Modelism - RHC Forum: Motoare electrice aero - Modelism - RHC Forum
Motoare electrice aero brushless outrunner de 2.5Kg - 3Kg
#61 Useril este offline   alexvid
  • Postari: 1494
  • Inregistrat: 30-April 08
Postat 15 September 2009 - 02:26 PM
C4260/06 90RON
C3548/06 70RON
UP
#62 Useril este offline   alexvid
  • Postari: 1494
Postat 24 September 2009 - 11:01 AM
C4260/06 90RON
C3548/06 70RON
UP
#63 Useril este offline   alexvid
  • Postari: 1494
Postat 14 October 2009 - 03:13 PM
C4260/06 90RON
C3548/06 70RON
UP
#64 Useril este offline   alexvid
  • Postari: 1494
Postat 03 November 2009 - 11:54 AM
C4260/06 90RON
C3548/06 70RON
UP
#65 Useril este offline   alexvid
  • Postari: 1494
Postat 03 December 2009 - 10:34 AM
C4260/06 90RON
C3548/06 70RON
UP
#66 Useril este offline   alexvid
  • Postari: 1494
Postat 29 January 2010 - 03:43 PM
C4260/06 90RON
C3548/06 70RON
UP
#67 Useril este offline   ViorelX
  • Postari: 537
  • Inregistrat: 06-October 09
Postat 29 January 2010 - 05:11 PM
Da-mi mie motorul C3548, dar cu tot cu regulatorul acela de 70lei.
#68 Useril este offline   alexvid
  • Postari: 1494
Postat 30 January 2010 - 12:41 AM
Vezi postareaViorelX, la Jan 29 2010, 05:11 PM, a spus:
Nu mai am regulatorul .
#69 Useril este offline   alexvid
  • Postari: 1494
Postat 30 January 2010 - 10:54 AM
3548 rezervat
#70 Useril este offline   alexvid
  • Postari: 1494
Postat 05 March 2010 - 06:05 PM
C4260/06 90RON
Optional si regulator Hobbyking SS Series 90-100A ESC fara BEC 95RON
Spec.
Weight: 85g
Cells: 2-7S Li Po
Max Current: 90A
Burst : 100A
No BEC
Timing: 1/7/15/30 programmable
PWM: 8/16K
Features.
Constant current 90A Max 100A <10S
Li-Poly 2-7 cells
Dynamic Braking
BEC: opto
Auto shut down when lose signal
Slow down at 3.0V per cell Lipo, Cut-off at 2.9V per cell Lipo 0.8V NiMh
User Programming options.
Battery settimg
Throttle Rnage
Brake settimg 4 options:
Direction and Cutoff Type
Timing Mode Setting: 1 / 7 / 15 / 30
PWM setting: 8K/16K
Aceasta postare a fost editata de alexvid: 05 March 2010 - 06:07 PM
#71 Useril este offline   george10
  • Postari: 1298
  • Inregistrat: 08-August 07
  • Interests:Modelism
    Foto
  Postat 05 March 2010 - 11:15 PM
Vezi postareaalexvid, la Mar 5 2010, 06:05 PM, a spus:
C4260/06 90RON
Spec.
Weight: 85g
Cells: 2-7S Li Po
Max Current: 90A
Burst : 100A
No BEC
PWM: 8/16K
Features.
Li-Poly 2-7 cells
Dynamic Braking
BEC: opto
Battery settimg
Throttle Rnage
PWM setting: 8K/16K
Vreau eu regulatorul!vorbim pe privat!
Cu Stima George J.
tel.0724686263
#72 Useril este offline   george10
  • Postari: 1298
    Foto
  Postat 15 March 2010 - 11:01 PM
Vezi ca ai mesageria plina! ;)
Cu Stima George J.
tel.0724686263
#73 Useril este offline   george10
  • Postari: 1298
    Foto
Postat 17 March 2010 - 10:05 PM
A ajuns cu bine!Nersic :D !
Cu Stima George J.
tel.0724686263
#74 Useril este offline   alexvid
  • Postari: 1494
Postat 07 April 2010 - 02:30 PM
C4260/06 90RON
Optional si regulator Hobbyking SS Series 90-100A ESC fara BEC 80RON la mana a 2-a.
L-am folosit la teste pe elicopter clasa 500, dar are startul prea brusc, prin urmare am pus unul cu specificatii pentru elicopter.
Are mufele puse (deans catre baterie si 3.5mm catre motor) si adaptor JST pentru BEC extern.
Spec.
Weight: 85g
Cells: 2-7S Li Po
Max Current: 90A
Burst : 100A
No BEC
PWM: 8/16K
Features.
Li-Poly 2-7 cells
Dynamic Braking
BEC: opto
Battery settimg
Throttle Rnage
PWM setting: 8K/16K
Aceasta postare a fost editata de alexvid: 07 April 2010 - 02:32 PM
#75 Useril este offline   alexvid
  • Postari: 1494
Postat 29 April 2010 - 12:09 PM
motor C4260/06 90RON
#76 Useril este offline   alexvid
  • Postari: 1494
Postat 10 May 2010 - 09:36 AM
#77 Useril este offline   cristila65
  • Postari: 35
  • Inregistrat: 13-May 08
Postat 10 May 2010 - 06:20 PM
Vezi postareaalexvid, la May 10 2010, 10:36 AM, a spus:
Un pret "la pachet" motorul si regulatorul , se poate?
#78 Useril este offline   alexvid
  • Postari: 1494
Postat 27 May 2010 - 01:54 PM
cu regulator +95RON Hobbyking SS Series 90-100A ESC FARA BEC
#79 Useril este offline   alexvid
  • Postari: 1494
Postat 07 June 2010 - 09:08 PM
- motor C4260/06 90RON
- motor + regulator nou =180RON (Hobbyking SS Series 90-100A ESC FARA BEC descrierea mai sus)
Aceasta postare a fost editata de alexvid: 07 June 2010 - 09:08 PM
#80 Useril este offline   alexvid
  • Postari: 1494
Postat 03 July 2010 - 05:23 PM
#81 Useril este offline   alexvid
  • Postari: 1494
Postat 22 July 2010 - 09:23 AM
#82 Useril este offline   mirceav
  • Postari: 83
  • Inregistrat: 16-May 10
Postat 25 July 2010 - 03:45 PM
Vezi postareaalexvid, la Jul 22 2010, 10:23 AM, a spus:
ma tot chinui sa aflu cum ar functiona fara BEC aeromodelul,adica cum ar fi facute legaturile electrice pe receptor?
Though I Fly Through the Valley of Death, I Shall Fear No Evil. For I am at 80000 Feet and Climbing.....si..m-am trezit!!!
#83 Useril este offline   alexvid
  • Postari: 1494
Postat 25 July 2010 - 05:39 PM
Vezi postareamirceav, la Jul 25 2010, 04:45 PM, a spus:
Regulatoarele mari peste 40A, de obicei nu au BEC (exista si exceptii).
In cazul asta, inseamna ca trebuie sa ai tu sau sa cumperi BEC.
In receptor, nu ai voie sa bagi peste 6V.
Succes
#84 Useril este offline   mirceav
  • Postari: 83
Postat 25 July 2010 - 07:31 PM
Deci asta ar insemna ca de la receptor,in acest caz,regulatorul primeste doar comanda(un soi de semnal analogic,cred),nu?Unul din cele trei fire care sunt in mod normal in conectorul de la ESC n-ar mai fi.In cazul asta,BEC-ul ar fi alimentat separat(alt acumulator)?Sau din acelasi acumulator,el avand doar rolul de a regla curentul care intra in receptor?Sau se poate in ambele moduri?In cazul asta,receptorul ar avea un canal pentru ESC si unul pentru BEC?
Iti multumesc pentru luminare,inca descopar domeniul asta!
#85 Useril este offline   mirceav
  • Postari: 83
Postat 25 July 2010 - 07:32 PM
Vezi postareaalexvid, la Jul 25 2010, 06:39 PM, a spus:
Succes
Si cei 6 V de care spui,pot ajunge la 7,4 V,ca servo-urile merg pana la 7,4 de obicei,nu?
#86 Useril este offline   alexvid
  • Postari: 1494
Postat 05 August 2010 - 11:25 AM
Aceasta postare a fost editata de alexvid: 05 August 2010 - 11:26 AM
#87 Useril este offline   roibu
  • Postari: 20
  • Inregistrat: 30-July 10
Postat 05 August 2010 - 09:29 PM
ma intereseaza, ia legatura cu mine pe 0724395427 sau mail pe marinaru56@yahoo.com
#88 Useril este offline   alexvid
  • Postari: 1494
Postat 29 August 2010 - 09:42 AM
#89 Useril este offline   alexvid
  • Postari: 1494
Postat 05 October 2010 - 12:08 PM
#90 Useril este offline   alexvid
  • Postari: 1494
Postat 14 October 2010 - 04:26 PM
34 useri citesc topicul
0 membri, 34 vizitatori, 0 utilizatori anonimi
