Modelism - RHC Forum: Multiplex AcroMaster - Modelism - RHC Forum
  • 8 Pagini +
Multiplex AcroMaster kit, build, flight log
#1 Useril este offline   Romulus
  • Postari: 1190
  • Inregistrat: 02-June 08
Postat 05 August 2008 - 01:43 PM
Am cumparat un kit Multiplex AcroMaster cu tot ce e nevoie. Vreau sa pun poze pe masura ce-l construiesc si sa impartasesc experienta mea cu acest kit intr-un domeniu total nou pentru mine. Acrobatie.
#2 Useril este offline   Romulus
  • Postari: 1190
Postat 05 August 2008 - 05:43 PM
Cutia asa cum vine ea...
Fisier atasat  IMG_5411_small.jpg (82.3K)
Number of downloads: 12576Fisier atasat  IMG_5415_small.jpg (68.42K)
Fisier atasat  IMG_5413_small.jpg (64.83K)
Number of downloads: 6783Fisier atasat  IMG_5418_small.jpg (73.42K)
Motorizarea HiMax C3516-1130
Fisier atasat  IMG_5425_small.jpg (70.18K)
Number of downloads: 4861Fisier atasat  IMG_5427_small.jpg (66.24K)
Aceasta postare a fost editata de big_ipaq: 05 August 2008 - 05:43 PM
#3 Useril este offline   Romulus
  • Postari: 1190
Postat 05 August 2008 - 05:48 PM
Lipo Hyperion 2.100 mAh 18C 3S
Fisier atasat  IMG_5428_small.jpg (71.84K)
Servo eleroane 2 bucati Hitec HS-55
Fisier atasat  IMG_5432_small.jpg (50.14K)
Servo elevator si directie 2 bucati Robbe FS 550 BB Carbon Digital
Fisier atasat  IMG_5433_small.jpg (46.92K)
Regulator Jamara Xenon Eco 40A
Fisier atasat  IMG_5436_small.jpg (79.39K)
Elici Electro APC Jamara 11x5,5 si 10x5
Fisier atasat  IMG_5435_small.jpg (77.46K)
Si o vopsea pentru canopie
Fisier atasat  IMG_5439_small.jpg (53.38K)
Aceasta postare a fost editata de big_ipaq: 05 August 2008 - 05:49 PM
#4 Useril este offline   Romulus
  • Postari: 1190
Postat 05 August 2008 - 05:55 PM
Si cateva poze din cutie...
Fisier atasat  IMG_5455_small.jpg (63.16K)
Number of downloads: 288Fisier atasat  IMG_5449_small.jpg (62.39K)
Fisier atasat  IMG_5452_small.jpg (71.47K)
Number of downloads: 277Fisier atasat  IMG_5454_small.jpg (63.51K)
Number of downloads: 214Fisier atasat  IMG_5456_small.jpg (56.58K)
#5 Useril este offline   Romulus
  • Postari: 1190
Postat 06 August 2008 - 03:26 AM
In primul rand, pentru cei interesati: Instructiunile de asamblare Multiplex AcroMaster (format PDF - 754 Kb EN, DE, FR).
Apoi, n-am fost lenes in seara/noaptea asta... M-am apucat de asamblare...
Am verificat cum se potriveste montura motorului inainte de lipire. Apoi am si lipit montura pe fiecare jumatate de fuselaj.
Fisier atasat  IMG_5462_small.jpg (54.67K)
Number of downloads: 330Fisier atasat  IMG_5458_small.jpg (48.04K)
Am lipit pe fiecare jumatate de fuselaj, urechile de prindere ale canopiei.
Fisier atasat  IMG_5463_small.jpg (55.68K)
Apoi am lipit protectiile de plastic ale aparatorilor de roti, si partea exterioara si partea interioara. Sunt niste lagare metalice in care va intra tija rotii... Se lipesc direct e aparatorile rotilor cu cyano.
Fisier atasat  IMG_5467_small.jpg (56.77K)
Number of downloads: 240Fisier atasat  IMG_5468_small.jpg (32.86K)
Fisier atasat  IMG_5469_small.jpg (57.19K)
Apoi am potrivit roata pe ax, sa va daca totul e ok.
Fisier atasat  IMG_5470_small.jpg (55.68K)
Intre timp, cum eu am incarcator Robbe cu egalizator tot Robbe, mufa e egalizare de la lipo fiind Polyquest, am cautat in cutia cu scule un adaptor de egalizare, ca sa pot incarca si lipo-ul.
Fisier atasat  IMG_5472_small.jpg (61.9K)
Apoi am lipit cele doua jumatati ale fiecarei aparatori de roti.
Fisier atasat  IMG_5476_small.jpg (33.04K)
Number of downloads: 223Fisier atasat  IMG_5477_small.jpg (30.93K)
Aceasta postare a fost editata de big_ipaq: 06 August 2008 - 03:27 AM
#6 Useril este offline   Romulus
  • Postari: 1190
Postat 06 August 2008 - 03:36 AM
Desi cred ca vor avea viata scurta prin iarba de unde voi decola modelul, sunt multumit de cum au iesit cele doua aparatori de roti.
Fisier atasat  IMG_5475_small.jpg (68.23K)
Number of downloads: 192Fisier atasat  IMG_5478_small.jpg (31.53K)
Servourile FS 550 BB Carbon Digital, pentru carma si profundor, montate in fuselaj, de proba.
Fisier atasat  IMG_5479_small.jpg (41.97K)
Number of downloads: 215Fisier atasat  IMG_5480_small.jpg (42.92K)
Am "construit" conform instructiunilor, bratele pentru aceste doua servo. Multiplex a pus la dispozitie in kit si bratele mari dar si cele doua surubele necesare.
Fisier atasat  IMG_5481_small.jpg (49.81K)
Number of downloads: 237Fisier atasat  IMG_5483_small.jpg (47.47K)
Am asamblat complet rotile si am strans suruburile imbus fara cap pregatind complet trenul de aterizare.
Fisier atasat  IMG_5487_small.jpg (25.99K)
Number of downloads: 176Fisier atasat  IMG_5488_small.jpg (29.46K)
Am pregatit sa lipesc cele doua jumatati de fuselaj si ca urmare am protejat si lipit cu banda de hartie, cablurile e la servouri, ca sa nu ma incurce la lipire.
Fisier atasat  IMG_5489_small.jpg (64.79K)
Pentru a lipi servourile de fuselaj, folosind glue-gun-ul, am protejat servourile mai intai.
Fisier atasat  IMG_5490_small.jpg (49.38K)
#7 Useril este offline   Romulus
  • Postari: 1190
Postat 06 August 2008 - 03:44 AM
Si ulterior am aplicat cateva picaturi de adeziv fierbinte cu pistolul de adeziv, pe urechiusele de la servouri.
Fisier atasat  IMG_5492_small.jpg (66.82K)
Si cum preventia este mai buna decat repararea, am inchis cu putina banda gaura servourilor, pana cand lipesc jumatatile de fuselaj.
Fisier atasat  IMG_5495_small.jpg (42.35K)
Apoi am chiar lipit fuselajul, folosindu-ma printre altele si de ceva benzi elastice.
Fisier atasat  IMG_5498_small.jpg (54.32K)
Am pregatit si roata din deriva.
Fisier atasat  IMG_5499_small.jpg (24.38K)
Si uite si o prima problema. Manualul spune sa imping tija rotilor, in piesa de fixare pana face "click" si s-o fixez acolo cu putin cyano. A mea se incapataneaza sa nu faca click si mai rau, aluneca inapoi afara cu destul de mare forta. Nici vorba sa ramana fixata acolo cu o picatura de cyano. O sa vedem cum rezolvam problema asta, parca am vazut ceva rezolvari pe net.
Fisier atasat  IMG_5500_small.jpg (29.47K)
Si cateva poze de detali dupa lipirea fuselajului.
Fisier atasat  IMG_5501_small.jpg (32.56K)
Number of downloads: 247Fisier atasat  IMG_5502_small.jpg (32.17K)
Fisier atasat  IMG_5503_small.jpg (35.23K)
Number of downloads: 172Fisier atasat  IMG_5505_small.jpg (38.16K)
Fisier atasat  IMG_5507_small.jpg (34.44K)
#8 Useril este offline   Romulus
  • Postari: 1190
Postat 06 August 2008 - 03:55 AM
Panoul de montura al motorului. Are un sistem ingenios de reglaj sidetrust si downtrust... In plus, Multiplex livreaza in kit si un distantier pentru motoarele recomandate Himax, astfel incat tija motorului sa iasa exact 10mm in exteriorul panoului.
Fisier atasat  IMG_5509_small.jpg (55.92K)
Am trecut la aripi proband cum intra servourile Hitec HS55 in locul destinat lor si pregatind cablurile de extensie. Am imbracat in tub termocontractil mufele de conexiune.
Fisier atasat  IMG_5513_small.jpg (50.92K)
Si din doua motive, am alimentat servourile. 1) sa verific conexiunea, inainte sa lipesc aripa si 2) sa aduc servourile in zero.
Fisier atasat  IMG_5514_small.jpg (77.32K)
Am lipit cablul in aripa pentru a-l fixa, macar cat timp lipesc cele capacul aripii si am lipit cu cyano mufa de aripa.
Fisier atasat  IMG_5515_small.jpg (56.64K)
Number of downloads: 324Fisier atasat  IMG_5519_small.jpg (49.74K)
Si am lipit din nou cu glue-gun, servourile pe capacul aripii. Instructiunile spuneau sa le montez dupa ce lipesc capacul, dar n-am gasit nici un motiv sa fac asta si apoi sa ma chinui sa scot calubl afara din aripa cu un lat de sarma, asa cum vroiau cei de la multiplex. Nu cred ca picaturile de cyano si banda adeziva, vor creste semnificativ greutatea aripilor.
Fisier atasat  IMG_5522_small.jpg (52.91K)
Apoi am asamblat provizoriu bestia ca sa ma pot duce si eu la culcare...
Fisier atasat  IMG_5530_small.jpg (50.35K)
Number of downloads: 393Fisier atasat  IMG_5534_small.jpg (77.71K)
Si acum o prima intrebare. Conul elicii, din kit, este din elapor. Este chiar frumos. Se monteaza pe un fel de saiba de plastic, care se strange imediat dupa elice pe ax. Dar nu am nici un surub care sa poata strange piesa asta. Conul metalic al motorului, cel care face strangerea, nu potriveste si orice piulita am cautat in cutia de scule, desi are diametrul interior corect, nu se infileteaza pe penseta.
Cum fac? Folosesc conul asta metalic mic si urat, care lasa un gol mare in fata modelului asa cum e in poza, sau gasesc undeva o piulita corespunzatoare cu care sa prind conul din elapor pe ax?
Aceasta postare a fost editata de big_ipaq: 06 August 2008 - 03:59 AM
#9 Useril este offline   Romulus
  • Postari: 1190
Postat 06 August 2008 - 04:04 AM
Apropos, instructiunile Multiplex, spuneau sa lipesc camasile exterioare de la bowdenuri pe fuselaj, ca prima operatiune. N-am vazut nici un motiv sa fac asta inca de la inceput si le-am omis, in speranta ca le pot instala ulterior. Sper ca nu am gresit luand decizia sa omit aceasta operatiune. Am spus sa nu risc sa picur superglue pe ele si sa le blochez.
#10 Useril este offline   Romulus
  • Postari: 1190
Postat 06 August 2008 - 11:45 AM
Nu ma ajuta nimeni cu raspunsuri la intrebari?
#11 Useril este offline   Bogdan B
  • ex ad525
  • Postari: 948
  • Inregistrat: 25-July 08
Postat 06 August 2008 - 12:46 PM
bravo pt avion ;) cat ai dat pe kit ?
#12 Useril este offline   Romulus
  • Postari: 1190
Postat 06 August 2008 - 12:49 PM
Kitul e 360 lei
Postat 06 August 2008 - 01:16 PM
Felicitari pentru achizitie si pentru minutiozitatea de care dai dovada la montaj.
Eu as lasa conul metalic. Este bine echilibrat, solid, ai racire buna la motor, la viteza de zbor necesara unui acrobat nu vei avea probleme de aerodinamica si in aer nu se va vedea...zic si eu.
#14 Useril este offline   Romulus
  • Postari: 1190
Postat 07 August 2008 - 01:22 AM
Am lipit piesa care tine cele doua bucati ale profundorului si joaca rol si de element de comanda.
Fisier atasat  IMG_5537_small.jpg (28.33K)
Am lipit-o cu cyano de cele doua bucati ale profundorului.
Fisier atasat  IMG_5545_small.jpg (37.47K)
Am probat balamalele si modul lor de prindere si lipire.
Fisier atasat  IMG_5538_small.jpg (37.46K)
Number of downloads: 255Fisier atasat  IMG_5540_small.jpg (36.3K)
Am lipit cu niste banda sa pot marca locul pentru balamale pe ambele parti.
Fisier atasat  IMG_5543_small.jpg (48.68K)
Si am lipit toate balamalele.
Fisier atasat  IMG_5546_small.jpg (32.32K)
Metoda folosita e exact cea din instructiuni, adica am inserat balamaua intr-o suprafata cativa mm, am aplicat pe ambele parti ale ei, adeziv si am impins-o repede inauntru. Am folosit cyano cu vascozitate mica si multe servetele cu care am sters imediat surplusul de adeziv.
Balamalele din directie au fost urmatoarele, aici treaba e putin complicata de roata de la coada.
Fisier atasat  IMG_5552_small.jpg (40.36K)
Number of downloads: 229Fisier atasat  IMG_5555_small.jpg (54.63K)
Dupa ce-am lipit si balamalele de la eleroane, am facut o proba de asamblare finala, prilej cu care am mai facut cateva cadre.
Fisier atasat  IMG_5556_small.jpg (72.15K)
Number of downloads: 331Fisier atasat  IMG_5558_small.jpg (54.88K)
#15 Useril este offline   Romulus
  • Postari: 1190
Postat 07 August 2008 - 01:30 AM
Urmatorul pas a fost sa ma ocup de suprafetele de comanda si comenzile lor.
Fisier atasat  IMG_5564_small.jpg (49.13K)
Number of downloads: 329 Fisier atasat  IMG_5585_small.jpg (44.15K)
Number of downloads: 266 Fisier atasat  IMG_5588_small.jpg (33.02K)
Number of downloads: 200 Fisier atasat  IMG_5590_small.jpg (31.82K)
Am montat definitiv elicea. De data asta am folosit si distantierul din kit.
Fisier atasat  IMG_5565_small.jpg (40.03K)
Number of downloads: 282 Fisier atasat  IMG_5566_small.jpg (38.71K)
Number of downloads: 292 Fisier atasat  IMG_5567_small.jpg (36.3K)
A sosit momentul sa ma apuc de mufe... CT4 pentru circuitul de putere si CT3,5 pentru motor.
Fisier atasat  IMG_5568_small.jpg (66.99K)
Number of downloads: 267 Fisier atasat  IMG_5570_small.jpg (71.01K)
A fost necesar sa pornesc la acest moment motorul ca sa pot pune tub termocontractil colorat potrivit pe cele 3 fire de la motor. Si ca sa verific sensul de rotatie al elicei, am pornit motorul si apoi am pus tubul potrivit pe cele 3 fire...
Fisier atasat  IMG_5572_small.jpg (56.11K)
#16 Useril este offline   Romulus
  • Postari: 1190
Postat 07 August 2008 - 01:36 AM
Partea electrica completa si ea...
Fisier atasat  IMG_5573_small.jpg (51.35K)
Number of downloads: 240 Fisier atasat  IMG_5574_small.jpg (58.9K)
Si practic sunt gata. Mai ramane ca maine sa testez in mare centrul de greutate si dupa aceea sa fixez regulatorul, acumulatorul si receptorul inauntru. Urmatorul pas va fi sa definitivez centrarea si sa o verific temeinic.
Si bineinteles tot maine voi pune stickerele pe el. Inca nu m-am decis ce si cum. Apoi va urma, programarea statiei, D/R, Expo, miscare suprafete de control, etc.
Si sambata, va urma sper eu primul test de zbor.
#17 Useril este offline   Romulus
  • Postari: 1190
Postat 07 August 2008 - 11:15 AM
Am cantarit modelul gata de zbor cu toate inauntru (exceptand scaiurile de fixare lipo, regulator etc) si are 997g. Presupun ca va avea spre 1Kg, cu totului tot.
#18 Useril este offline   Romulus
  • Postari: 1190
Postat 07 August 2008 - 11:35 AM
Instructiunile recomanda lipo intre 2100 mAh si 3200 mAh. Eu desi aveam un 3.200 mAh am cumparat un 2.100 mAh. Motivul fiind pentru a tine greutatea la minimum. Peste tot unde am citit, se spune ca greutatea e esential a fi tinuta la minimum. Asa ca chiar daca va zbura putin cu 2.100 mAh, o sa zboare bine... :D
#19 Useril este offline   Bogdan B
  • ex ad525
  • Postari: 948
Postat 07 August 2008 - 11:43 AM
abia astept sa-l vad zburand... :X:X super tare... bravo inca odata :D
#20 Useril este offline   Romulus
  • Postari: 1190
Postat 07 August 2008 - 11:47 AM
Si eu. Poate inca nu e momentul, in schimb e momentul sa aflu asta. Adica eu m-am obisnuit deja cu gandul ca poate il distrug la primul zbor. Asta e. Consider ca e important sa stiu acum daca pot. Daca nu pot, regandesc strategia. Asa ca am nevoie de incurajari... :D
#21 Useril este offline   Bogdan B
  • ex ad525
  • Postari: 948
Postat 07 August 2008 - 11:53 AM
ar fi pacat sa strici frumusete de avion .... intai vezi pune pe altcineva (mai experimentat ) sal conduca si apoi incearca si tu :D succes si la cat mai multe zboruri fara crash :D
#22 Useril este offline   Romulus
  • Postari: 1190
Postat 07 August 2008 - 11:55 AM
Trebuie sa aflu chiar si cu riscul de a-l distruge. N-am ce face. E doar un avion, psihicul meu e mai important ca el. :D
#23 Useril este offline   Rontaila
  • Postari: 324
  • Inregistrat: 29-May 07
  • Interests:Tot ce zboara cu motor sau se scufunda in mare
Postat 07 August 2008 - 12:25 PM
Vezi postareabig_ipaq, la Aug 7 2008, 12:55 PM, a spus:
Nu stiu ce strategie alegi, dar avionul este rapid si foarte manevrabil,este bine sa incepi cu niste setari care sa-ti permita si ezitari si mici greseli ,oricum ridica-l sus si la loc larg .
Bafta si CAVOK
Primul sosit ,ultimul plecat..
#24 Useril este offline   Romulus
  • Postari: 1190
Postat 08 August 2008 - 01:20 PM
Am terminat si decoratiunile. Nu l-am centrat inca. Urmeaza si asta.
Fisier atasat  IMG_5595.jpg (175.37K)
#25 Useril este offline   Bogdan B
  • ex ad525
  • Postari: 948
Postat 08 August 2008 - 01:24 PM
a iesit beton :) cand il zboir sa pui un filmulet :D bravo
#26 Useril este offline   Romulus
  • Postari: 1190
Postat 09 August 2008 - 09:12 PM
Zburat. Aterizat. Fericit.
#27 Useril este offline   Porumbeu
  • Postari: 831
  • Inregistrat: 09-July 07
  • Interests:discussion
Postat 09 August 2008 - 09:32 PM
off-topic: ai dat buleala cu poza de mai sus unde zici ca ai terminat de pus stick-ere pe el :D e luata de pe site de la ei ( se vede pe fundal ©RMM 2008 )
on-topic: baga filme :lol:
#28 Useril este offline   renatoa
Postat 09 August 2008 - 09:41 PM
Sunt initialele lui, Romulus MM, nu ai nimerit-o.
MM nu vine in cazul asta de la Multiplex Modellbau, chiar daca pare ciudata coincidenta...
Vezi postareaPorumbeu, la Aug 9 2008, 10:32 PM, a spus:
Aceasta postare a fost editata de renatoa: 09 August 2008 - 09:41 PM
#29 Useril este offline   Romulus
  • Postari: 1190
Postat 09 August 2008 - 09:53 PM
@Renatoa: glumea... Porumbeu a vazut azi modelul live. Pacat c-a plecat inainte de a-l vedea in zbor. :lol:
It flies!
Fisier atasat  IMG_5815.jpg (41.28K)
#30 Useril este offline   Romulus
  • Postari: 1190
Postat 09 August 2008 - 10:01 PM
And it can land...
Fisier atasat  IMG_5826.jpg (174.83K)
  • 8 Pagini +
