Modelism - RHC Forum: Jurnal de zbor Braila-Galati - Modelism - RHC Forum
  • 283 Pagini +
  • 124
  • 125
  • 126
  • 127
  • 128
Jurnal de zbor Braila-Galati sau Galati-Braila...
#3751 Useril este offline   incepatoru
  • Postari: 2862
  • Inregistrat: 30-May 09
  • Interests:aero
Postat 19 January 2013 - 04:54 PM
..BINE ma MIHAI asa sa fie DAR cum impart io 3 suluri la 2 :pardon: ca la 3min dupa POSTARE o sunat BATMANU" di MAREAN ..co vrea el..
#3752 Useril este offline   hype
  • Postari: 1280
  • Inregistrat: 05-February 11
Postat 20 January 2013 - 11:53 AM
Vezi postareatantar, la 19 January 2013 - 01:51 PM, a spus:
O iau eu mancati'as
Batman,batman,totusi???
Credeam ca sunt in depozit la materiale de constructii,io cautam jurnalul de zbor :shok:
Sina de cale ferata, ai bai vre-o 24,32km?
#3753 Useril este offline   tantar
  • Postari: 2743
  • Inregistrat: 01-November 08
Postat 21 January 2013 - 08:15 PM
De azi
http://youtu.be/GJ6J7txIR6A
Trex 700 V BAR
FMS P-51 D MUSTANG 1700 mm
JU- 87 STUKA 1920 mm
A-10 Freewing 1700 mm EDF
FMS F 4U CORSAIR 1700 mm
FW 190 HYPE
Futaba T-8FG x 2
#3754 Useril este offline   incepatoru
  • Postari: 2862
  • Interests:aero
Postat 21 January 2013 - 08:36 PM
canalizarea ..canalizarea ..unde-i bree CAPACIU. :excl: ..ha sooper..mai trebe oleaca di veteaza .restu e oki doki...roger :db: (pi" romaneste BLANA ...huoooooooooooooooo)
#3755 Useril este offline   adi elicopter gl
  • Postari: 1171
  • Inregistrat: 07-March 09
Postat 21 January 2013 - 09:57 PM
Vezi postareatantar, la 21 January 2013 - 08:15 PM, a spus:
ba tintare da ma un și tu un telefon când mai ieși!!!!!!!!!!!!!!!!!!!!!!!
www.fotofilmaerian.ro
#3756 Useril este offline   tantar
  • Postari: 2743
Postat 22 January 2013 - 08:29 AM
Vezi postareaincepatoru, la 21 January 2013 - 08:36 PM, a spus:
Nu frate viteza era buna dar mi s-aa intors rotile si a capotat ca un nebun
Vezi postareaadi elicopter gl, la 21 January 2013 - 09:57 PM, a spus:
A fost incognito'
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#3757 Useril este offline   incepatoru
  • Postari: 2862
  • Interests:aero
Postat 22 January 2013 - 08:47 PM
Din ciclul..ce avem noi aici.ups (gasi pi iutubee) :good: ...vocile din funda-l las marmotele ..sa zica :db:
#3758 Useril este offline   dan1972
  • Postari: 1453
  • Inregistrat: 03-December 11
Postat 23 January 2013 - 05:26 AM
A inviat din morti ZERO-ul !!! :yahoo: Credeam ca ai renuntat la el...
...Bre nenea...dar de ce zboara asa de turbilitic ?!?...Vezi sa nu aiba vre-o suprafatza de control slabita !!!...Sau sa nu fie ceva pozitionat/lipit stramb pe el...ca nu zboara cum trebuie...E turbat rau!!!...Sau poate CG-ul...Verifica daca aripa e asezata drept fatza de coada si de profundor
Verifica vizual daca profundorul e paralel cu aripa (privind din spate
Verifica sa nu fie slabit (moale) polistirenul, in zona de prindere a ampenajelor (cum am patit eu la ME 109)...sau daca tijele de comanda functioneaza OK...
Eventual micsoreaza-i cursele cu Dual Rate sau Exponential...daca totul e drept pe el...
....Daca a fost trantit, rupt si lipit, vezi sa nu fie unghiul de incidentza al profundorului aiurea...
Oricum...arata intr-un mare fel in aer!!!...
Nu stiu de ce am impresia ca modelele din EPO sant mult mai rezistente la tavaleala si mai indicate pt. zborul atunci cand nu ai prea mult timp...ajungi intamplator la camp...conditiile meteo sant ciudate...etc...
...Un model din EPO...il mai lipesti...il mai bagi in apa fierbinte.....pana la urma tot zboara....:-)...La un "balsa" repari o luna dupa un incident de zbor!!!
....Observ ca pana si cei care au mai multe modele termice, pana la urma tot cu cate un planor din EPO...o aripa construita artizanal din polistiren...un EasyStar...etc....zboara....Celelalte zboara putin si rar...
....Sigur...merita sa ai si termice...asaaaa...pt. satisfacerea virusului...dar se pare ca elecricele din polistiren raman de baza...
Messersmitt ME 109 G - Parkzone - 1100mm
Magister-MULTIPLEX - 1630mm
Ryan NY-P - 1600mm
Piper Cub J3- 2310 mm - 28cc benzina
Diamond 1800mm
P40-Warhawk mini (645mm)
W-Fly-Flaspeed 2,4 GHz
#3759 Useril este offline   dan1972
  • Postari: 1453
Postat 23 January 2013 - 05:43 AM
Referitor la aterizare...Am remarcat ca warbird-urile pot fi aterizate cu brio de fiecare data in urmatorul mod:
- Dupa ultimul viraj, cand e pe directia pistei (dar sus si relativ aproape)...il lasi sa coboare pe o panta pronuntata pana la nivelul soluilui (la 60...80 cm) dupa care il lasi sa piarda viteza, tinand-ul in zbor paralel cu solul...Vei observa ca aterizeaza extrem de bine!!! Daca inainte de a atinge solul mai turezi putin motorul si tragi de profundor usor in sus, va ateriza si mai lin!
...Coborandu-l pe o panta pronuntata...de aproape, se mentine viteza de zbor exact in zona periculoasa (cat e inca la 2....4m inaltime) si unde nu prea ai ce sa-i mai faci daca o ia razna...
...Aterizeaza bine asa, pt. ca Warbird-urile nu zboara bine la viteza mica...Ori daca vii pe o panta prea lina, tot timpul va exista riscul sa se angajeze, sau sa o balbai...sa faci salturi in aer...
Ori daca asta se intampla la 60 cm de sol, chiar nu se mai intampla nimic rau...
Am fost placut surprins de cat de bine vine ME-ul la aterizare atunci cand il las sa coboare abrupt...
...Iar daca o sa-i faci flapsuri (doua pe un servo mic...in cazul lui ZERO) vei vedea ca aterizeaza de 1000 de ori mai bine!!! Chiar merita munca...cand ai chef de mestereala!!! Va fi o experientza noua...
Ryan NY-P - 1600mm
Diamond 1800mm
#3760 Useril este offline   hype
  • Postari: 1280
Postat 24 January 2013 - 07:35 PM
Frumos,Mihai.Am impresia ca ai venit cam tare la aterizare sub un unghi cam abrut.Incearca sa redresezi la rasul solului cu motor de portanta si trage putin de coada.Asta te va frana.Pentru un specialist in ventilatoare,o dai bine zau.Eu acum, exersez electricele,ma rog la pazitorul zburatorilor sa nu ma tina prea mult necesitatea. :good: :good:
#3761 Useril este offline   hype
  • Postari: 1280
Postat 24 January 2013 - 07:41 PM
Dane,sunt de acord cu tine,e mai bine ca la simulator.Termicul ramane termic,ramane la inima mea,chiar daca am inima ca toate carutele. :drinks:
#3762 Useril este offline   tantar
  • Postari: 2743
Postat 24 January 2013 - 08:47 PM
Dan , Hype ..
Nu frate modelul zboara bine , cand l-am ridicat nu era trimat , dupa a zburat cum trebuie , la aterizare am venit repede pt ca ... sincer ma manca nasul .
Aterizatul pe camp din orice directie este total deferit de aterizatul pe o pista ingusta la care vantul bate din alta directie decat lungul pistei (si vantul batea destul de tare ), beleaua a fost ca mi s-au inchis rotile si normal ca a capotat .
Nu mai fiti voi asa carcotasi si veniti la ANL sa va vad cum aterizati .
Aceasta postare a fost editata de tantar: 24 January 2013 - 08:49 PM
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#3763 Useril este offline   alex g
  • Postari: 619
  • Inregistrat: 16-April 11
Postat 24 January 2013 - 10:23 PM
Vezi postareatantar, la 24 January 2013 - 08:47 PM, a spus:
Salutare, cu acest cosmar,( aterizari pe pista ingusta, de cele mai multe ori cu vant din directii diferite fata de lungul pistei) ma confrunt si eu, dar dupa 2 ani de incercari si perseverenta, am inceput sa ma descurc.....mai mult sau mai putin bine :pardon:
Daca n-ar fi stalpu'.....:wacko:
Un scurt video cu pista si cu stalpu'...
http://www.youtube.c...h?v=5OrMivcsCeA
Spor si aterizari line tuturor.
Aceasta postare a fost editata de alex g: 24 January 2013 - 10:23 PM
Alex G:
SCOUT MX2
CESSNA 182, 1,87m
PIPER SUPER CUB, PICO CUB
WING-TIGER
#3764 Useril este offline   tantar
  • Postari: 2743
Postat 25 January 2013 - 08:20 PM
Vezi postareaalex g, la 24 January 2013 - 10:23 PM, a spus:
Chiar ca ai ...ratat stalpul
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#3765 Useril este offline   alex g
  • Postari: 619
Postat 25 January 2013 - 08:39 PM
Vezi postareatantar, la 25 January 2013 - 08:20 PM, a spus:
Da..
:clapping:
Mai lipseau cativa cm si ar fi fost cel mai teribil crash fara sa fie de vina electronica de pe model :pardon:.
Totusi din cauza pistei care este destul de dificila, am invatat o chestie foarte importanta: daca consider ca modelul nu va avea o aterizare cat de cat decenta, il ridic si mai incerc o data si daca e nevoie mai fac o tura..... Ajuta foarte mult mai ales pe vant. Un rol foarte important il au si flaps-urile, mai ales la modelul din clip; scad viteza modelului si permit corectii de traiectorie pe care inainte nu aveam timp sa le fac si reduc mult si distanta de rulare pe sol.
Stima si numai bine.:good:
Alex G:
SCOUT MX2
CESSNA 182, 1,87m
WING-TIGER
#3766 Useril este offline   incepatoru
  • Postari: 2862
  • Interests:aero
Postat 25 January 2013 - 09:34 PM
mmdaaa fata de alti.. :db: ..vorba aia STALPUUUU BAAA(defapt era ..sarmaaaaaa.HO)...PLICI..
#3767 Useril este offline   Ionutz_c
  • Postari: 155
  • Inregistrat: 22-February 08
Postat 26 January 2013 - 08:26 PM
Buna seara domnilor! vreo doua quartz-uri pentru 40 mhz are careva sa fac o proba la o statie?
#3768 Useril este offline   dan1972
  • Postari: 1453
Postat 27 January 2013 - 07:24 AM
Dan , Hype ..
Aaaa! OK! L-am vazut ca zboara mai turbilitic si nu am stiut ca nu e trimat...Sorry!...Si-apoi daca nu ar fi si carcotasi pe aici ce-am face la vremea asta, cand ninsoarea si frigul nu ne dau pace ?!? :-)
....Stiu cum e cu pista cu borduri, unde de cele mai multe ori vii cu vantul din lateral...Ti-am zis ca si eu am incercat "sportul" asta la ANL-uri la noi...si e criminal!!!...Am dat de vre-o 2 ori cu Cessna de asfalt de am zis ca se imprastie...e aiurea rau!
....Venim la ANL, daca dai si tu un telefon din timp...
Uita-te la asta...E cu dedicatie pt. tine!!! B) Uita-te cu atentie la descrierea avionului!!!...Are sistem de tractiune vectorial....flapsuri si in bordul de fuga si in cel de atac...parasuta pt. franare dupa aterizare...doua EDF-uri de 70mm...E belea!!!
Ryan NY-P - 1600mm
Diamond 1800mm
#3769 Useril este offline   dan1972
  • Postari: 1453
Postat 27 January 2013 - 07:36 AM
Evident...Cessna 182 zboara superb!!!
...Mama-Mama ce-ai ratat...stalpul!!! :ph34r: ....Pista aia chiar e pozitionata aiurea in raport cu stalpul ala!!!
...Credeam ca doar eu incerc sa zbor printre stalpii de iluminat... :rofl:
...La Cessna pune-i capota motorului si papucii rotilor cu rotile originale!!!...E mult mai vitezoman si aluneca muuult mai frumos prin aer...Am avut si eu o Cessna de ArtTech...Daca pui papucii originali pe roti, rotile originale sant suficient de mari ca sa decoleze si din iarba!!! Avand papucii pe roti, nu se mai propteste in orice denivelare, e si mai aerodinamic si nici nu o ingreunezi inutil...
Avionul ala zboara cel mai bine cu acumulatori de 2200 mAh (nu cu 2400...sau 2650 cum am zburat eu o vreme)...Scoate-i ESC-ul langa motor (in stanga lui) pt. ca in compartimentul bateriei se cam incinge (vara)...
Zboruri reusite!
Ryan NY-P - 1600mm
Diamond 1800mm
#3770 Useril este offline   dan1972
  • Postari: 1453
Postat 27 January 2013 - 07:48 AM
Vezi postareahype, la 24 January 2013 - 07:41 PM, a spus:
Si am mai observat o chestie interesanta la electrice...Pt. ca motoarele electrice au cuplu constant si mare la orice turatie, un model electric pleaca muuult mai bine decat un termic... Am impresia ca de cele mai multe ori electricele sant supramotorizate in raport cu greutatea...In contrapartida, am vazut multe termice care "o cam balbaie" daca reduci prea mult vitea...pana prind iar viteza...
...In schimb ce-mi place la termice....zbori frate de te plictisesti pana termini zeama!!!....La electrice dai cateva ture si gata "bacteria"...Tot timpul stai cu stress ca daca il fugaresti prea tare se termina curentul cand te astepti mai putin...
E clar!!! Termicele sant de mare efect, chiar daca sant mai dificil de zburat!!!
Promit ca la primavara sa apar la camp cu ceva frumos!!! B)
Ryan NY-P - 1600mm
Diamond 1800mm
#3771 Useril este offline   dan1972
  • Postari: 1453
Postat 27 January 2013 - 07:55 AM
@Tantar - Nu cred ca mai dau ME 109 pt. ca nu mai e o urgentza...Acum sant cu ochii dupa un Mustang de 1600 mm...Inca nu sant hotarat daca va fi EPO electric sau balsa-termic...Am un motor de 7,5cc si ma gandeam sa-i gasesc o utilizare...ori pe un Mustang, ori pe un Decathlon 46...Ma gandesc totusi sa nu sar peste anumite etape...
...Ma tenteaza si un planor de 1800...2500 mm...Sa vedem ce se concretizeaza... :rolleyes:
Ryan NY-P - 1600mm
Diamond 1800mm
#3772 Useril este offline   tantar
  • Postari: 2743
Postat 27 January 2013 - 08:47 AM
Vezi postareadan1972, la 27 January 2013 - 07:55 AM, a spus:
Daca iti iei Mustang din EPO .... da'neamtul' pt.ca nu o sa il mai zbori , daca iei balasa la 1600 7,5 este cam mic motorul .
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#3773 Useril este offline   tantar
  • Postari: 2743
Postat 27 January 2013 - 08:54 AM
Vezi postareadan1972, la 27 January 2013 - 07:24 AM, a spus:
Hei DANE cum sa ma supar ,,
Am si eu ceva in pregatire , tot cu 2 EDF'uri si thrust-vectoring si cu o unitate 3 G ,proiect secret , deocamdata.
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#3774 Useril este offline   alex g
  • Postari: 619
Postat 27 January 2013 - 01:03 PM
Vezi postareadan1972, la 27 January 2013 - 07:36 AM, a spus:
Zboruri reusite!
Bun gasit, pista asa cum se vede, este singura varianta posibila din pacate, am cercetat toata zona si nu am gasit teren mai neted. :wacko:
Capota din pacate si-a dat "demisia" in vreo 10 bucati toamna trecuta in urma unui crash teribil un urma caruia nu credeam ca Cessna va mai zbura vreo data: aripile rupte, capota franjuri, panuol de foc cu batiul si suportul jambei facute aschii, fuselajul rupt in dreptul geamurilor..... Pana la urma am resuscitat-o, dar capota n-a mai avut nici o sansa...
Rotile de pe trenul principal sunt cale originale, (de 65mm), dar acum au amortizoare:Imagine atasata: IMG_4466.JPGImagine atasata: IMG_4467.JPG
Jamba fata este facuta de mine, are o roata de 70 mm:Imagine atasata: IMG_5594.JPG
Papuceii rotilor sunt din polistiren, si nu i-am pus din cauza amortizoarelor. Pista este mai degraba buna pentru offroad decat pentru aeromodele dar alta nu am :wacko: Inainte de a face amortizoarele am rupt de vreo 2 ori jamba si suportul ei si era cat pe ce sa rup si suportul trenului principal... Acum ruleaza super :good:
Acum legat de baterie......cred ca se face o confuzie....modelul are 1,9m anvergura si vreo 2750g :pardon: . Bateria este 4S 3300mAh 25C, ( cea originala) si 4S 3200mAh 50C cea noua.
ESC-ul a fost montat din prima pe batiu, si tot acolo am prins si UBEC-ul de 6A. Cel din ESC-ul original a cauzat cele 4 crash-uri cand modelul a ramas fara control in zbor.
Acum fara capota au aer din plin Poate am sa reusesc sa-i fac o alta capota, dar nu am nici o idee valabila deocamdata....
Stima.
Alex G:
SCOUT MX2
CESSNA 182, 1,87m
WING-TIGER
#3775 Useril este offline   tantar
  • Postari: 2743
Postat 27 January 2013 - 08:14 PM
Dan uite aici :
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#3776 Useril este offline   alex g
  • Postari: 619
Postat 27 January 2013 - 09:10 PM
Vezi postareatantar, la 27 January 2013 - 08:14 PM, a spus:
:clapping:Fara cuvinte, adevarate bijuterii.:good:
Am o nelamurire: pe la minutul 4 00 pana la min 4:13 este bombardierul care decoleaza cam abrupt zic eu, dar nu am inteles care a fost faza cu aterizarea :ph34r: Nu-mi dau seama prea bine, s-au oprit motoarele?
Alex G:
SCOUT MX2
CESSNA 182, 1,87m
WING-TIGER
#3777 Useril este offline   hype
  • Postari: 1280
Postat 28 January 2013 - 01:11 PM
Vezi postareadan1972, la 27 January 2013 - 07:48 AM, a spus:
Uite Dane cine asteapta primavara. Imagine atasata: Fotografie-0012.jpgImagine atasata: Fotografie-0013.jpg
#3778 Useril este offline   adi elicopter gl
  • Postari: 1171
Postat 29 January 2013 - 11:11 PM
Vezi postareahype, la 28 January 2013 - 01:11 PM, a spus:
Uite Dane cine asteapta primavara. Atasament Fotografie-0012.jpgAtasament Fotografie-0013.jpg
esti marfa lulu cu caricoplanul ala
sincer si acum regret ca l am dat pe al meu
#3779 Useril este offline   hype
  • Postari: 1280
Postat 30 January 2013 - 08:55 AM
Vezi postareaadi elicopter gl, la 29 January 2013 - 11:11 PM, a spus:
Multumesc Ady.Stiam de cand ai trecut la nivelul superior ca va ramane in sistem un craculet din vechiul virus.Am trei receptori care au decedat,tu ai un amic care se pricepe.Ce zici,mai pot fi resuscitati?Duminica am pornit Top-ul,motorul ma unge pe suflet.Clocesc doua schiuri. :drinks:
#3780 Useril este offline   adi elicopter gl
  • Postari: 1171
Postat 01 February 2013 - 11:11 PM
Vezi postareahype, la 30 January 2013 - 08:55 AM, a spus:
sincer nu te sfătuiesc sa le repari doar stii povestea cu top starul ala, dacă insiști eu le trimit eba se numește dar după cum spuneam anterior e cea delicata treaba și dacă nu ești 100% ca e ok apar altele.............
iese careva duminica la un zbor?
  • 283 Pagini +
  • 124
  • 125
  • 126
  • 127
  • 128
63 useri citesc topicul
0 membri, 63 vizitatori, 0 utilizatori anonimi
