 100 de coco, va mai dau 10% discount!
Axial Yeti XL
Losi LST XXL
Imagine postata
#3341 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 01 September 2013 - 10:28 PM
Vezi postareaTzicul, la 01 September 2013 - 10:22 PM, a spus:
...Asa ca daca aveti ceva de luat, bagati repede.
prea tarziu... ma bag in pat..
am culcat si savage-ul
nb to all.
Aceasta postare a fost editata de e.cata: 01 September 2013 - 10:29 PM
mai fac o baie!
#3342 Useril este offline   soarece
  • Postari: 2860
Postat 03 September 2013 - 01:55 AM
ma,ma tot fixa o idee odata.....la savy nu merge pus un filtru de aer de hpi trophy truggy 4.6 de ala WP ? nu e dual stage dar are carapace...ar fi util cand te dai cu ea fara coaja,ca sa nu mai umbli cu saculetii aia,ar merge si pe vreme uda ,noroi,etc....ce ziceti ?
http://shop.hpi-raci...hy--p-2234.html
R: Pen`ca poate."
#3343 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 03 September 2013 - 09:14 AM
Vezi postareasoarece, la 03 September 2013 - 01:55 AM, a spus:
merge sigur..
am si eu o alta variatie de filtru de aer pt vreme rea, cu care ma dau iarna pe zapada...
arata cam asa:
si se gaseste aici: http://www.fxmodells...id/1322/page/94
Aceasta postare a fost editata de e.cata: 03 September 2013 - 09:15 AM
mai fac o baie!
#3344 Useril este offline   executivul
  • Postari: 195
  • Inregistrat: 10-June 13
  • Interests:RC Cars & Planes
Postat 03 September 2013 - 12:52 PM
Uite Cata si solutia la problema noastra cu rulmentul din fata:
http://www.bukupower...nkCaseCaps.aspx
Traxxas Summit, HPI Savage XL K5.9, HK Mission-D DRB clone, HPI Mircro RS4 Drift
RCPowers home-made F35v2, RCPowers home-made F18V3, RCPowers home-made F35V3
HobbyKing SK450 Dead-Cat
#3345 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 03 September 2013 - 04:47 PM
Vezi postareaexecutivul, la 03 September 2013 - 12:52 PM, a spus:
daca faci comanda.. contribui si eu .,,
mai fac o baie!
#3346 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 03 September 2013 - 05:12 PM
Ati luat-o cu capu'?? Cu banii aia iti schimbi de trei ori rulmentul!! :wacko:
Axial Yeti XL
Losi LST XXL
Imagine postata
#3347 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 03 September 2013 - 05:37 PM
Vezi postareaTzicul, la 03 September 2013 - 05:12 PM, a spus:
eu l-am schimbat recent si tot scapa, si acuma mai nou imi da si rateuri si e greu de reglat, deci trage la greu aer fals..
ai un link ceva cu niste rulmenti buni de fata ?
mai fac o baie!
#3348 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 03 September 2013 - 05:39 PM
Eu am luat SKF de la Badi.ro
I-am luat pentru Kyosho, dar presupun ca au si pentru HPI
Axial Yeti XL
Losi LST XXL
Imagine postata
#3349 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 03 September 2013 - 05:41 PM
Vezi postareaTzicul, la 03 September 2013 - 05:39 PM, a spus:
al meu e 19x7x6 am sa ma duc sa vad si eu cat e unu la ghezaco iasi.. skf
al meu motor face balta pe la rulmentul din fata..
Aceasta postare a fost editata de e.cata: 03 September 2013 - 05:43 PM
mai fac o baie!
#3350 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 03 September 2013 - 05:43 PM
Pe cel din fata, cu dubla etansare, am dat cam 25 lei, parca. Culmea e ca cel interior, fara etansari, e mai scump, pe la 40 lei. Ce-i drept, e un pic mai mare
Axial Yeti XL
Losi LST XXL
Imagine postata
#3351 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 03 September 2013 - 05:52 PM
Vezi postareaTzicul, la 03 September 2013 - 05:43 PM, a spus:
asa am pus si eu, cu dubla etansare NTN, a rezistat cu brio vreo 12 rezervoare, apoi.. dezastru...
mai fac o baie!
#3352 Useril este offline   e.cata
  • Banned
  • Postari: 3386
Postat 04 September 2013 - 04:48 PM
asa cum a aparut problema, asa a si disparut(ameliorat).. cred ca a fost vremea de vina + un reglaj necorespunzator..
azi a mers acceptabil..
mai jos.. doua bestii.. in parcare la Fortus.
Aceasta postare a fost editata de e.cata: 04 September 2013 - 04:49 PM
mai fac o baie!
#3353 Useril este offline   maneta
  • Postari: 1579
  • Inregistrat: 02-February 11
Postat 04 September 2013 - 05:52 PM
salutari...daca are cineva un spur de plastic de savage 52t de vanzare
team durango dex410 V4
team durango desc410
savage flux
vorza flux
Tel. 0748382727
#3354 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 04 September 2013 - 07:44 PM
Vezi postareae.cata, la 03 September 2013 - 05:37 PM, a spus:
http://www.avidrc.com/
http://www.bocabeari...ature=2%20SPEED
Tipii de la Boca au o gramada de modele/calitati, ii poti alege dupa dimensiuni sau dupa masina, pe bucata sau la set
Axial Yeti XL
Losi LST XXL
Imagine postata
#3355 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 04 September 2013 - 08:06 PM
Cam asa aratau sabotii mei dupa vreo 15 rezervoare cu clopot 20T
  • Imagine atasata: CAM00494.jpg
Aceasta postare a fost editata de Tzicul: 04 September 2013 - 08:07 PM
Axial Yeti XL
Losi LST XXL
Imagine postata
#3356 Useril este offline   executivul
  • Postari: 195
Postat 04 September 2013 - 08:09 PM
Vezi postareaTzicul, la 04 September 2013 - 08:06 PM, a spus:
Erau cumva din aia super heavy duty?
#3357 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 04 September 2013 - 08:13 PM
Si asa arata acum, cu saboti Kyosho style, handmade pe strung :) by user-ul ndc74, la un pret de 15/set
  • Imagine atasata: CAM00492.jpg
Axial Yeti XL
Losi LST XXL
Imagine postata
#3358 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 04 September 2013 - 08:14 PM
Vezi postareaexecutivul, la 04 September 2013 - 08:09 PM, a spus:
Ionut asa zice si erau si noi!! Varza s-au facut. Primul set de la Kyosho m-a tinut vreo 3 ani! :)
Axial Yeti XL
Losi LST XXL
Imagine postata
#3359 Useril este offline   soarece
  • Postari: 2860
Postat 04 September 2013 - 08:58 PM
Vezi postareaTzicul, la 04 September 2013 - 08:13 PM, a spus:
ieftin si bun,super buna ideea !
Vezi postareaTzicul, la 04 September 2013 - 08:14 PM, a spus:
erau noi....probabil ca imperecherea pinioanelor am facut-o prea lunga.mergi pe ceva mai scurt ,ai putea incepe cu un clopot de 17 !
R: Pen`ca poate."
#3360 Useril este offline   Tzicul
  • Free your mind
  • Postari: 2111
Postat 04 September 2013 - 09:05 PM
Vezi postareasoarece, la 04 September 2013 - 08:58 PM, a spus:
S-a facut deja, dupa ce mi-a ras si un set cu doi saboti in doar vreo 3-4 rezervoare cu 20T. O sa-l desfac in we acesta sa vad cum arata dupa 4 iesiri cu clopot 17T. Daca nu-mi place, trec la spur de 52T. Cu 17T deja se catara aproape la fel de bine ca Mad Force-ul
Axial Yeti XL
Losi LST XXL
Imagine postata
  • 201 Pagini +
  • 110
  • 111
  • 112
  • 113
  • 114
34 useri citesc topicul
0 membri, 34 vizitatori, 0 utilizatori anonimi
