Graupner Yak-54 cu OS Max 120 AX
Postat 21 October 2008 - 12:00 PM
Wingspan approx. 1620 mm
Overall length excl. spinner approx. 1430 mm
Wing area approx. 49 dm²
Tailplane area approx. 12 dm²
Total surface area approx. 61 dm²
All-up weight according to fittings approx. 3600 g
Longitudinal dihedral 0 to + 0.5º
Centre of Gravity approx. 120 mm aft of the root leading edge
Graupner Yak-54 cu OS MAX 120 AX (pagina producator)
Manual de asamblare - DE - pdf 319 Kb
Manual de asamblare - EN - pdf 81 Kb
RCMW - Test Report - pdf 2,18 Mb
Postat 21 October 2008 - 12:24 PM
Number of downloads: 3916 IMG_0317_small.jpg (108.76K)
Number of downloads: 3648 IMG_0318_small.jpg (77.26K)
Number of downloads: 2867 IMG_0311_small.jpg (106.62K)
Postat 21 October 2008 - 02:31 PM
Postat 21 October 2008 - 02:32 PM
Postat 23 October 2008 - 11:53 PM
Postat 24 October 2008 - 07:48 AM
Romulus, la Oct 21 2008, 03:32 PM, a spus:
Sa vorbesc la utilitare cu vanzatorii pentru un CRAFTER ? :)
Postat 07 January 2009 - 12:13 AM
Postat 07 January 2009 - 12:28 AM
Postat 07 January 2009 - 12:39 AM
Number of downloads: 249 IMG_1602_small.jpg (56.99K)
Number of downloads: 344 IMG_1597_small.jpg (48.17K)
Postat 07 January 2009 - 12:48 AM
si eu intre timp am apelat la Kriminel! pt siguranta! ..
multumesc inca o data ..
#11
Postat 07 January 2009 - 07:02 PM
#13
Postat 07 January 2009 - 07:30 PM
Romulus, la Jan 7 2009, 07:02 PM, a spus:
Gresit, sunt doar trei reali (care si au aparatele). Zilele urmatoare vor fi intr-adevar patru (momentan al patrulea este doar comandat si platit...).
#14
Postat 08 January 2009 - 12:14 PM
Number of downloads: 216 -
#15
Postat 08 January 2009 - 12:18 PM
#16
Postat 08 January 2009 - 12:21 PM
#17
Postat 08 January 2009 - 12:22 PM
#18
Postat 08 January 2009 - 12:24 PM
#19
Postat 08 January 2009 - 12:34 PM
#20
Postat 08 January 2009 - 12:46 PM
Si da, sunt copil si din anumite puncte de vedere, voi ramane asa cat voi trai, dar cu siguranta nu in felul in care o spui tu. Spor la review.
#21
Postat 08 January 2009 - 01:35 PM
Daca Romulus a deschis un review la modelul asta parerea mea este ca era normal sa il prezinte el pana la capat; si nu stiu cui i-ar folosi sa mai deschizi un subiect in paralel pe aceeasi tema...pentru ca s-ar prezenta fix acelasi model!
#22
Postat 08 January 2009 - 01:44 PM
#23
Postat 08 January 2009 - 02:36 PM
Atata timp cat e vorba de acelasi model...consider ca topicul nu este al cui l-a deschis ci al modelului. Cu cat se prezinta mai multe kit-uri cu atat vor fi acoperite mai multe probleme ce pot aparea la montaj. Iar daca unu face ceva diferit....foarte bine...abia vor stii ceilalti daca e o idee buna sau nu sa faca si ei acea modificare.
ps. cam asta am facut si eu cu Decathlon-ul meu...am scris in kit review unde era deja deschis subiectul. Unele dintre problemele mele le-au avut si ceilalti ...altele nu. Acum si fretemiu are decathlon-ul si din cate am vazut...mai exista si alte probleme neatinse inca.
Stima.
#24
Postat 08 January 2009 - 02:51 PM
yr-zbg, la Jan 8 2009, 02:36 PM, a spus:
Crezi? Mie mi s-a parut ca Turok vroia sa faca review la modelul ala cu pozele facute de Romulus pe modelul (ghici???) tot al lui Romulus. Care inteleg ca este deja construit.
De aceea am si spus ca e normal sa-l duca Romulus pana la capat.
Dar poate ca doar mi s-a parut.....
Aceasta postare a fost editata de MADA: 08 January 2009 - 02:54 PM
#25
Postat 08 January 2009 - 08:40 PM
#26
Postat 10 January 2009 - 04:17 AM
Pentru receptie am folosit un regulator cu switch magnetic incorporat DPSI Micro MPS RV de la Emcotec alimentat de un LiPo de 1.500 mAh.
Nu am cantarit inca modelul dar am s-o fac cat de repede pot.
#27
Postat 11 January 2009 - 08:25 PM
Number of downloads: 354 -
Number of downloads: 295 -
Number of downloads: 252 -
#28
Postat 11 January 2009 - 08:30 PM
Number of downloads: 277 -
Number of downloads: 227 -
Number of downloads: 188 -
#29
Postat 11 January 2009 - 08:31 PM
Number of downloads: 300 -
Number of downloads: 286 -
#30
Postat 11 January 2009 - 08:39 PM
