Modelism - RHC Forum: filme si poze aeriene - Modelism - RHC Forum
  • 55 Pagini +
  • 26
  • 27
  • 28
  • 29
  • 30
#811 Useril este offline   Zen
  • Postari: 1185
  • Inregistrat: 14-January 09
Postat 25 July 2010 - 08:48 PM
Nu prea cred ca poate sa ajunga praf pe ccd, e bine incapsulat.
Daca ar fi direct pe placa fotosensibila, punctul ar fi negru opac nu transparent. Transparenta sa dovedeste clar faptul ca se afla pe o lentila.
#812 Useril este offline   ilie F1A
  • Postari: 1249
  • Inregistrat: 17-April 09
Postat 25 July 2010 - 08:49 PM
Laur,frumos filmul si montajul,marea e intradevar neagra.Sper ca ai protejat aparatul de filmat in secventile in care apa loveste obiectivul.
#813 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 25 July 2010 - 09:39 PM
Vezi postareaZen, la Jul 25 2010, 09:48 PM, a spus:
ok, multumesc ,dar unde o pot duce la curatatpentru ca lentila este fixata prin insurubare si i-mi este frica daca o desfac nu mai pot focaliza dupa . camera este aceasta http://www.goprocame...=2&productid=31
Fotografie Aeriana
#814 Useril este offline   Wheelflyer
  • Members
  • Postari: 172
  • Inregistrat: 16-July 10
Postat 26 July 2010 - 01:07 AM
Superb filmul.
Felicitari !
#815 Useril este offline   Zen
  • Postari: 1185
Postat 26 July 2010 - 09:25 AM
Nu stiu unde o poti duce...
Uite un post de pe RCGroups:
"The camera's own lens is glass, and also coated with an infrared filter, and also glued into the threads. You need to open the camera body and use significant force to remove the stock lens, and you'd have delicate work with live video to a monitor to be able to put in a new lens and get it properly positioned for best focus. [...] I agree that GoPro's customer service has been great, and people should at least try that route"
Ca tot veni vorba de lentile, stie cineva unde pot gasi (in tara) lentile wide F.O.V. pentru camileo S10 ?
Aceasta postare a fost editata de Zen: 26 July 2010 - 09:28 AM
#816 Useril este offline   ALLEN
  • Postari: 3004
  • Inregistrat: 11-May 08
Postat 26 July 2010 - 09:47 AM
Laur, incearca la F64, il cauti pe Florin (sau oricare din baietii de la video) si te indruma ei catre un centru, sau chiar la ei in service.
sau la fotohobbyshop.ro
#817 Useril este offline   renatoa
Postat 26 July 2010 - 01:15 PM
Vezi postareaZen, la Jul 26 2010, 10:25 AM, a spus:
...Ca tot veni vorba de lentile, stie cineva unde pot gasi (in tara) lentile wide F.O.V. pentru camileo S10 ?
Eu am luat pentru Sony Webbie de pe eBay un set wide 0.67x + tele 2x, articolul 350245663070
Merge rezonabil in video, la foto ii altereza clar colturile. Are avantajul ca e mic, 4 grame si se ataseaza rapid cu magnet.
Numai ca webbie are o deschidere foarte mica a lentilei, similara cu un webcam, sau un celular, nu stiu S10 cat de mare are deschiderea. La noi exista ceva produs de raynox, destul de mari si incomode, si cam scumpe.
#818 Useril este offline   Zen
  • Postari: 1185
Postat 26 July 2010 - 08:36 PM
Vezi postarearenatoa, la Jul 26 2010, 02:15 PM, a spus:
Pai cat sa aiba,tot cam cat un celular. Merge?
  • Imagine atasata: toshiba_camileo_s10_1.jpg
#819 Useril este offline   renatoa
Postat 26 July 2010 - 08:50 PM
Ai localizat pe eBay ce am luat eu ?
Lentila posterioara are diametrul de 9mm, acopera fata lentilei de la S10?
De fapt... mi se pare ca si la tine este la fel ca la webbie, vad acolo un geam plan de protectie, lentila fiind in interior, si probabil fiind mai mica...
#820 Useril este offline   bogdyys
  • Postari: 531
  • Inregistrat: 20-October 08
Postat 26 July 2010 - 08:57 PM
Vezi postareaZen, la Jul 26 2010, 09:36 PM, a spus:
Hama Digital Objektiv HR 0,5, Magnet, 22 mm
Cred ca asa ceva iti trebuie(posibil sa ma insel insa)
FOREVER YOUNG.......
#821 Useril este offline   Zen
  • Postari: 1185
Postat 26 July 2010 - 09:02 PM
Inseamna ca merge. Am incercat eu sa fac un sistem wide din 2 convergente si o divergenta ce le aveam, iar lentila posterioara de vreo 5mm acoperea suficient obiectivul (desigur nu am obtinut claritate satisfacatoare din cauza calitatii lentilelor).
P.S.
Vezi postareabogdyys, la Jul 26 2010, 09:57 PM, a spus:
Cam bulky (42g) , aceeasi problema ca si la raynox(110g) .
Cred ca am sa optez pentru ce a luat renatoa.
Aceasta postare a fost editata de Zen: 26 July 2010 - 09:09 PM
#822 Useril este offline   renatoa
Postat 26 July 2010 - 09:52 PM
Vezi postareaZen, la Jul 26 2010, 10:02 PM, a spus:
...Cam bulky (42g) , aceeasi problema ca si la raynox(110g) ...
Am gasit asta pe rcgroups, 4 diverse solutii pt S10, una pare foarte aproape de ce am eu:
http://www.rcgroups....d.php?t=1145519
Vad ca Raynox QC-707 de care vorbesc ei nu ar fi asa grea, are 28 grame, dar la 50mm diametru lentiei frontale, si 27mm filetul de prindere pe obiectiv, mi se pare imensa.
#823 Useril este offline   dramida
  • Postari: 599
  • Inregistrat: 05-November 08
  • Interests:filmari si fotografie aeriana, fpv
Postat 26 July 2010 - 11:43 PM
antrenament
Pentru secventele de pe plaja pregatesc un montaj mai special ;)
Aceasta postare a fost editata de dramida: 26 July 2010 - 11:47 PM
#824 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
  • Inregistrat: 03-February 07
  • Interests:AEROMODELISM
Postat 27 July 2010 - 05:32 PM
Darmida ! ...frumos nu pot spune NU! ....dar de ce ai numit tu ANTRENAMENT ?
As dori sa aprofundezi putin ceea ce ai facut tu acolo .SA nu porti pica acum pe mine insa eu nu as numi asa .........
ESTE CAM APOCALIPTIC TREABA ASTA ! ;)
ABIA ASTEPT SA VAD CE AI FACUT PE PLAJA ......KAMIKAZE! :)
Aceasta postare a fost editata de TUROK: 27 July 2010 - 05:41 PM
ADOR VITEZA!!!
#825 Useril este offline   renatoa
Postat 27 July 2010 - 07:01 PM
Pai... antrenament de taiat niste capete :)
Aceasta postare a fost editata de renatoa: 27 July 2010 - 07:02 PM
#826 Useril este offline   Abburo
  • Postari: 1317
  • Inregistrat: 02-June 07
  Postat 27 July 2010 - 07:03 PM
Pregatesc si eu un montaj din statia de metrou din Victoriei la ora 18.
Aceasta postare a fost editata de Abburo: 27 July 2010 - 07:04 PM
#827 Useril este offline   renatoa
Postat 28 July 2010 - 08:14 AM
Cum ziceam, colegul dramida va avea o vreme probleme cu accesul la internet, asa ca la rugamintea lui postez aici filmul de pe plaja.
http://www.youtube.c...h?v=LzvcWyUPoXY
#828 Useril este offline   Wheelflyer
  • Members
  • Postari: 172
Postat 29 July 2010 - 11:54 AM
O intrebare am si eu....
Aceste filmate au fost facute in FPV sau doar onboard camera ?
#829 Useril este offline   takeoff
  • Postari: 1029
  • Inregistrat: 25-July 08
Postat 29 July 2010 - 03:14 PM
Vezi postareaArtelian, la Jul 29 2010, 12:54 PM, a spus:
Nu sunt fpv,atat mai trebuia,ca dramida sa mai zboare si cu ochelari pe aglomeratia aia.Cred ca FPV e mai usor de folosit decat onboard camera (cuvantul)
#830 Useril este offline   bogdyys
  • Postari: 531
Postat 30 July 2010 - 10:51 AM
Postez si eu doua din primele mele fotografii aeriene(doua din opt) :) .Emotiile primului pas se fac resimtite insa in calitate.......dar fericirea reusitei mele ma face sa incerc sa merg mai departe(asta daca reusesc sa descopar setup-ul perfect la heli) :) .Prima fotografie nu pare,dar chiar este aeriana :) ,cred ca de pe la 5 metri doar,iar a doua este facut la revenire spre locul de aterizare.
Imagine atasata: 2__Large_.JPG
Imagine atasata: 1__Large_.JPG
Pozele sunt facute cu un LX3(fara sa fie insa setat corect in acel moment)montat pe un suport home made la un T-rex 600,si bineinteles cu ajutorul sotiei pe post de operator foto,nu am si nici nu o sa pun un sistem de stabilizare pe heli.
Aceasta postare a fost editata de bogdyys: 30 July 2010 - 10:51 AM
#831 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 30 July 2010 - 08:36 PM
Vezi postareabogdyys, la Jul 30 2010, 11:51 AM, a spus:
Postez si eu doua din primele mele fotografii aeriene(doua din opt) :D .Emotiile primului pas se fac resimtite insa in calitate.......dar fericirea reusitei mele ma face sa incerc sa merg mai departe(asta daca reusesc sa descopar setup-ul perfect la heli) :lol: .Prima fotografie nu pare,dar chiar este aeriana :lol: ,cred ca de pe la 5 metri doar,iar a doua este facut la revenire spre locul de aterizare.
felicitari , ai facut o alegere buna folosind LX3, nu te va trada niciodata .Eu majoritatea pozelor le-am facut utilizind setarea IA.
este un aparat foarte bun pentru fotografie aeriana dar si pentru orice fel de fotografie.
  • Imagine atasata: P1290053.jpg
Fotografie Aeriana
#832 Useril este offline   bogdyys
  • Postari: 531
Postat 01 August 2010 - 11:03 AM
Vad ca nu se vad la dimensiunea urcata cele doua foto,mai incerc o data.
@ Laur73 ... Multumesc !
http://i624.photobucket.com/albums/tt329/bogdyys/AP/P1020590.jpg
http://i624.photobucket.com/albums/tt329/bogdyys/AP/P1020585.jpg
#833 Useril este offline   dramida
  • Postari: 599
Postat 01 August 2010 - 09:38 PM
Tricopter fpv cu osd-ul defect, pe ploaie.
Aceasta postare a fost editata de dramida: 01 August 2010 - 09:38 PM
#834 Useril este offline   dramida
  • Postari: 599
Postat 02 August 2010 - 05:57 PM
La pas pe strazile din Eforie Sud. Briza adia destul de puternic dupa cum se vede in frunzele copacilor.
Am ajuns la concluzia ca tricopter-ul se piloteaza mult mai lin in mod fpv, desi nu ai aceiasi perspectiva.
Aceasta postare a fost editata de dramida: 02 August 2010 - 06:01 PM
#835 Useril este offline   renatoa
Postat 02 August 2010 - 06:28 PM
Acum sincer, o sa postezi si cand o sa lovesti pe cineva ?
Pt mine e o chestie certa, problema nu e daca, ci cat de curand va fi...
Aceasta postare a fost editata de renatoa: 02 August 2010 - 06:30 PM
#836 Useril este offline   dramida
  • Postari: 599
Postat 02 August 2010 - 07:23 PM
Stii cum fac aia de la Myth Busters teste pe manechine? am sa fac si eu un test sa vad ce damage face tricopter-ul in hower si in cadere libera de la 5-10 metrii.
Oricum, pilotez bine tri-ul, de cand l-am construit, l-am pilotat zilnic, am avut un near miss cu un tip de la BGS in parcul trandafirilor din IOR, nu stiu de unde a aparut, era parcul gol si el se plimba agale....l-am evitat in timp ce tri-ul era cu fata catre mine, cu comenzile inversate. Nici nu si-a dat seama ce ia trecut prin spate...
Vezi postarearenatoa, la Aug 2 2010, 07:28 PM, a spus:
Aceasta postare a fost editata de dramida: 02 August 2010 - 07:34 PM
#837 Useril este offline   takeoff
  • Postari: 1029
Postat 02 August 2010 - 07:33 PM
Vezi postareadramida, la Aug 2 2010, 08:23 PM, a spus:
oricum, pilotez bine tri-ul, de cand l-am construit, l-am pilotat zilnic.
Lasa gluma si nu mai zbura in locuri populate,eu am vazut ce a facut un hbk2,la tricopterul tau nici nu vreau sa ma gandesc.
#838 Useril este offline   dramida
  • Postari: 599
Postat 02 August 2010 - 08:28 PM
are elicie cu diam de 11 inch si motorul sta turat aprox la 50%, undeva la 6 amp / motor. Intelegi care e diferenta?
Vezi postareatakeoff, la Aug 2 2010, 08:33 PM, a spus:
Aceasta postare a fost editata de dramida: 02 August 2010 - 08:28 PM
#839 Useril este offline   Abburo
  • Postari: 1317
Postat 02 August 2010 - 08:44 PM
Dramida, acum serios... daca vezi un papuc "near miss" sa stii ca al doilea va fi din plin in tri... si la fel nu vei sti de unde au sarit... asta daca il vad personal vreodata prin zone populate evident... oricati 6A zici tu ca ai in nu's'ce elice ...
Eu m-am dat cu un planorel nemotorizat din spuma, aruncat din mana.. doar 300g in IOR... si tot nu m-am simtit prea bine... d-apai tu cu tri' motoare...
Cred ca am vazut cu totii ca esti "bun"...
Diferenta e urmatoarea... noi ca modelisti/zburatori ne asumam niste riscuri. Oamenii din parc/strazi nu si le asuma si pe buna dreptate. Hai sa respectam dorintele fiecaruia...
Aceasta postare a fost editata de Abburo: 02 August 2010 - 08:48 PM
#840 Useril este offline   ALLEN
  • Postari: 3004
Postat 02 August 2010 - 09:04 PM
Abburo, tu chiar nu intelegi? 6A... pfuu e greu frate, nu vezi diferenta? auzi la tine, sa dai cu papucu... pai e mai mare pacatul de papuc...
acu serios, omul vrea sa fie in centrul atentiei, sa se afirme, daca nu ca cameraman, (va rog nu-mi scuzati cacofonia), macar ca personaj. asta pana s-o trezi unu sa-i crape capul ca i-a violat intimitatea ca l-a filmat cu ventilatorul, sau ca i-a speriat puradelul.
sau mai rau, ii da vreunuia cu elica aia ce trage 6A in cap si atunci sa vezi omor ce-si ia.
  • 55 Pagini +
  • 26
  • 27
  • 28
  • 29
  • 30
12 useri citesc topicul
