  • 201 Pagini +
  • 39
  • 40
  • 41
  • 42
  • 43
#1201 Useril este offline   Prepe
  • Postari: 169
  • Inregistrat: 17-November 08
Postat 19 December 2010 - 10:36 PM
Imi poate spune si mie cineva ce dimensiune are furtunul de combustibil de la savage ? , e cumva 2 mm ?
Hpi Savage X 4.6 RTR
#1202 Useril este offline   Al3xandru239
  • Membru somnambul
  • Postari: 1877
  • Inregistrat: 11-August 08
Postat 20 December 2010 - 12:09 AM
Vezi postareaPrepe, la Dec 19 2010, 10:36 PM, a spus:
Cum 2mm? :unsure: Diametru interior are 3mm ,exterior 5mm,si grosime 2.
Aceasta postare a fost editata de Al3xandru239: 20 December 2010 - 12:17 AM
Associated SC8E on 4S
Membru retras!
#1203 Useril este offline   prisi
  • scale addicted
  • Postari: 1299
  • Inregistrat: 03-January 08
Postat 20 December 2010 - 08:51 AM
Vezi postareajustbart2002, la Dec 19 2010, 03:19 PM, a spus:
Ce dimensiuni ar trebui sa aiba acea piulita?
interior 6 mm si exterior 12 mm
If it is to be it is up to me
#1204 Useril este offline   vgeorge
  • Membru Fondator MDT
  • Postari: 2700
  • Inregistrat: 31-August 09
Postat 21 December 2010 - 11:22 AM
In anotimpul rece, ce bujie sa folosim?rece sau calda?
Racing
-Mugen MBX5T - truggy nitro
-Mugen MBX6 - buggy nitro
-Kyosho MR03 - 1/28 box stock
-GLR racing - 1/28 mod
[center]Club
C.S.T.A. Bucuresti
#1205 Useril este offline   Dan71
  • Postari: 1390
  • Inregistrat: 27-March 08
Postat 21 December 2010 - 04:58 PM
Uite aici ceva sa te ajute.
#1206 Useril este offline   Prepe
  • Postari: 169
Postat 21 December 2010 - 05:04 PM
Vezi postareaAl3xandru239, la Dec 20 2010, 12:09 AM, a spus:
Cum 2mm? :rolleyes: Diametru interior are 3mm ,exterior 5mm,si grosime 2.
Mersi Frumos !
#1207 Useril este offline   prisi
  • scale addicted
  • Postari: 1299
Postat 23 December 2010 - 07:58 PM
o tura mica prin zapada
http://www.youtube.c...h?v=acSO_6Oyijs
#1208 Useril este offline   lamav4
  • Postari: 1133
  • Inregistrat: 19-May 10
Postat 24 December 2010 - 01:17 PM
Vezi postareaAl3xandru239, la Dec 12 2010, 03:22 PM, a spus:
Daca este e-savage o sa ai o teroare.Papa mula baterie ala...iti recomand 2 lipo de 5000mah 25c si un charger turnigy.RToate astea te duc maxim 350lei dar le vei abia dupa sarbatori. Ia 3300mah sau chiar cu amperaj mai mare daca poti ,o sa te dai 5 minute cu alea de 3300...cu 2700 numai zic,mai putin!
- savage 1:10
- doua motoare brushed, face whealy daca ii dau blana
- servo stock
- 27 mhz
- Incarcator pachete Powerjack 6 celule Delta Pro, incarca cu 900 mah pe ora
- 2 acumulatori ansmann Racing-Pack 7,2V 3000 mAh NiMH, noi, doar de doua ori m-am dat cu masina si a tinut de fiecare data cate 40 minute;
Cum de tine 40 minute?, nu trebuia sa tina maxim 5 minute, cel de la care i-am cumparat a zis ca folosea la un savage doi acumulatori lipo de 9000 mah fiecare si il tinea 40 minute; sau tine acum la inceput atat si apoi o sa scada timpul dupa un anumit numar de incarcari-descarcari?
Fan Nokia.
#1209 Useril este offline   elbutchos
  • Postari: 398
  • Inregistrat: 20-January 08
Postat 24 December 2010 - 05:36 PM
Depinde cum te dai cu ea.
Si eu am unul iar cand erau inca bateriile originale in forma tineau si 40 de minute.... depinde de stilul de condus.
Daca esti tot blana cu ea normal ca tin 10 minute acumulatorii, dar daca esti mai finut cu telecomanda te poti bucura multe minute cu un set de acumulatori. :)
Sarbatori fericite la toate lumea.
HPI E-Savage stock.
HPI Savage Flux stock.
#1210 Useril este offline   prisi
  • scale addicted
  • Postari: 1299
Postat 20 January 2011 - 11:12 PM
am reusit sa mai confectionez un sasiu pentru savage,tot low CG,dar model conceput de mine
placa de jos:
  • Imagine atasata: Poza_nr_082_.jpg
Aceasta postare a fost editata de prisi: 20 January 2011 - 11:13 PM
#1211 Useril este offline   gaza07
  • Postari: 107
  • Inregistrat: 04-December 09
Postat 24 January 2011 - 06:22 PM
Salut .
Ieri am fost cu savy-ul putin prin zapada.Cand am ajuns acasa l-am curatat cat de cat.Dupa cateva ore , am observat ca daca pornesc receptorul , servoul de acceleratie/frana se misca singur.Am pus masina la caldura dar nimic , servoul face la fel.
Doar servoul de accel/frana.Cel de la directie nu are nimic.
Ce pot face ?
#1212 Useril este offline   prisi
  • scale addicted
  • Postari: 1299
Postat 24 January 2011 - 07:48 PM
din ce spui tu reiese ca a intrat apa in el.
dasfa-l si usuca motoru si placa,daca nici asa nu da rezultate alt servo...
ieri am vazut pe un forum de afara ca sunt posesori de savage care folosesc pini de fibra de carbon pentru prinderea bratelor de sasiu.
am avut si eu o bagheta de carbon de 4 mm,si am taiat 8 pini,4 scurti si 4 lungi si i-am montat.sa vedem cat or sa tina la uzura,ca si rezistenta sunt absolut sigur ca nu se pot rupe sub nici o forma.
Aceasta postare a fost editata de prisi: 24 January 2011 - 07:51 PM
#1213 Useril este offline   Lev
  • Postari: 187
  • Inregistrat: 06-March 08
Postat 24 January 2011 - 08:19 PM
Poate fi si de la receptor :lol:
Eu am avut 2 probleme cu apa si de fiecare data era de la receptor. E vorba de alt automodel dar nu prea conteaza.
Usuca cu uscatorul de par receptorul si daca nu merge desfa servoul si fa la fel. Receptorul nu trebuie desfacut neaparat, are deschidere la aer destula pe la mufe.
#1214 Useril este offline   gaza07
  • Postari: 107
Postat 24 January 2011 - 09:32 PM
Am pus-o pe calorifer , daca pana maine nu se face bine , trec la metoda spusa de voi .
#1215 Useril este offline   prisi
  • scale addicted
  • Postari: 1299
Postat 28 January 2011 - 03:23 PM
dupa ultimele retusuri,am reusit sa montez sasiul de textolit de 3mm.
am confectionat si traversle care prind puntea de sasiu de aluminiu
  • Imagine atasata: Poza_nr_114_.jpg
Aceasta postare a fost editata de prisi: 28 January 2011 - 03:25 PM
#1216 Useril este offline   prisi
  • scale addicted
  • Postari: 1299
Postat 28 January 2011 - 03:27 PM
  • Imagine atasata: Poza_nr_115_.jpg
  • Imagine atasata: Poza_nr_120_.jpg
  • Imagine atasata: Poza_nr_122_.jpg
#1217 Useril este offline   prisi
  • scale addicted
  • Postari: 1299
Postat 28 January 2011 - 03:30 PM
  • Imagine atasata: Poza_nr_124_.jpg
  • Imagine atasata: Poza_nr_125_.jpg
#1218 Useril este offline   Kitty
  • RC Addict
  • Postari: 4563
  • Inregistrat: 11-July 08
  • Interests:RC,Cars.....
Postat 29 January 2011 - 09:45 AM
a iesit frumoas,dar care e diferenta intre cel conceput de tine si precedentul?am vazut ca formele sunt putin schimbate,insa efectiv ce s-a realizat prin unele modificari?felicitari oricum pt realizare
Axial SCX10.3
Absima Sherpa
Axial Base Camp
#1219 Useril este offline   prisi
  • scale addicted
  • Postari: 1299
Postat 29 January 2011 - 09:47 AM
ms mult de aprecieri.
pai ca si deometrie,e exact la fel,doar am schimbat design-ul,si l-am facut mai putin gaurit,daca pot spune asta.adica am pus accent pe rezistenta in unele puncte.
si cel mai important aspect,e ca am mai mesterit ceva la ea si asta ma face sa ma simt bine :lol:
Aceasta postare a fost editata de prisi: 29 January 2011 - 09:49 AM
#1220 Useril este offline   gaza07
  • Postari: 107
Postat 02 February 2011 - 10:29 PM
Pe savy-ul meu am la directie un sf-5 si la acceleratie/frana am un futaba s3001.
Ce parere aveti?Sunt bune ?
#1221 Useril este offline   Prepe
  • Postari: 169
Postat 03 February 2011 - 01:09 AM
Mie servoul stock mi s-a rupt foarte repede , dar ca putere nu este chiar groaznic . dar totusi merita un upgrade iar eu iti recomand un hitec 645mg pentru directie iar pentru acceleratie blue bird ... 620 , Aceste 2 servouri le folosesc de mult timp si is foarte multumit de ele
#1222 Useril este offline   gaza07
  • Postari: 107
Postat 03 February 2011 - 09:16 AM
Vezi postareaPrepe, la Feb 3 2011, 02:09 AM, a spus:
Prepe , iti multumesc pt sfaturi .Eu am intrebat daca sunt bune cele care le am eu , nu cele stock.
Astept un raspuns.
#1223 Useril este offline   FLUERARU
  • Postari: 613
  • Inregistrat: 27-October 10
Postat 07 March 2011 - 02:39 PM
Salut scuzati bagarea in seama dar imi poate spune si mie cineva de unde se pot cumpara inserti pentru rotile la savage-ul meu ?Gumele sunt noi jentile sunt ok si nu vreau sa dau banii pe alte roti.............sau daca se poate baga altceva in afara de buretele acela care se afla in interiorul cauciucului
am auzit pe la uni pe la alti ca se gasesc camere si inlocuiesti buretele cu camere(ca la automodelele 1/5)................pe altiiiiiiiiiiiiiiiii!!!!!!!!!!!!!!!!! "cica" bag furtun rulat pe janta(ca la bicla noastra cand eram mic si nu aveam bani de camera).......................este adevarat ceva din ce am postat aici sau.............................
multumesc celui care imi raspunde si stima
#1224 Useril este offline   FLUERARU
  • Postari: 613
Postat 10 March 2011 - 08:57 AM
Chiar nu este nimeni sa-mi dea si mie un raspuns?!!!!!!!!!!!!!!!http://www.rhcforum.ro/public/style_emoticons/default/blush.gif................................
#1225 Useril este offline   Dan71
  • Postari: 1390
Postat 10 March 2011 - 09:26 AM
Rotile de la modelele 1/5 si 1/6 NU au camere in general. Sunt tot cu inserti.
#1226 Useril este offline   vice_12_85
  • Postari: 532
  • Inregistrat: 24-January 10
Postat 10 March 2011 - 04:19 PM
da in general toate rotile de 1/5 sunt tot cu insertii dar....eu mi-am luat camera din bricostore(de la raionu de roabe :pardon: )si merge perfect pe goliath.numai ca trebuie sa gauresc janta sa fac loc de valva
~~~~~~AM REVENIT LA PRIMA IUBIRE ~~~~~~~
ADRIAN 074xxxx281
#1227 Useril este offline   elbutchos
  • Postari: 398
Postat 11 March 2011 - 12:36 AM
Salut.
De obicei la automodele se urmareste scaderea greutatii, mai ales la gume care sunt masa rotativa.
Felicitari pentru ideea cu camera de roaba, poate ii da cauciucului un feeling mai real, dar probabil ca 4 camere mai adauga un kilogram pe roti.
Baga si niste poze cand ai timp sa vedem ce a iesit.
HPI E-Savage stock.
#1228 Useril este offline   FLUERARU
  • Postari: 613
Postat 11 March 2011 - 08:09 AM
Dar totusi camerele astea de roaba nu sunt cam mari?sau sunt pe marimi?Eu am vazut o camera de roaba si era cam maricica mult prea mare ptr roata de savage,poate la goliath merge.Imi poti spune(pentru vice) dimensiunea rotii?(sau cum se zice exprimarea corecta)http://www.rhcforum.ro/public/style_emoticons/default/rolleyes.gif? Tu ai spus ca ti-ai luat camera de la brico(pentru vice)..................si...............se potriveste perfect????????????niste poze m-ar ajuta m-ai multhttp://www.rhcforum.ro/public/style_emoticons/default/drinks.gif.multam
#1229 Useril este offline   vice_12_85
  • Postari: 532
Postat 11 March 2011 - 12:28 PM
Vezi postareaFLUERARU, la 11 March 2011 - 08:09 AM, a spus:
eu am luat tot raionu la "puricat"si da am gasit mai multe marimi de camere,cea mai mica este numai buna pt goliath-uri(178x97mm)
ADRIAN 074xxxx281
#1230 Useril este offline   FLUERARU
  • Postari: 613
Postat 11 March 2011 - 02:25 PM
--------------------------Pentru vice-----------------------
Sii daca gasesc camere din acelea care merg pe goliath crezi ca as' putea sa le adaptez pe rotile stok de savage?singura chestie care am putut sa observ este ca daca pun camere pe rotile astea trebe' sa scot valva pe interiorul nu pe exterior ca la masina normala si nu are loc de fuzeta care este aproape cat interiorul jantei.in fine o sa merg sa ma interesez de camere si poate cand pui tu camere ne arati si noua,dar intre timp poate postezi o poza cu camera achizitionata de la brico langa roata(goliath)sa vad asa ca chestie care cun vine.........(intelegi tu........)
multam.
  • 201 Pagini +
  • 39
  • 40
  • 41
  • 42
  • 43
21 useri citesc topicul
