Proiectul Y I need HELP!! F1 F1 F1
Postat 03 July 2008 - 09:22 AM
Prima intrebare : cam cati m2 mi'ar trebui ca sa fac ceva gen dulap3 70*25*20.
Cam atata pentru inceput , sper sa avansez repede.
Multumesc tuturor celor implicati.
Postat 03 July 2008 - 06:47 PM
spor la lucru
Bucuresti/Rahova
Postat 04 July 2008 - 12:51 AM
Postat 08 July 2008 - 02:42 PM
Material : Komatex plus 3mm
Dimensiuni : 70x30x20
1 http://img165.imageshack.us/img165/5809/37...37750067wf4.jpg
2 http://img378.imageshack.us/img378/4125/10...10770836as0.jpg
3 http://img205.imageshack.us/img205/9626/25...25113002wk9.jpg
4 http://img378.imageshack.us/img378/3883/81...81464057mv1.jpg
5 http://img378.imageshack.us/img378/2788/54...54979292wd5.jpg
6 http://img205.imageshack.us/img205/9438/22...22578736ws4.jpg
7 http://img378.imageshack.us/img378/1922/47...47651802su1.jpg
Postat 08 July 2008 - 06:46 PM
dar nu este cam inalta de prova ? cea facuta de tine ???? :blink:
Postat 08 July 2008 - 09:03 PM
Da ..e putin cam inalta... e pentru prima oara cand ma confrunt cu astfel de jucarie ... sper ca urmatoarea sa iasa mai bine ... asta e de proba .. sa fac nijte teste cu ea :blink:
Postat 08 July 2008 - 09:36 PM
o sa te cam chinui sa lucrezi la interior
#13
Postat 08 July 2008 - 09:47 PM
Poate si un test in cada sa vedem daca pluteste si nu ia apa la bord :wub:
#14
Postat 09 July 2008 - 07:56 AM
am sa ma apuc si eu de una si sper sa ma ajutati cu ceva sfaturi si critici.....ambele sunt bune !!!!
am sa fur si eu cate ceva de la toata lumea...!
intrebarea mea este ...daca ma apuc de constructia unei barci trebuie sa am deja piesele.....adica bateria mnotorul si restul......?????
#15
Postat 09 July 2008 - 08:03 AM
#16
Postat 09 July 2008 - 08:30 AM
#17
Postat 09 July 2008 - 01:14 PM
sunt si eu interesat !!!!
#18
Postat 09 July 2008 - 01:59 PM
#19
Postat 09 July 2008 - 09:16 PM
#20
Postat 09 July 2008 - 10:19 PM
Nowatiny, la 9 Jul 2008, 21:16, a spus:
cianoacrilat super adeziv da la den braven
#21
Postat 09 July 2008 - 10:50 PM
Tel. 0744915775
#23
Postat 10 July 2008 - 07:12 PM
adica cu adezivul cianoacrilat doar dai puncte ...pentru fixare...???
si cel de rezistenta....dai cordon...sau cum se procedeaza ???????
ms
#24
Postat 10 July 2008 - 08:32 PM
Tel. 0744915775
#25
Postat 10 July 2008 - 09:01 PM
Cand am bagat barca in apa pt teste , i'am pus si o caramida inauntru ca sa ajunga la nivelul dorit si am observat ca in unele locuri ia apa (numa din cauza foliei de plastic/kkmas pe ea ca nu are nici un rost) ... acuma m'am gandit sa cumpar un tub de silicon si sa torn pe la toate imbinaturile in exces sa acopere bine , sa fiu sigur ca nu o sa ma mai intalnesc cu o astfel de problema si sa o mai si chituiesc pe exterior bine dupa si o vopsea in cateva straturi ... asta ca sa fiu sigur.
Daca cineva a mai intampinaat problema asta si a avut o alta rezolvare rog sa'mi spuna si mie ...sau daca altineva are o alta idee mai bun astept cu drag ...
Maine o sa bag si cateva poze cu barcutza :)
Va multumesc!
#26
Postat 10 July 2008 - 09:26 PM
nu ????
bafta .....si te astept cu poze ......si poate ai si niste planuri salvate pe undeva sa le vad si eu .......
#27
Postat 10 July 2008 - 10:03 PM
Nu am nici o schita pur si simplu am facut totu dupa din cap si ceva mai mult din dulapurile lu marian http://www.rhcforum....tyle_emoticons/default/tongue.gif
#28
Postat 10 July 2008 - 10:14 PM
Nowatiny, la 10 Jul 2008, 21:01, a spus:
Maine o sa bag si cateva poze cu barcutza http://www.rhcforum....tyle_emoticons/default/tongue.gif
Va multumesc!
ma stric de ris,
credeam ca sint singurul fraier.
am cumparat GLAF de 500mm,cu gindul sa-mi fac si un mic dulapior la geamul de la bucatarie,
miine vin termonanele.
am decupat dulapiorul la fix,din plexic de 5mm.
l-am asamblat si l-am lipit pe GLAF-ul mult cautat.
l-am lipit cu SICOMET,
era beton.
ca orice roman cu simtul raspunderii,
zic sa-i mai dau o lipitura de siguranta cu GLUE GUN.
rezultatul,
a inceput sa se increteasca folia de protectie.
am inceput sa rid,apoi sa pling,apoi am luat-o de la capat.
oricum,dulapiorul e beton.
#29
Postat 10 July 2008 - 11:58 PM
Nowatiny, la 10 Jul 2008, 22:01, a spus:
Va multumesc!
MISTO, ca sa zic asa..... http://www.rhcforum....tyle_emoticons/default/tongue.gif Cum sa nu observi folia aia.... cum ai taiat piesele ? Tu le-ai taiat ? Se observa cel tarziu la taiere folia aia, de aceea intreb !
Vezi ca siliconul nu rezista la apa, daca imi este permis. Nu te lua dupa ce scrie pe specificatiile lui, crede-ma. Facem pariu daca vrei.
#30
Postat 11 July 2008 - 01:06 AM
MIRCIONE1, la 10 Jul 2008, 19:12, a spus:
ms
eu am lipit forexul cu superadeziv, iar la interior, de-alungul lipiturilor, am dat cu pensula un strat de adeziv pvc de la bison. cam scump, dar bun.
