Modelism - RHC Forum: Motoare electrice aero - Modelism - RHC Forum
Motoare electrice aero brushless outrunner de 2.5Kg - 3Kg
#31 Useril este offline   alexvid
  • Postari: 1494
  • Inregistrat: 30-April 08
Postat 11 December 2008 - 08:55 PM
Inca o reducere :
C4260/06 110RON
C3548/06 85RON
#32 Useril este offline   alexvid
  • Postari: 1494
Postat 18 December 2008 - 12:31 PM
UP
C4260/06 110RON
C3548/06 85RON
#33 Useril este offline   alexvid
  • Postari: 1494
Postat 28 December 2008 - 07:03 PM
UP
C4260/06 110RON
C3548/06 85RON
#34 Useril este offline   alexvid
  • Postari: 1494
Postat 11 January 2009 - 12:59 PM
UP
C4260/06 110RON
C3548/06 85RON
#35 Useril este offline   alexvid
  • Postari: 1494
Postat 01 February 2009 - 02:39 PM
UP
C4260/06 100RON
C3548/06 80RON
#36 Useril este offline   iulian207
  • Postari: 94
  • Inregistrat: 17-October 08
Postat 01 February 2009 - 08:24 PM
sal.ma intereseaza mototul de 900w.ym: iulian207
#37 Useril este offline   alexvid
  • Postari: 1494
Postat 13 February 2009 - 10:54 PM
C4260/06 100RON
C3548/06 80RON
#38 Useril este offline   alexvid
  • Postari: 1494
Postat 20 February 2009 - 12:04 PM
C4260/06 100RON
C3548/06 80RON
UP
#39 Useril este offline   alexvid
  • Postari: 1494
Postat 03 March 2009 - 05:16 PM
C4260/06 100RON
C3548/06 80RON
sau
C4260/06 + ESC 60A Mystery opto(fara bec) 170RON
C3548/06 + ESC 60A Mystery opto(fara bec) 150RON
UP
#40 Useril este offline   alexvid
  • Postari: 1494
Postat 10 March 2009 - 09:45 PM
C4260/06 100RON
C3548/06 80RON
sau
UP
#41 Useril este offline   alexvid
  • Postari: 1494
Postat 18 March 2009 - 11:51 AM
C4260/06 100RON
C3548/06 80RON
sau
UP
#42 Useril este offline   alexvid
  • Postari: 1494
Postat 30 March 2009 - 06:53 PM
C4260/06 100RON
C3548/06 80RON
sau
UP
#43 Useril este offline   george10
  • Postari: 1298
  • Inregistrat: 08-August 07
  • Interests:Modelism
    Foto
  Postat 08 April 2009 - 10:40 AM
Vezi postareaalexvid, la Mar 30 2009, 07:53 PM, a spus:
C4260/06 100RON
C3548/06 80RON
sau
UP
vezi ca ai pm!
Cu Stima George J.
tel.0724686263
#44 Useril este offline   alexvid
  • Postari: 1494
Postat 16 April 2009 - 01:58 PM
C4260/06 100RON
C3548/06 80RON
sau
UP
#45 Useril este offline   alexvid
  • Postari: 1494
Postat 24 April 2009 - 06:45 PM
UP and running <_<
C4260/06 100RON
C3548/06 80RON
sau
#46 Useril este offline   alexvid
  • Postari: 1494
Postat 03 May 2009 - 12:20 PM
UP
C4260/06 100RON
C3548/06 80RON
sau
#47 Useril este offline   alexvid
  • Postari: 1494
Postat 12 May 2009 - 11:56 AM
UP
C4260/06 100RON
C3548/06 80RON
sau
se poate adauga si bec 30ron UBEC hexTronik 5/6V 3A
Specifications;
Output: 5v/3a & 6v/3a (Selectable via jumper)
Ripply: <50mVp-p(@2A/12V)
Input: 5.5v~23v (2 to 6s)
Weight: 12.5g
#48 Useril este offline   alexvid
  • Postari: 1494
Postat 22 May 2009 - 10:23 AM
UP
C4260/06 100RON
C3548/06 80RON
ESC nu mai am
#49 Useril este offline   alexvid
  • Postari: 1494
Postat 01 June 2009 - 01:55 PM
UP
C4260/06 100RON
C3548/06 80RON
Sau cu regulator SuperSimple 70A (+70RON)
Specificatii regulator:
Weight: 63g
Cells: 12-24Ni MH ~ 4-8S Li Po
Constant Current: 70A
Max Current: 80A
No BEC
Timing: 1/7/15/30 programmable
PWM: 8/16K
Features.
Constant current 70A Max 85A <10S
Li-Poly 4-8 cells Ni-MH 12-24 cells
Low Resistant 0.0017 Ohms;
Dynamic Braking
BEC: opto
Auto shut down when lose signal
Slow down at 3.0V per cell Lipo, Cut-off at 2.9V per cell Lipo 0.8V NiMh
User Programming options.
Battery settimg
Throttle Range
Brake settimg 4 options:
Direction and Cutoff Type
Timing Mode Setting: 1 / 7 / 15 / 30
PWM setting: 8K/16K
Note:
This ESC is OPTO, with no BEC supplying power to your receiver.
You will need an extra power source for your receiver.
If you hear the music tone repeat for more than 3 times,
you may need to check your power source to the receiver.
Aceasta postare a fost editata de alexvid: 01 June 2009 - 01:56 PM
#50 Useril este offline   alexvid
  • Postari: 1494
Postat 10 June 2009 - 10:11 AM
UP
C4260/06 100RON
C3548/06 80RON
vezi mai sus descrierea
#51 Useril este offline   alexvid
  • Postari: 1494
Postat 18 June 2009 - 06:32 PM
UP
C4260/06 90RON
C3548/06 70RON
#52 Useril este offline   alexvid
  • Postari: 1494
Postat 30 June 2009 - 11:36 AM
UP
C4260/06 90RON
C3548/06 70RON
#53 Useril este offline   alexvid
  • Postari: 1494
Postat 09 July 2009 - 09:59 AM
UP
C4260/06 90RON
C3548/06 70RON
#54 Useril este offline   alexvid
  • Postari: 1494
Postat 16 July 2009 - 11:54 AM
C4260/06 90RON
C3548/06 70RON
#55 Useril este offline   alexvid
  • Postari: 1494
Postat 31 July 2009 - 11:50 AM
UP
C4260/06 90RON
C3548/06 70RON
#56 Useril este offline   george10
  • Postari: 1298
    Foto
  Postat 31 July 2009 - 10:13 PM
Vezi postareaalexvid, la Jul 31 2009, 12:50 PM, a spus:
UP
C4260/06 90RON
C3548/06 70RON
Un pret pt :C3548/06 cu regulatorul aferent?pune te rog un nr de tel.pe privat !
Cu Stima George J.
tel.0724686263
#57 Useril este offline   alexvid
  • Postari: 1494
Postat 13 August 2009 - 02:52 PM
UP
C4260/06 90RON
C3548/06 70RON
#58 Useril este offline   dumi 031
  • Postari: 236
  • Inregistrat: 01-August 08
Postat 13 August 2009 - 09:01 PM
Vezi postareaalexvid, la Aug 13 2009, 03:52 PM, a spus:
UP
C4260/06 90RON
C3548/06 70RON
salut . barosane care-i mai chitros eu sau tu ,te chinui sa vinzi o gramada de chestii de un an jumate . s-a luat cineva de tine . te-ai suparat?ps . avionul zboara cu un esc de 18 a .imprumutat si vroiam sa-i cumpar celui care mi-a imprumutat escul unul nou de 20 a . te-am intrebat daca ai unul de 20 a si ai zis ca nu ai .si aici si pe "ocazii" ai niste preturi super mari. mai gandeste cand faci comentarii !!!!!!!!!!!!!!
#59 Useril este offline   alexvid
  • Postari: 1494
Postat 14 August 2009 - 03:01 PM
O parere personala ! Am inteles asta si o respect!
Mult succes in achizitii cat mai ieftine si succes in continuare!
#60 Useril este offline   alexvid
  • Postari: 1494
Postat 04 September 2009 - 03:26 PM
C4260/06 90RON
C3548/06 70RON
UP
26 useri citesc topicul
