  • 134 Pagini +
  • 16
  • 17
  • 18
  • 19
  • 20
#511 Useril este offline   Bogdi
  • Postari: 280
  • Inregistrat: 20-October 08
  • Interests:baschet, ciclism (dirt jump) si automodelism
Postat 27 December 2008 - 05:07 PM
se pot combina cateva culori obtinand efect cameleon?
sau mai bine cumpar direct un spray cu culoare cameleon?
HPI Baja 5B SS:
-Futaba 3PKS 2.4GHZ
-filtru Redneck TGN
-3700mAH hump pack EDIT, 1400mAH hump pack intellect
-roti Tarmac Buster (on-road), jante Pro-line Desperado fata/spate (negre), cauciucuri Hostile Hobby MX Hard (spate), cauciucuri Dirt Buster (fata)
-geamuri atx (fumurii)
-servo Blue Bird pt. acceleratie
-servo Hitec 5755MG pt. directie
-caroserie Pro-line Desert Rat
-bascule RPM fata
-toba DDM Dominator V2 (neagra cu silentiator)
-billet gas cap (carbon/rosu)
-Dark Soul axle extenders V2
-Outwears combo kit (elemente negre)
-Ultimate Rear Brake Kit by TGN (carbon)
HPI Wheely King 4x4:
-rock crawler conversion kit
-motor 15t + gearbox
-radiator cu ventilator pentru motor
-ESC Jamara NO Limit
-servo tower pro MG996R
-baterie LRP 4000mah, HPI Plazma 4300mah
-anvelope Hot Bodies Rover Crawler + jante Rock 8 Bead Lock Wheel
- caroserie Ford F100
#512 Useril este offline   nelu bv
  • Postari: 658
  • Inregistrat: 19-May 07
Postat 27 December 2008 - 06:07 PM
Vezi postareaBogdi, la Dec 27 2008, 05:07 PM, a spus:
oricat ai combina culorile nu vei obtine cameleon
cameleonul e dat de o perla care se aplica pe o vopsea de baza in mai multe straturi ininte de lac
in functie de baza se vad culorile
bafta
Decat sa bei si sa conduci mai bine fumezi si zbori !!!!!!!
#513 Useril este offline   Bogdi
  • Postari: 280
Postat 27 December 2008 - 06:56 PM
multumesc mult de raspuns !
ce magazin mi-ati recomanda din Vienna unde sa gasesc vopsea cameleon pentru lexan?
HPI Baja 5B SS:
-Futaba 3PKS 2.4GHZ
-filtru Redneck TGN
-bascule RPM fata
#514 Useril este offline   cata_adc
  • Postari: 113
  • Inregistrat: 09-November 08
  • Interests:Sporturile cu motor, mai nou AUTOMODELISM ;)
Si care isi va lua zborul la prima lovitura a carcasei :)
Mai bine nu te complici
Spektrum DX3R DSM2
Traxxas REVO 3.3 #5308
HPI Savage X 4.6 Reverse
Tamiya TT-01 XB BMW 320si
#515 Useril este offline   Vlad1111
  • Postari: 370
  • Inregistrat: 06-July 06
Postat 27 December 2008 - 07:49 PM
intrebare, care spuneti voi ca este cea mai super masina? ce merge pe metanol si numai metanol.
all bad thing that can happen, will happen.
#516 Useril este offline   amd
  • Postari: 731
  • Inregistrat: 25-March 08
Postat 28 December 2008 - 10:50 AM
referitor la magazin in viena iti recomand Conrad care are pe langa electronice si articole de modelism, deci acolo cred ca au si vopsea
parerea mea
stima
marius
#517 Useril este offline   Bogdi
  • Postari: 280
Postat 28 December 2008 - 12:41 PM
Vezi postareaamd, la Dec 28 2008, 10:50 AM, a spus:
parerea mea
stima
marius
multumesc mult de raspuns!
si la G.K. (Gerhold Kirchert) au vopsea, dar nu stiu daca au ce imi trebuie mie.....
o sa incerc si la G.K. si la Conrad sa vad unde gasesc......
Aceasta postare a fost editata de Bogdi: 28 December 2008 - 12:42 PM
HPI Baja 5B SS:
-Futaba 3PKS 2.4GHZ
-filtru Redneck TGN
-bascule RPM fata
#518 Useril este offline   Al3xandru239
  • Membru somnambul
  • Postari: 1877
  • Inregistrat: 11-August 08
Postat 29 December 2008 - 12:20 AM
Salut ..!!! Si sarbatori fericite!
As avea si eu o intrebare in legatura cu niste sasiuri ale marci TAMIYA , intrebarea suna cam asa : Care este diferenta intre sasiul m03 si m04?
Tatal meu vrea o tamiya m03 Mini One si nu gasesc piese pt ea cand dau search m03 parts imi dgaseste piese de m04 se potrivesc piesele?(din cate am vazut ..da.)
{am cautat si pe google dar nu am gasit nimic}
multumesc
Aceasta postare a fost editata de Al3xandru239: 29 December 2008 - 12:24 AM
Associated SC8E on 4S
Membru retras!
#519 Useril este offline   Vlad1111
  • Postari: 370
Postat 29 December 2008 - 01:33 AM
cine stie unde gasesc cel mai ieftin un savage X SS kit nou? daca stiti voi de un magazin sau pe cineva ce importa la pret foarte mic
#520 Useril este offline   adio
  • Postari: 8
  • Inregistrat: 28-December 08
Postat 29 December 2008 - 06:30 PM
ce inseamna RTR?
#521 Useril este offline   Bogdi
  • Postari: 280
Postat 29 December 2008 - 06:45 PM
Vezi postareaadio, la Dec 29 2008, 06:30 PM, a spus:
ce inseamna RTR?
Ready To Run/Race
adica are toate incluse care ti le trebuie la masina si sunt de asemena montate
Aceasta postare a fost editata de Bogdi: 29 December 2008 - 06:47 PM
HPI Baja 5B SS:
-Futaba 3PKS 2.4GHZ
-filtru Redneck TGN
-bascule RPM fata
#522 Useril este offline   Mr. F
  • Postari: 582
  • Inregistrat: 17-December 03
Postat 30 December 2008 - 05:13 PM
Intrebare: Care este durata medie de viata a unui motor termic de off-road, folosit normal (nici fortat, nici menajat) ?
Eu nu am probleme, intreb doar de curiozitate. Eu cu modelul meu am consumat cam 2.5 l in 1 luna.
#523 Useril este offline   costinbv
  • Postari: 345
  • Inregistrat: 27-September 06
Postat 30 December 2008 - 05:20 PM
Vezi postareaMr. F, la Dec 30 2008, 05:13 PM, a spus:
nu cred ca are o viata prea scurta
daca il intretii calumea si schimbi segment si piese care se uzeaza il poti tine mult timp
#524 Useril este offline   off-road
  • Postari: 355
  • Inregistrat: 27-September 08
  • Interests:sportul cu motor
Postat 30 December 2008 - 05:21 PM
am si eu o problema!mi-am cumparat un motor si un variator brushless!problema este ca variatoru are cele 3 fire pt motor de aceasi culoare(albastre) si cate o initiala pt fircare(B R C)motorul are firele de culori diferite!intrebarea mea este cum sa le conectez?pot sa le pun pe incercatelea pana aflu?se poate arde ceva daca fac asa?multumesc
Drive them like you hate them!!!
#525 Useril este offline   protheus
  • 日本語
  • Postari: 1719
  • Inregistrat: 26-August 07
Postat 30 December 2008 - 07:10 PM
Vezi postareaoff-road, la Dec 30 2008, 06:21 PM, a spus:
Spre motor la brushless nu conteaza ordinea, decat pentru directia de rotatie, care se selecteaza foarte usor (schimbi 2 dintre fire intre ele), cel putin la cele cu care am avut eu de-a face.
Cu respect,
Catalin C.
#526 Useril este offline   X-tra
  • Postari: 533
  • Inregistrat: 27-February 07
Postat 30 December 2008 - 07:22 PM
Vezi postareaVlad1111, la Dec 27 2008, 07:49 PM, a spus:
De ce ?? te apuci de Nascar ???
HoBao Hyper 8.5 Pro > RB WS7
#527 Useril este offline   off-road
  • Postari: 355
Postat 30 December 2008 - 08:04 PM
mersi frumos de raspuns!
#528 Useril este offline   cristi995
  • Postari: 14
  • Inregistrat: 30-December 08
  Postat 31 December 2008 - 12:38 PM
salut catre toti! sunt incepator in acest domeniu si as vrea un pic de ajutor .ma intereseaza mai ales automodelele off-road si am vizitat cateva
siteuri printe care si #$%&%#$$ dar nu ma pot decide ce model sa-mi iau. as prefera unul termic .
as fi recunoscator pentru orice raspuns :lol:
Vezi postareacristi995, la Dec 31 2008, 12:37 PM, a spus:
as fi recunoscator pentru orice raspuns :D
#529 Useril este offline   costinbv
  • Postari: 345
Postat 31 December 2008 - 03:02 PM
Vezi postareacristi995, la Dec 31 2008, 12:38 PM, a spus:
as fi recunoscator pentru orice raspuns ;)
salut si tie
foloseste functia search si vei gasi 10000000 de discutii pe acest subiect
sau mai simplu uitate pe paginile acestui topic
#530 Useril este offline   mihaimitza
  • Postari: 18
Postat 31 December 2008 - 03:06 PM
Salut.Scuzati-ma ca va deranjez din nou ,dar am o mica problema cu noul meu automodel Jamara Mad Max .Aseara cum v-am mai spus i-am facut rodaju',iar apoi m-am mai dat cu el pe strada.Iar astazi m-am dat cu el pe strada si m-am lovit de bordura.Cand m-am dus sa vad daca a patit ceva am vazut ca i s-a rupt aparatoarea din fata.Eu as vrea sa va cer parerea despre asta .Pot sa mai lipesc aparatoarea ?Sau daca nu ce sa fac ?Uitati si nishte poze:
#531 Useril este offline   costinbv
  • Postari: 345
Postat 31 December 2008 - 06:17 PM
ai 3 solutii:
1)o lipesti dar ai riscu sa se rupa din nou
2)cumperi una noua poate ceva upgradat
3)iti faci tu una din metal (platband de minim 4 mm grosime) care sigur va tine o viata daca o faci calumea:D
daca vrei detalii.... MI
#532 Useril este offline   mihaimitza
  • Postari: 18
  Postat 31 December 2008 - 07:00 PM
Mersi pt raspuns.
Vezi postareacostinbv, la Dec 31 2008, 06:17 PM, a spus:
ai 3 solutii:
imi poti spune te rog deunde as putea sa imi cumpar o aparatoare noua ?
Aceasta postare a fost editata de Flo234: 31 December 2008 - 07:02 PM
#533 Useril este offline   costinbv
  • Postari: 345
Postat 31 December 2008 - 07:13 PM
Vezi postareamihaimitza, la Dec 31 2008, 07:00 PM, a spus:
Mersi pt raspuns.
deobicei de pe siteul de pe care cumperi masina acolo gasesti si piese
daca nu cauta si tu pe google piese de schimb pt masinuta ta
#534 Useril este offline   andrei2008
  • Postari: 52
  • Inregistrat: 04-August 08
  • Interests:automodelismul
Postat 31 December 2008 - 07:29 PM
Ce parere aveti despre PORSCHE 911 1:10 de la robbe ? E vorba de modelul ce se afla la vanzare si in romania
Un An Nou plin de fericire si bucurie ! Mult succes in tot si in toate alaturi de automodele !
ma refer la modelul terminc
Aceasta postare a fost editata de Flo234: 31 December 2008 - 07:38 PM
Motiv editare: mai este un topic la incepatori
CEN Genesis 7.7 - 1:8
Monster Tyranosaurus - 1:10
HPI E10 - 1:10
Nikko Dodge Viper GTS-R - 1:10
#535 Useril este offline   Prepe
  • Postari: 169
  • Inregistrat: 17-November 08
Postat 01 January 2009 - 10:37 PM
Am si eu o problema cu un Savage
Nu am mai pornit-o de 2 saptamani deoarce nu am mai avut carburant , ieri cand a sosit comanda am umplut rezervorul , Si am zis ca innaite sa o pornesc sa o incalzesc putin si am incalzit-o cu feonul cam 2-3 minute , apoi am bagat putin metanol in carburator ( presiune in rezervor ) si frumos cu glow starterul si roto starterul ... dar din pacate am terminat un acumulator de roto si tot nu a pornit ~X(
Ce as putea sa mai fac
Hpi Savage X 4.6 RTR
#536 Useril este offline   ghost rider
  • Postari: 362
  • Inregistrat: 25-February 08
Postat 01 January 2009 - 10:47 PM
Vezi postareaPrepe, la Jan 1 2009, 10:37 PM, a spus:
Folosesti acelasi combustibil ca inainte?
Verifica si glow-l,sa fie incarcat.Si bujia sa nu fie arsa.
Sper ca stii ca nu se incalzeste sus radiatorul(chiuloasa),trebuie incalzit jos corpul motorului.
Aceasta postare a fost editata de ghost rider: 01 January 2009 - 10:55 PM
nevoia te invata...:)
#537 Useril este offline   Prepe
  • Postari: 169
Postat 01 January 2009 - 11:01 PM
Vezi postareaghost rider, la Jan 1 2009, 10:47 PM, a spus:
Nu folosesc acelasi combustibil innainte foloseam 16% si acum 20% , glow-ul e pe baterii si e bateria noua bujia nu am verificato
Am incalzit
toata baza radiatorului , cat de jos am putut intra cu feonul ... :D
Maine am sa mai incerc
Aceasta postare a fost editata de Prepe: 01 January 2009 - 11:02 PM
#538 Useril este offline   ghost rider
  • Postari: 362
Postat 01 January 2009 - 11:17 PM
[quote name='Prepe' post='264886' date='Jan 1 2009, 11:01 PM']Nu folosesc acelasi combustibil innainte foloseam 16% si acum 20% ,
Cred ca ar cam trebui refacute reglajele,ca sa mearga cu 20%.Oricum o sa trebuiasca sigur niste mici ajustari la reglaje. (avand in vedere schimbarea combustibilului si temperatura de afara).
Adica,mai da-i zeama. :D
Aceasta postare a fost editata de ghost rider: 01 January 2009 - 11:24 PM
#539 Useril este offline   Prepe
  • Postari: 169
Postat 01 January 2009 - 11:20 PM
Multumesc frumos , Nu prea am sanse sa o pornesc asa , nu ?
#540 Useril este offline   ghost rider
  • Postari: 362
Postat 01 January 2009 - 11:29 PM
Cu placere.
Sa nu uiti sa verifici si bujia.
Io' zic ca nu prea ai,fara sa umbli la reglaje.
Aceasta postare a fost editata de ghost rider: 01 January 2009 - 11:43 PM
  • 134 Pagini +
  • 16
  • 17
  • 18
  • 19
  • 20
47 useri citesc topicul
0 membri, 47 vizitatori, 0 utilizatori anonimi
