  • 134 Pagini +
  • 26
  • 27
  • 28
  • 29
  • 30
#811 Useril este offline   laur.xxl
  • Postari: 72
  • Inregistrat: 13-December 07
Postat 27 February 2009 - 05:22 PM
@on_off road
merci asta am vrut sa aud.
tocmai mi-au venit de pe ebay 2 servo si am fost placut surprins sa nu mai platesc nimic altceva in plus , de aceea am intrebat
Aceasta postare a fost editata de laur.xxl: 27 February 2009 - 05:23 PM
#812 Useril este offline   Sunseth
  • Postari: 1
  • Inregistrat: 24-November 07
Postat 02 March 2009 - 10:02 AM
salut am si eu o intrebare....am o masina electrica mai veche care necesita 6 baterii de 1.5v as putea sa o fac sa mearga pe un acumulator?
#813 Useril este offline   on_off road
  • Postari: 526
  • Inregistrat: 30-October 08
Postat 02 March 2009 - 02:54 PM
Vezi postareaSunseth, la Mar 2 2009, 10:02 AM, a spus:
pui 6 acumulatori , dar o sa mearga putin mai incet
daca voi nu ma vreti , io oricum nu va vreu
#814 Useril este offline   daniZZ
  • Postari: 374
  • Inregistrat: 12-January 09
  • Interests:Automodelism
Postat 05 March 2009 - 09:05 AM
Super Acumulatori, Utilizator incompetent sau doar aparat de masura defect??????
Deci
Am un pack 5 elementi 2/3A (6V) 1100mA. Ieri seara l-am scos de la incarcat, si l-am masurat.
tensiune 7.24V si stupoare :D :o :rolleyes: curent 8,3A........ :o :o
Imagine postataOffroad Racer: Team Associated SC10 (Novak GTB+Novak Ballistic 8.5T) RIENERGY BodyDrifter/Touring:Tamiya Ta05 (HPI SC15+LRP V10 Spec4 17x2T) VIENNA POLICE Body
Radio:Ansman W3 40MHz canal 58 For Sale
FlySky GT3B hacked and moded
#815 Useril este offline   Isti
  • Postari: 339
  • Inregistrat: 12-October 08
Postat 05 March 2009 - 09:38 AM
Amperii se masora in sarcina asa ca nu stiu cum ai masurat tu...
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
#816 Useril este offline   Dan71
  • Postari: 1390
  • Inregistrat: 27-March 08
Postat 05 March 2009 - 09:49 AM
Vezi postareadaniZZ, la Mar 5 2009, 09:05 AM, a spus:
Deci
E normal sa arata 7.25V(5*1.45V) imediat dupa incarcare.Totusi vezi sa nu se incalzeasca ca par cam "supraincarcati".
Ce ai masurat tu A ai masurat in scurt, nu asa se masoara, masoara-l in sarcina cum a spus Isti.
#817 Useril este offline   amd
  • Postari: 731
  • Inregistrat: 25-March 08
Postat 05 March 2009 - 11:29 AM
nu poti afla cati amperi are decat daca stii rata de descarcare ( C )
deoarece tu cand il masori cu ampermetrul il bagi in scurt cum ar venii si bineinteles ca o sa iti arate mai multi amperi decat are packul deoarece intervine rata de descarcare
daca ti-a aratat 8.3 A inseamna ca rata de descarcare ar fi pe undeva pe la 8 C
amperii masurati cu aparatul de masura(in scurt) = C * amperajul packului
tu te asteptai sa iti arate 1.1 A dar de aici rezulta ca rata de descarcare sa fie = 1 ( ceea ce este prea putin)
sper ca m-am facut inteles :rolleyes:
Aceasta postare a fost editata de amd: 05 March 2009 - 11:29 AM
#818 Useril este offline   daniZZ
  • Postari: 374
Postat 05 March 2009 - 01:16 PM
OK merci, m-am lamurit....
#819 Useril este offline   3leigrei
  • Postari: 132
  • Inregistrat: 01-November 08
  • Interests:pescuitul si mai nou navomodele de plantat[de la bratesti3 mi se trage]
  Postat 05 March 2009 - 06:14 PM
sall.am un hpi brama si am un pack de 2000 nimh.mie mi se pare ca nu merge asa de tare se poate sa fie din causa bateriei ca este prea mica?
#820 Useril este offline   Bogdi
  • Postari: 280
  • Inregistrat: 20-October 08
  • Interests:baschet, ciclism (dirt jump) si automodelism
Postat 05 March 2009 - 06:57 PM
Vezi postarea3leigrei, la Mar 5 2009, 06:14 PM, a spus:
(2000) mah = timp de joaca
Deci daca dai cateva ture, normal ca nu va mai merge ca la inceput...
HPI Baja 5B SS:
-Futaba 3PKS 2.4GHZ
-filtru Redneck TGN
-3700mAH hump pack EDIT, 1400mAH hump pack intellect
-roti Tarmac Buster (on-road), jante Pro-line Desperado fata/spate (negre), cauciucuri Hostile Hobby MX Hard (spate), cauciucuri Dirt Buster (fata)
-geamuri atx (fumurii)
-servo Blue Bird pt. acceleratie
-servo Hitec 5755MG pt. directie
-caroserie Pro-line Desert Rat
-bascule RPM fata
-toba DDM Dominator V2 (neagra cu silentiator)
-billet gas cap (carbon/rosu)
-Dark Soul axle extenders V2
-Outwears combo kit (elemente negre)
-Ultimate Rear Brake Kit by TGN (carbon)
HPI Wheely King 4x4:
-rock crawler conversion kit
-motor 15t + gearbox
-radiator cu ventilator pentru motor
-ESC Jamara NO Limit
-servo tower pro MG996R
-baterie LRP 4000mah, HPI Plazma 4300mah
-anvelope Hot Bodies Rover Crawler + jante Rock 8 Bead Lock Wheel
- caroserie Ford F100
#821 Useril este offline   Isti
  • Postari: 339
Postat 06 March 2009 - 10:09 AM
Poate sa fie si din cauza acumulatoriilor mai ales daca sunt mai vechi. Dar intradevar chiar dupa ce l-ai scos de la incarcat bagi in masinuta cateva secunde ar trebui sa mearga calumea dupa care tot mai slab si mai slab. Dar cel mai usor lucru ce poti sa incerci ceri de la un prieten un alt pack si incerci cu ala.
#822 Useril este offline   bogdyys
  • Postari: 531
Postat 06 March 2009 - 10:41 AM
Servus,am vazut la masinuta mea in timpul unei inspectii de rutina,ca unul dintre diferentiale nu mai are vaselina,voi comanda dar solutii de moment(sau definitive)?Adica ce fel de vaselina pot folosi?De auto 1/1 merge?Are acceiasi vascozitate?Ceva care pot gasi la magazine de bricolaj?
FOREVER YOUNG.......
#823 Useril este offline   rad_gaby
  • Postari: 673
Postat 06 March 2009 - 10:55 AM
Nu merge. Ala e de fapt un ulei siliconic de vascozitate mare si in plus diferit fata-spate. Ceva de genul 10K pe spate si 30K pe fata in cazul in care ai un MT.
#824 Useril este offline   prisi
  • scale addicted
  • Postari: 1299
  • Inregistrat: 03-January 08
Postat 06 March 2009 - 10:56 AM
eu folosesc vaselina normala la diferentiale si se comporta ok.nu am vazut uzura prematura sau alte defecte din cauza vaselinei normale.
If it is to be it is up to me
#825 Useril este offline   rad_gaby
  • Postari: 673
Postat 06 March 2009 - 11:02 AM
Problema nu se pune in termeni de uzura sau alte defecte ci in controlul subvirarii/supravirarii la viteza mare. De aceea se folosesc vascozitati diferite.
#826 Useril este offline   bogdyys
  • Postari: 531
Postat 06 March 2009 - 11:20 AM
Sigur m-am exprimat gresit! :D .Stiu ca in diferential se pune silicon oil,eu ma refer la pinioanele exterioare.
#827 Useril este offline   bogdyys
  • Postari: 531
Postat 06 March 2009 - 11:27 AM
Vezi postareaprisi, la Mar 6 2009, 10:56 AM, a spus:
Prin normala te referi la cea folosita la 1/1?De culoare maro?Si spune-mi te rog daca stii,merge si la cutie?
#828 Useril este offline   ionut76
  • Postari: 1240
  • Inregistrat: 19-November 08
  • Interests:http://www.catia.ro
Postat 06 March 2009 - 11:53 AM
Intreba cineva mai sus de ce nu merge Brama mai repede. Nu stiu, nici la mine nu merge, vreau sa fac unele reglaje la motor, are citeva pozitii in care se monteaza roata conducatoare, ma uit pe net, gasisem ceva. Insa, nu stiu daca BRAMA este un model de viteza, parerea mea este ca viteza e compensata de manevrabilitate. Si inca ceva: ia-ti inca un acumulator de 4000-4700 mAh.
Cursuri si carti CATIA v5 aici
#829 Useril este offline   stefymaso
  • Postari: 169
  • Inregistrat: 16-February 09
  • Interests:...somnul...
Postat 09 March 2009 - 10:42 PM
sall all am fost cu e-maxxu afara si l`am balacit cam mult asa ca l`am facut bucatele si m`am gandit sa`i refac ungerea mai ales avand in vedere ca l`am cumparat second hand ... are ceva daca fotosesc vaselina mai moale(de la niste utilaje electrice de la mn de la munca?) sau mai am niste ulei de mecanisme fine de la fostul loc de munca (masini de cusut/croitorie) ... ce imi recomandati dintre cele 2 variante?
E-MaXx Novak power
#830 Useril este offline   leontin93
  • Postari: 86
  • Inregistrat: 04-January 09
  • Interests:Hobby-ul meu este aeromodelele!
Postat 09 March 2009 - 10:45 PM
Am o intrebare cam cat prinde un carson mini bull?
Just FLY!
#831 Useril este offline   amd
  • Postari: 731
Postat 10 March 2009 - 09:08 AM
@ stefymaso - parerea mea este sa folosesti mai bine uleiul pt rulmenti si vaselina pt pinioane
#832 Useril este offline   Barabula
  • Postari: 415
  • Inregistrat: 25-November 07
Postat 10 March 2009 - 06:21 PM
Vezi postareastefymaso, la Mar 9 2009, 11:42 PM, a spus:
Uleiul de mecanisme fine e bun pentru rulmenti si bucsele motorului (daca e pe bucse de bronz) dar inutil in rest.
Pentru celelalte (daca pinioanele sint de plastic) iti trebuie unsoare pentru plastice (ceramic grease de la Tamiya de exemplu, nu poate sa fie prea scumpa).
Pentru diferentiale, vasilina siliconica daca sunt cu bile, sau unsoare ceramica daca sunt cu pinioane. Vezi si tu ce vasilina ai, dar nu cred ca merita sa te scumpesti pentru citva gologani.
#833 Useril este offline   stefymaso
  • Postari: 169
Postat 10 March 2009 - 06:31 PM
Vezi postareaamd, la Mar 10 2009, 09:08 AM, a spus:
...m`am gandit bine si am mai facut rost de 1 spray cu vaselina sau ceva de genul ala o sa`l folosesc la angrenajele mai "fine" iar la cele mai robuste voi folosi vaselina aper sa iasa bn:) ... asta seara ma apuc sa o remontez insa daca demontatul a durat doar o ora montatul ma tem ca imi va lua cel putin 3h :rolleyes:) asta daca nu intampin probleme pe parcurs:)
E-MaXx Novak power
#834 Useril este offline   porcofon
  • Postari: 961
  • Inregistrat: 26-October 08
Postat 12 March 2009 - 11:18 AM
vin si eu cu o intrebare...
aveti idee unde as putea gasi rulmenti cu urmatoarele dimensiuni?
diametru exterior = 9.5mm (9mm)
diametru interior = 3mm
grosime = 4mm
multumesc
#835 Useril este offline   X-tra
  • Postari: 533
  • Inregistrat: 27-February 07
Postat 12 March 2009 - 11:55 AM
Astia's ??
HoBao Hyper 8.5 Pro > RB WS7
#836 Useril este offline   porcofon
  • Postari: 961
Postat 12 March 2009 - 11:56 AM
Vezi postareaporcofon, la Mar 12 2009, 11:18 AM, a spus:
grosime = 4mm
multumesc
scuze de double post...
am primit specificatiile de la producator
Motor ball bearing 1/8 x 3/8 x 5/32
am uitat s amai specific ca ma intereseaza un magazin din tara. pe tower l-am gasit...
@X-tra: da, aceia sunt :| sau acestia
Aceasta postare a fost editata de porcofon: 12 March 2009 - 11:58 AM
#837 Useril este offline   X-tra
  • Postari: 533
Postat 12 March 2009 - 01:45 PM
Vorbeste cu Sahin, parca zicea ceva de niste ceramici.
#838 Useril este offline   Isti
  • Postari: 339
Postat 12 March 2009 - 06:23 PM
INtradevar sunt bune cele mentionate mai sus dar daca nu ai buget pentru chestiile astea. Iei un sprai de WD-40 si dai cu el pe la incheieturi etc.
#839 Useril este offline   Al3xandru239
  • Membru somnambul
  • Postari: 1877
  • Inregistrat: 11-August 08
  Postat 12 March 2009 - 11:42 PM
buna ziua! Am si eu un variator luat de la un prieten :) .NU MERGE :( : Am venit acasa sa il pun si eu pe masina ,l.am conectat pe receptor cum trebuie , conectez si motorul la el un motor de 300 , conectez acumulatoru , dau drumu la statie ... PAUZA... nu merge :( ciudat este faptul ca nu merge nici servoul , din cate am mai citit pe forum cand se arde un variator servoul merge (al meu nu a scos fum , nu miroase, nu nimic) , la mine numai merge nici servoul.Am deconectat variatorul de pe receptor si am lasat motorul si acumulatorul legat pe variator , se aude ticaitul de la motor dar cand il conectez la loc numai nu merge. :) :( http://www.rhcforum....tyle_emoticons/default/blink.gif
Receptorul nu este stricat l.am probat cu un echipament vechi(motor,servo, accu,variator). :(
Associated SC8E on 4S
Membru retras!
#840 Useril este offline   radu94
  • GNS Racing
  • Postari: 2650
  • Inregistrat: 02-November 08
    Ciclism
  Postat 13 March 2009 - 07:00 PM
Vezi postareaAl3xandru239, la Mar 12 2009, 11:42 PM, a spus:
buna ziua! Am si eu un variator luat de la un prieten :) .NU MERGE :unsure: : Am venit acasa sa il pun si eu pe masina ,l.am conectat pe receptor cum trebuie , conectez si motorul la el un motor de 300 , conectez acumulatoru , dau drumu la statie ... PAUZA... nu merge :( ciudat este faptul ca nu merge nici servoul , din cate am mai citit pe forum cand se arde un variator servoul merge (al meu nu a scos fum , nu miroase, nu nimic) , la mine numai merge nici servoul.Am deconectat variatorul de pe receptor si am lasat motorul si acumulatorul legat pe variator , se aude ticaitul de la motor dar cand il conectez la loc numai nu merge. :) :rolleyes: :blink:
Receptorul nu este stricat l.am probat cu un echipament vechi(motor,servo, accu,variator). :blink:
La mine la masina este legat servo-ul in receptor. Daca nu-ti merge esc-ul (si zici ca este testat pe alt motor) cred ca este de la receptor, motorul nu cred ca sa ars. Incearca sa pui alt receptor si poate va merge. La mine este este.
Verifica receptorul sa fie conetat corect inca o data, sar putea sa ai noroc sa fie ceva legatura sau ceva contact "rece"
Stiu ca pare stupid, dar poate este pentru motor brushless. :)
Radu :)
Aceasta postare a fost editata de radugns: 13 March 2009 - 07:01 PM
Custom CNC parts GNS Racing
  • 134 Pagini +
  • 26
  • 27
  • 28
  • 29
  • 30
33 useri citesc topicul
0 membri, 33 vizitatori, 0 utilizatori anonimi
