Modelism - RHC Forum: Jurnal de zbor Braila-Galati - Modelism - RHC Forum
  • 283 Pagini +
  • 254
  • 255
  • 256
  • 257
  • 258
Jurnal de zbor Braila-Galati sau Galati-Braila...
#7651 Useril este offline   tantar
  • Postari: 2743
  • Inregistrat: 01-November 08
Postat 02 April 2016 - 07:56 PM
Vezi postareaAinshtain, la 02 April 2016 - 07:49 PM, a spus:
Maine in jur de 11,11-30 la teren...
Radule sa ai bafta , iti tin pumnii stransi .
Trex 700 V BAR
FMS P-51 D MUSTANG 1700 mm
JU- 87 STUKA 1920 mm
A-10 Freewing 1700 mm EDF
FMS F 4U CORSAIR 1700 mm
FW 190 HYPE
Futaba T-8FG x 2
#7652 Useril este offline   Ainshtain
  • Postari: 537
  • Inregistrat: 20-February 14
  • Interests:Aero, navo
Postat 02 April 2016 - 07:59 PM
Mersi frumos, tu nu apari maine, ca deja imi e mila de umarul meu la cate pale o sa dau pana o ia motorul ala si mi-ar fi prins bine un demaror mai vanjos, asta pana imi fac unul.... :)
Stamatin Radu
#7653 Useril este offline   hype
  • Postari: 1280
  • Inregistrat: 05-February 11
Postat 02 April 2016 - 08:28 PM
La Tecuci,eu si Relu prezenti. Se mai baga cineva?
#7654 Useril este offline   tantar
  • Postari: 2743
Postat 02 April 2016 - 09:19 PM
Vezi postareaAinshtain, la 02 April 2016 - 07:59 PM, a spus:
As veni, dar cam lung drumul din Kenya pana acasă.
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7655 Useril este offline   GigiGL
  • Postari: 2107
  • Inregistrat: 10-March 11
  • Interests:Aero
Postat 03 April 2016 - 07:47 AM
La 10 ma intalnesc cu Radu pentru imbarcare. Destinatia VA. Probabil la 11 suntem acolo.
Aceasta postare a fost editata de GigiGL: 03 April 2016 - 07:48 AM
Gigi Sterian
Rascal 1940mm fs.61 nitro
Rascal 120 DLE 30
U Can Do .46 nitro .52, 2T
Beaver 1520
Maule 1500
Helios 2545
#7656 Useril este offline   tantar
  • Postari: 2743
Postat 03 April 2016 - 08:08 AM
Nu uitati sa filmati .
Nici eu nu stau degeaba .
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7657 Useril este offline   victorio
  • Postari: 359
  • Inregistrat: 02-February 10
  • Interests:Aero
Postat 03 April 2016 - 08:59 AM
Vezi postareatantar, la 03 April 2016 - 08:08 AM, a spus:
Tantare pentru atat te duci in Africa
#7658 Useril este offline   victorio
  • Postari: 359
  • Interests:Aero
Postat 03 April 2016 - 09:04 AM
Priveste si tu pe facebuca MODELISM GALATI
#7659 Useril este offline   victorio
  • Postari: 359
  • Interests:Aero
Postat 03 April 2016 - 09:10 AM
TII MINTE https://youtu.be/us0jeJPX8Kk?list=
#7660 Useril este offline   Ainshtain
  • Postari: 537
Postat 03 April 2016 - 02:28 PM
Si a zburat porcusorul meu .... toate bun si frumoase, nu ii place elica de 24, asa ca am zburat cu un 22 cu ~6700 RPM la motor....e puternic voinicu ...trage bine ...si papa mult combustibil ...daca am facut pana prostului, asta e ....rezultat : 6 suruburi de la tren rupte si tobele indoite ....plus o mana de pamant in carburator....se curata se indreapta si se inlocuiesc...
Din pacate camera mea nu a vrut sa filmeze nimic... asa ca daca e cineva care are o poza ...e binevenit sa o posteze ...
Ca si comportament de zbor, ce sa zic ...nu se angajaza de nebun ca piperu, nu urca sau coboara botul la acceleratie ca bixleru, stie sa urce la verticala destul de frumos...ce mai ...zboara nebunie.... numai ca e cam vitezoman, fara flaperoane la aterizare va fi dificil...desi am fact vre-o 2 treceri care erau asa la un metru de sol si se tinea acceptabil...
Centru de greutate trebuie oleaca mai in fata dar am sa mai mut motoru cam 5-6 mm si am sa fac niste distantiere stfel incat sa ii maresc un pic unghiu la motor spre deapta .... la full tindea sa traga spre stanga ....si asa am sa mut si centru mai in fata si am sa inclin si motorul....daca diferenta de inaltime la distantiere e de 1 mm imi da o deviatie de 0.8 grade....el de la fabrica spune sa aiba cca 2 grade inclinatie dreapta... cred ca am sa fac diferenta de inaltime doar de 0.5 mm astfel incat sa pot sa mai pun o saiba daca e nevoie .... sau sa le fac la fel si sa vad dupa .....nu stiu ....inca fierb de la emotiile primului zbor cu un avion benzinar......
MULTUMIRI COLEGILOR CARE M-AU AJUTAT SA IL RIDIC AZI ....data viitoare bagam si fum :drinks:
Stamatin Radu
#7661 Useril este offline   tantar
  • Postari: 2743
Postat 03 April 2016 - 02:58 PM
Vezi postareaAinshtain, la 03 April 2016 - 02:28 PM, a spus:
Bravo frate , am avut emotii .
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7662 Useril este offline   Ainshtain
  • Postari: 537
Postat 03 April 2016 - 03:03 PM
Vezi postareatantar, la 03 April 2016 - 02:58 PM, a spus:
Mie imi zici, imi tremurau degerele de nu piteam sa il controlez.....
Acum sa vad cum indrept tobele, ca una o pot desface si cim zicea Victor, la cald sa o indrept dar cealalta bagi un imbus in ea prin evacuare, dar acum daca e i doita nu am cum.... Poate gasesc sa o sudez daca o dezdoi fortat si se rupe...
Stamatin Radu
#7663 Useril este offline   incepatoru
  • Postari: 2863
  • Inregistrat: 30-May 09
  • Interests:aero
Postat 03 April 2016 - 03:26 PM
.Am avut emotii la decolare.sa vazut ca era greu de coada,bine ca ai compentat cu turatia.si trimaj. dupa aia te-ai distrat cu el..Brava drace..ps uita de soroabele di plastic pune de fer ca tin mai ghine...si data viitoare cand piue statia vi la sol---k
#7664 Useril este offline   Ainshtain
  • Postari: 537
Postat 03 April 2016 - 03:37 PM
Data viitoare... Ce sa fac cu statia? Nu am inteles... :)
Stamatin Radu
#7665 Useril este offline   incepatoru
  • Postari: 2863
  • Interests:aero
Postat 03 April 2016 - 04:55 PM
Vezi postareaAinshtain, la 03 April 2016 - 03:37 PM, a spus:
sa te anunte cand vine..HERCULE-su :good:
#7666 Useril este offline   Glider 1
  • Postari: 150
  • Inregistrat: 09-November 15
  • Interests:aero/automodele
Postat 03 April 2016 - 07:33 PM
si pe la Macin a fost ceva miscare astazi
am invatat sa zboare niste pui de avicola si ceva carnaciori pe la gratar
si am zburatacit si planorul dupa RK
am fost pe langa eoliana
zona excelenta de zbor dar nu pentru cei cu roti, ca sunt multe denivelari
Radio: Taranis X9D Plus
Aero: CX5 & Stark DLG / NineEagles Sky Climber / Voltigeur MK II 3d aerobatic plane 1220mm / S800 Sky Shadow FPV Flying Wing
Auto: LOSI8ight Gas Engine
#7667 Useril este offline   tantar
  • Postari: 2743
Postat 04 April 2016 - 11:01 PM
Vezi postareaGlider 1, la 03 April 2016 - 07:33 PM, a spus:
Tare frumoasa zona , vad in spatele tau un teren destul de drept .
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7668 Useril este offline   Ainshtain
  • Postari: 537
Postat 05 April 2016 - 07:59 AM
http://s28.postimg.org/gq9o6zyeh/20160404_180608.jpg http://s28.postimg.org/3ne1nq86h/20160404_180612.jpg http://s28.postimg.org/d5dsnrtux/20160404_180624.jpg
Indreptate si sudate ... una mai trebuie putin indreptata dar nu as vrea sa ma risc sa nu se rupa mai tare, plus ca nu cred ca va avea ceva probleme in functionalitate
Am desfacut si carburatorul, i-am facut o mica curatire si acum e la scurs... o intrebare... daca as face o piesa din ceva material dur astfel incat sa il scot mai inafara adica sa ii maresc distanta de la motor ca sa pot ajunge la jigloare fara a mai opri motorul....se poate , nu as afecta functionalitatea motorului.....?????
Stamatin Radu
#7669 Useril este offline   Glider 1
  • Postari: 150
Postat 05 April 2016 - 09:51 AM
Vezi postareatantar, la 04 April 2016 - 11:01 PM, a spus:
zona este excelenta, privelistea de asemenea,
dar sunt colturi de pietre presarate peste tot care pot dauna la trenurile de aterizare (-asa cred eu)
mai exista o culme/deal mai departe de unde am stat eu, mai inalta si parea si mai dreapta
am vazut cativa motociclisti pe acolo
nu am fost sa vad cum e acolo dar probabil ca merita incercat
ne organizam odata si exploram daca vreti
#7670 Useril este offline   incepatoru
  • Postari: 2863
  • Interests:aero
Postat 05 April 2016 - 10:48 AM
..pana acuma nu am vazut chestia cu plelungirea 'carburiciului" .poate sa influenteze .pozitiv sau negativ functionarea ..dar mai e varianta...
  • Imagine atasata: DLE60_Header_2.jpg
#7671 Useril este offline   Ainshtain
  • Postari: 537
Postat 05 April 2016 - 10:51 AM
Pai nu am toba cu canistra....si sincer ... pentru un reglaj care vb lu victor pot sa il fac si dand o toba jos ... il pot face....sau mai bine zis " se poate face":blush: ca eu nu ma pricepesc!
Stamatin Radu
#7672 Useril este offline   incepatoru
  • Postari: 2863
  • Interests:aero
Postat 05 April 2016 - 06:53 PM
...flacau.credema la carburici o sa mai umbli.sigur.chiar si daca teoretic ai rodat motoru.dupaia isi da drumu la mers si mai trebuiesc reglaje.nu ramane intepenite jegloarele in pozitia aia nici dupa un an.(vazui la camp cat de nemultumit era nenea al.cu YR-ONE.galbin cu albastru.si are ceva galoane consumate..acuma tu decizi.Valabil si la mine .azi i-am dat gaz dupa 6 luni de conservare si nu mi-a placut "sonoru".trebe gadilat
#7673 Useril este offline   Ciprian97
  • Postari: 3951
Postat 05 April 2016 - 07:18 PM
Cine merge la RR?
#7674 Useril este offline   Glider 1
  • Postari: 150
Postat 06 April 2016 - 12:11 PM
Vezi postareaGlider 1, la 05 April 2016 - 09:51 AM, a spus:
am gasit o fotografie si cu dealul de care iti spuneam
#7675 Useril este offline   tantar
  • Postari: 2743
Postat 08 April 2016 - 11:05 AM
Maine se iese ?
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7676 Useril este offline   victorio
  • Postari: 359
  • Interests:Aero
Postat 08 April 2016 - 11:44 AM
Ce facem maine? ne zburatacim!
#7677 Useril este offline   victorio
  • Postari: 359
  • Interests:Aero
Postat 08 April 2016 - 11:48 AM
Vezi postareatantar, la 08 April 2016 - 11:05 AM, a spus:
Maine se iese ?
Ai venit din kenya?
Aceasta postare a fost editata de victorio: 08 April 2016 - 11:49 AM
#7678 Useril este offline   tantar
  • Postari: 2743
Postat 08 April 2016 - 04:37 PM
Daaaaaaa
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7679 Useril este offline   Ainshtain
  • Postari: 537
Postat 08 April 2016 - 05:00 PM
Mai ca as veni si eu, sa vad daca fac garnituri si pun tobele in timp util.... Si mai ales cum e vremea...
Stamatin Radu
#7680 Useril este offline   tantar
  • Postari: 2743
Postat 08 April 2016 - 08:15 PM
Eu m'am apucat de incarcat bateriile
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
  • 283 Pagini +
  • 254
  • 255
  • 256
  • 257
  • 258
19 useri citesc topicul
