Modelism - RHC Forum: Graupner Yak-54 - Modelism - RHC Forum
  • 16 Pagini +
Graupner Yak-54 cu OS Max 120 AX
#1 Useril este offline   Romulus
  • Postari: 1190
  • Inregistrat: 02-June 08
Postat 21 October 2008 - 12:00 PM
Date tehnice:
Wingspan approx. 1620 mm
Overall length excl. spinner approx. 1430 mm
Wing area approx. 49 dm²
Tailplane area approx. 12 dm²
Total surface area approx. 61 dm²
All-up weight according to fittings approx. 3600 g
Longitudinal dihedral 0 to + 0.5º
Centre of Gravity approx. 120 mm aft of the root leading edge
Graupner Yak-54 cu OS MAX 120 AX (pagina producator)
Manual de asamblare - DE - pdf 319 Kb
Manual de asamblare - EN - pdf 81 Kb
RCMW - Test Report - pdf 2,18 Mb
#2 Useril este offline   Romulus
  • Postari: 1190
Postat 21 October 2008 - 12:24 PM
Si cateva poze...
Fisier atasat  IMG_0315_small.jpg (103.43K)
Number of downloads: 3916 Fisier atasat  IMG_0317_small.jpg (108.76K)
Number of downloads: 3648 Fisier atasat  IMG_0318_small.jpg (77.26K)
Fisier atasat  IMG_0314_small.jpg (94.15K)
Number of downloads: 2867 Fisier atasat  IMG_0311_small.jpg (106.62K)
#3 Useril este offline   florin100%
  • Postari: 2685
  • Inregistrat: 20-June 06
Postat 21 October 2008 - 02:31 PM
Ba te sparg ai zis ca te potolesti...
Team Aeropower
#4 Useril este offline   Romulus
  • Postari: 1190
Postat 21 October 2008 - 02:32 PM
Stai sa vezi ce Extreme Flight cu benzina vine... http://www.rhcforum....tyle_emoticons/default/tongue.gif
#5 Useril este offline   ARU
  • Postari: 1427
  • Inregistrat: 15-February 08
  • Interests:aero
Postat 23 October 2008 - 11:53 PM
...cat mai multe zboruri fara incidente si sa-l stapanesti sanatos !
#6 Useril este offline   Rontaila
  • Postari: 324
  • Inregistrat: 29-May 07
  • Interests:Tot ce zboara cu motor sau se scufunda in mare
Postat 24 October 2008 - 07:48 AM
Vezi postareaRomulus, la Oct 21 2008, 03:32 PM, a spus:
Stai sa vezi ce Extreme Flight cu benzina vine... :)
Sa vorbesc la utilitare cu vanzatorii pentru un CRAFTER ? :)
Primul sosit ,ultimul plecat..
#7 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
  • Inregistrat: 03-February 07
  • Interests:AEROMODELISM
Postat 07 January 2009 - 12:13 AM
Romulus!...cum ti-au venit parghile de control din kit?ataseaza o poza cu ele ....daca :) se poate .
ADOR VITEZA!!!
#8 Useril este offline   Romulus
  • Postari: 1190
Postat 07 January 2009 - 12:28 AM
Al meu e gata asamblat, dar sunt convins ca sunt ca ale tale. Am verificat si in alt kit si erau la fel, in mod cert diferit de instructiuni. Poze in 10 minute.
#9 Useril este offline   Romulus
  • Postari: 1190
Postat 07 January 2009 - 12:39 AM
Eu le-am descalcit cu ajutorul lui ZOD si Kriminel...
Fisier atasat  IMG_1596_small.jpg (59.65K)
Number of downloads: 249 Fisier atasat  IMG_1602_small.jpg (56.99K)
Number of downloads: 344 Fisier atasat  IMG_1597_small.jpg (48.17K)
#10 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 07 January 2009 - 12:48 AM
ok ..multumesc frumos ! ...asa este si la mine :)
si eu intre timp am apelat la Kriminel! pt siguranta! ..
multumesc inca o data ..
ADOR VITEZA!!!
#11 Useril este offline   Romulus
  • Postari: 1190
Postat 07 January 2009 - 07:02 PM
Inteleg ca sunt 4 membri pe forum care au asa un model cu OS MAX 120 AX. Super frumos.
#12 Useril este offline   Romulus
  • Postari: 1190
Postat 07 January 2009 - 07:11 PM
Aici un film cu acest model, motorizat cu un ASP 180 4T.
http://www.youtube.c...h?v=nDPXCEpLZKk
#13 Useril este offline   ave
  • Postari: 1010
  • Inregistrat: 13-December 07
Postat 07 January 2009 - 07:30 PM
Vezi postareaRomulus, la Jan 7 2009, 07:02 PM, a spus:
Gresit, sunt doar trei reali (care si au aparatele). Zilele urmatoare vor fi intr-adevar patru (momentan al patrulea este doar comandat si platit...).
Ave
#14 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 08 January 2009 - 12:14 PM
Cu acordul lui ROMULUS ! ...ca sa nu mai incep alt subiect ,am sa incerc sa fac eu un review la acest avion .
ADOR VITEZA!!!
#15 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 08 January 2009 - 12:18 PM
ROMULUS ....poate ma vei ajuta putin cu poze si de la modelul tau care deja vad ca l-ai asamblat . :)
ADOR VITEZA!!!
#16 Useril este offline   Romulus
  • Postari: 1190
Postat 08 January 2009 - 12:21 PM
Nu inteleg. Sa te ajut pe tine? In ce sens? Eu ma ajut pe mine si pe restul. Tu la fel. Cum te ajut pe tine? Eu am poze din fiecare etapa de constructie, doar ca inca nu le-am pus. Le vine vremea si lor...
#17 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 08 January 2009 - 12:22 PM
pai tocmai la asta m-am referit ..poze cu etapele constructiei .! :)
ADOR VITEZA!!!
#18 Useril este offline   Romulus
  • Postari: 1190
Postat 08 January 2009 - 12:24 PM
Pai tu vrei sa faci review la fel ca mine. Cum te ajut eu cu poze? Ce ai cerut am pus deja. Nu cred ca mai am ce...
#19 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 08 January 2009 - 12:34 PM
Romulus ...parca ai fi copil :) ...ideea este sa postam despre acest model cat mai mult pt ca alti ,care ar dori sa-l achizitioneze sa stie ce au de facut . .Dar daca te deranjeaza acest fapt ma retrag din review tau ! ...cu scuzele de rigoare .Eu ti-am cerut acceptul daca pot sa postez si alaturi de mine sa postezi si tu despre modelul tau .Nimic mai simplu .
ADOR VITEZA!!!
#20 Useril este offline   Romulus
  • Postari: 1190
Postat 08 January 2009 - 12:46 PM
Turok, nu trebuie sa-mi cer permisiunea. Oricine e binevenit sa posteze in orice topic de-al meu. Faceam referire la faptul ca tu ai spus, hai sa facem un review, dar topicul era deja despre asta. Poate vroiai sa spui ca faci si tu un review in paralel, ceea ce e binevenit. Dar la postul urmator, ma rogi sa te ajut cu poze sa-ti faci review-ul? Pai nu mai inteleg nimic. Review-ul il facem pentru cei care nu au modelul, pe ei ii ajutam. La asta faceam referire.
Si da, sunt copil si din anumite puncte de vedere, voi ramane asa cat voi trai, dar cu siguranta nu in felul in care o spui tu. Spor la review.
#21 Useril este offline   MADA
  • Postari: 987
  • Inregistrat: 09-August 04
Postat 08 January 2009 - 01:35 PM
Turok eu zic ca un review se face ca sa prezinti un model din punct de vedere al realizarii acestuia de catre producator cu punctele bune si cele slabe, nicidecum ca sa stie cei care il cumpara ce au de facut...Ca daca ajungi sa cumperi un model de genul asta si nu stii ce ai de facut...e pacat de banii dati pe el.
Daca Romulus a deschis un review la modelul asta parerea mea este ca era normal sa il prezinte el pana la capat; si nu stiu cui i-ar folosi sa mai deschizi un subiect in paralel pe aceeasi tema...pentru ca s-ar prezenta fix acelasi model!
#22 Useril este offline   gicosu
  • Postari: 1849
  • Inregistrat: 08-May 03
Postat 08 January 2009 - 01:44 PM
Da,dar poate Turok face ceva diferit la model fata de Romulus!
#23 Useril este offline   yr-zbg
  • Postari: 1128
  • Inregistrat: 25-November 08
  • Interests:Aviatia
Postat 08 January 2009 - 02:36 PM
Imi spun si eu parerea....
Atata timp cat e vorba de acelasi model...consider ca topicul nu este al cui l-a deschis ci al modelului. Cu cat se prezinta mai multe kit-uri cu atat vor fi acoperite mai multe probleme ce pot aparea la montaj. Iar daca unu face ceva diferit....foarte bine...abia vor stii ceilalti daca e o idee buna sau nu sa faca si ei acea modificare.
ps. cam asta am facut si eu cu Decathlon-ul meu...am scris in kit review unde era deja deschis subiectul. Unele dintre problemele mele le-au avut si ceilalti ...altele nu. Acum si fretemiu are decathlon-ul si din cate am vazut...mai exista si alte probleme neatinse inca.
Stima.
Pacat ca Slz nu zboara.
#24 Useril este offline   MADA
  • Postari: 987
Postat 08 January 2009 - 02:51 PM
Vezi postareayr-zbg, la Jan 8 2009, 02:36 PM, a spus:
Crezi? Mie mi s-a parut ca Turok vroia sa faca review la modelul ala cu pozele facute de Romulus pe modelul (ghici???) tot al lui Romulus. Care inteleg ca este deja construit.
De aceea am si spus ca e normal sa-l duca Romulus pana la capat.
Dar poate ca doar mi s-a parut.....
Aceasta postare a fost editata de MADA: 08 January 2009 - 02:54 PM
#25 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 08 January 2009 - 08:40 PM
Mada ....atata timp cat deschizi un topic , este normal sa pui si poze despre etapele parcurse ( cel putin asa consider eu ) ...in fond si definitiv aici prezentam un model! cu partile lui bune si partile mai putin bune ! Se pare ca am fost inteles cu totul si cu totul gresit .
ADOR VITEZA!!!
#26 Useril este offline   Romulus
  • Postari: 1190
Postat 10 January 2009 - 04:17 AM
Am montat pe model 5 servo DS 8411 BB, MG de la Graupner, pentru suprafetele de comanda si un servo digital S3151 de la Futaba pentru acceleratie.
Pentru receptie am folosit un regulator cu switch magnetic incorporat DPSI Micro MPS RV de la Emcotec alimentat de un LiPo de 1.500 mAh.
Nu am cantarit inca modelul dar am s-o fac cat de repede pot.
#27 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 11 January 2009 - 08:25 PM
ADOR VITEZA!!!
#28 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 11 January 2009 - 08:30 PM
ADOR VITEZA!!!
#29 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 11 January 2009 - 08:31 PM
ADOR VITEZA!!!
#30 Useril este offline   ave
  • Postari: 1010
Postat 11 January 2009 - 08:39 PM
Vezi ca motanul ala abia asteapta sa-i faci niste poze, uita-te la moaca lui... :(
Ave
  • 16 Pagini +
14 useri citesc topicul
