HET TUCANO 700 MM
Postat 20 June 2008 - 08:47 AM
total mi-a esit la 390g....
am incercat si cu o elice pliabila insa nu se simte bine ...si fiind usurel nici la vant nu-i place ... :D
Postat 20 June 2008 - 08:50 AM
Postat 20 June 2008 - 08:54 AM
Postat 20 June 2008 - 08:58 AM
Postat 20 June 2008 - 09:01 AM
Postat 20 June 2008 - 09:03 AM
Postat 20 June 2008 - 09:28 AM
sper numa ca eleroanele o sa fie eficace, pentru ca nu sunt puse pe extremitatea aripiei.
Horia
Postat 20 June 2008 - 09:38 AM
eu am asa, ca hardware:
RX spektrum AR6200 10g
servo micro 2x9g 18g
variator 10A 10g (cu mufa "T", fara golduri de 3.5 intre motor si variator)
motor 2208-12T 36g
2s1p 850 mAH (25C) 57g (cu mufa "T")
con alu 30 mm+elice 6/5.5" 17g
____________________________
total R/C gear 148g
total gata de zbor: 342g
0728.26.93.19
Postat 20 June 2008 - 09:50 AM
8.8 Amp curent (aproape constant pe toata durata determinarii)
7.2 Volt in sarcina (cadere de tensiune 0.2 Volti, adica vax-albina)
aprox 63 Watt-in, din care calculat cu un randament de 87% raman la elice fo 55W
elice Graupner 6/5.5"
turatie elice la max: 8460 rpm/min, adica 141 rev/sec (Kv-motor = 1200 declarat, deci destul de aproape de adevar)
asta x pasul de 5.5" inseamna aprox 21 m/sec
adica, fo 75 km/h (calculat)
0728.26.93.19
Postat 20 June 2008 - 07:03 PM
Postat 21 June 2008 - 06:23 PM
http://www.youtube.c...h?v=OGZR55kYcsY
:) .....m-am indragostit de el !
Postat 21 June 2008 - 06:34 PM
Postat 23 June 2008 - 05:33 PM
pare insa greu de filmat in zbor...
0728.26.93.19
Postat 23 June 2008 - 06:25 PM
TUROK, la 21 Jun 2008, 18:34, a spus:
in manual zice asa
eleron up 8mm/ down 4mm (asta inseamna eleron diferential?)
profundor: 5mm up/ 5mm down
in ambele cazuri se recomanda expo
0728.26.93.19
Postat 23 June 2008 - 06:34 PM
IlPadrino, la 23 Jun 2008, 17:33, a spus:
Lasa comentariile ...de ce nu ai venit ...ca ai zis ca vii...si vedeam noi milimetrii si mililitrii... :D
Postat 26 June 2008 - 12:45 PM
da 8 sus si 4 jos pe eleroane ........
zboara impecabil mikutu .........
Postat 09 July 2008 - 12:26 PM
Postat 09 July 2008 - 12:57 PM
TUROK, la 9 Jul 2008, 12:26, a spus:
...mda,
cam asta avem acum
0728.26.93.19
#19
Postat 09 July 2008 - 01:25 PM
al meu a patit pana la urma cam acelasi lucru, dar i-am refacut partea din fata, pana la aripi, cu balsa de 3 mm. chiar pare mai rezistent decat modelul stock. parca mi-as mai lua unul, sa incerc si motorizarea cu axi 2208. mie mi-a iesit pe la 450 grame datorita motorului (inrunner 100 grame / 3000 kV) si acumulatorului de 1500 mA. sper sa se mai gaseasca, ca pe saitul producatorului am vazut ca modelul mic, 700, a disparut. Padrino, mai este?
#20
Postat 09 July 2008 - 01:41 PM
al meu avea fix 344 g gata de zbor
9 AMP x 7.8 V pe elice APC 8/3.8" (2S1P 850 mAh - 25C)
la greutatea asta CG-ul nu prea venea la punctul din manual, motiv pt care am mai pus 10g plumb in bot la decolare,
dupa care
l-am decolat gresit; asta e
oricum o sa rearanjez harnasamentul RC a.i. CG-ul sa vina unde tb. fara lest
da, este
0728.26.93.19
#21
Postat 09 July 2008 - 02:14 PM
Aceasta postare a fost editata de fulgerica: 09 July 2008 - 02:15 PM
