Modelism - RHC Forum: un pic de ajutor ptr un incepator - Modelism - RHC Forum
  • 5 Pagini +
un pic de ajutor ptr un incepator electronica problema mare
#121 Useril este offline   crapu
  • Postari: 14
  • Inregistrat: 28-December 08
Postat 07 February 2009 - 09:08 PM
nu prea ma pricep la ele asa bine,care crezi ca ar fi mai buna la o barcuta
#122 Useril este offline   ipsihi
Postat 07 February 2009 - 09:11 PM
...una de cumparat!!!
#123 Useril este offline   harrina
  • Postari: 530
  • Inregistrat: 26-July 05
Postat 07 February 2009 - 09:14 PM
corect.
150-200lei.
daca incepi cu mesteritul..........
si totusi se invirte !
#124 Useril este offline   crapu
  • Postari: 14
Postat 07 February 2009 - 09:24 PM
etajul final nui problema,se poate mari ,problema e ca nu gasesc o schema cu 6 canale :lol:
#125 Useril este offline   harrina
  • Postari: 530
Postat 07 February 2009 - 09:26 PM
ai luat in calcul si receptorul?
#126 Useril este offline   ipsihi
Postat 07 February 2009 - 09:29 PM
...iti dau eu schema de encoder/decoder, chiar iti pot da si piesele, vb serios!!!http://www.datasheetcatalog.com/datasheets.../0/NE5044.shtml
...NE 5044-NE 5045, mai am 4 perechi, am si seturi de bobine pentru receptor, tot ce-ti trebuie!!!
Aceasta postare a fost editata de ipsihi: 07 February 2009 - 09:31 PM
#127 Useril este offline   crapu
  • Postari: 14
Postat 07 February 2009 - 09:31 PM
http://i44.tinypic.com/2d6qejn.jpg
#128 Useril este offline   crapu
  • Postari: 14
  Postat 07 February 2009 - 09:39 PM
mersi frumos
#129 Useril este offline   mariandmd
  • Postari: 2161
Postat 08 February 2009 - 01:00 AM
marfa...:D
are si turbo... e belea
#130 Useril este offline   cata1524
  • Postari: 12
  • Inregistrat: 27-January 09
Postat 08 February 2009 - 02:40 PM
salut la toata lumea, am si eu o intrebare are ceva daca acumulatoru sta culcat??? :wub: multumesc frumos
#131 Useril este offline   ipsihi
Postat 08 February 2009 - 03:08 PM
...are!!!
#132 Useril este offline   manolo
  • Postari: 3539
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 08 February 2009 - 03:36 PM
Ce ....are?Il apuca somnul?
Aceasta postare a fost editata de manolo: 08 February 2009 - 03:37 PM
Barcute intinse!
#133 Useril este offline   ipsihi
Postat 08 February 2009 - 03:38 PM
...sectioneaza un acumulator si o sa vezi singur!!!
#134 Useril este offline   manolo
  • Postari: 3539
  • Interests:Navo
Postat 08 February 2009 - 03:47 PM
Vezi postareaipsihi, la Feb 8 2009, 03:38 PM, a spus:
Nu-i nevoie sa stric un acumulator.Oricum am pus de o cafea.
Barcute intinse!
#135 Useril este offline   ipsihi
Postat 08 February 2009 - 04:09 PM
...culca-l si vezi ce se intampla, fenomenul ce deriva din alterarea pozitiei se poate observa si pe monitorul incarcatorului!!!
#136 Useril este offline   crapu
  • Postari: 14
Postat 08 February 2009 - 07:20 PM
http://i40.tinypic.com/2eykejd.jpg
#137 Useril este offline   crapu
  • Postari: 14
Postat 08 February 2009 - 07:22 PM
salutare,am gasit si ceva de putere intre 300 si 500 de mertri.Sa speram ca si functioneaza
#138 Useril este offline   mariandmd
  • Postari: 2161
Postat 08 February 2009 - 10:04 PM
Vezi postareaipsihi, la Feb 8 2009, 04:09 PM, a spus:
eu ii pun culcati acumulatorii
oricum stau in pozitie de somn doar cand sunt la peste
restul sta in picioare pe dulap
nu cred ca-i afecteaza daca stau culcati doar la partidele de pescuit sau numai cat se munceste cu barcuta
nu i-as pune sa stea culcati in permanenta.... sigur cred ca i-ar afecta
#139 Useril este offline   cata1524
  • Postari: 12
Postat 13 February 2009 - 07:32 PM
salut cum maresc parrghia la un servou sau sa cunpar are cineva sau de unde multumesc
#140 Useril este offline   harrina
  • Postari: 530
Postat 13 February 2009 - 10:29 PM
2 suruburi si o bucatica de ebonita,dural,tabla......ce ai pe aproape.
depinde pt ce ai nevoie,
faca lungesti bratul poate servomecanismul nu o sa aiba suficienta putere si strici jucaria.
#141 Useril este offline   cata1524
  • Postari: 12
Postat 14 February 2009 - 04:43 PM
ce parere avet asraE-FLY 100C, 6 canale, 35 MHz sau 40 MHz asta
Futaba T-4EX 4/6/1 FM 40 MHz sau asta
Futaba T-4EX 4/6/1 FM 35 MHz :wacko: satept parerile voastre multumesc
#142 Useril este offline   Bogdan B
  • ex ad525
  • Postari: 948
  • Inregistrat: 25-July 08
Postat 14 February 2009 - 04:45 PM
Vezi postareacata1524, la Feb 14 2009, 04:43 PM, a spus:
daca vrei ceva de calitate ia Futaba oricare ! E mult mai bun decat e-fly !
#143 Useril este offline   manolo
  • Postari: 3539
  • Interests:Navo
Postat 14 February 2009 - 04:57 PM
Futaba.
Barcute intinse!
#144 Useril este offline   mariandmd
  • Postari: 2161
Postat 14 February 2009 - 10:08 PM
graupner
  • 5 Pagini +
