Modelism - RHC Forum: MOCA - Modelism - RHC Forum
  • 51 Pagini +
  • 14
  • 15
  • 16
  • 17
  • 18
MOCA Donatii de la modelisti pentru modelisti
#451 Useril este offline   icepatoru'
  • Postari: 304
  • Inregistrat: 15-August 08
Postat 27 August 2009 - 02:01 PM
Vreau eu jantele
Aceasta postare a fost editata de icepatoru': 27 August 2009 - 02:02 PM
#452 Useril este offline   cataWRC
  • Postari: 1486
  • Inregistrat: 27-December 02
Postat 27 August 2009 - 02:07 PM
Ok, ale tale sunt. Astept sa ma contactezi.
#453 Useril este offline   cataWRC
  • Postari: 1486
Postat 27 August 2009 - 08:57 PM
Sursa pleaca la Borz_Florin
#454 Useril este offline   dragos243
  • Postari: 879
  Postat 28 August 2009 - 11:24 AM
Vezi postareacataWRC, la Aug 27 2009, 09:57 PM, a spus:
daca nu s-au dat jantele le vreau eu!
#455 Useril este offline   cataWRC
  • Postari: 1486
Postat 28 August 2009 - 01:40 PM
Sunt rezervate pentru incepatoru'. Daca prin absurd nu le ia el, sunt ale tale.
#456 Useril este offline   -caTo-
  • Postari: 562
  • Inregistrat: 25-February 09
  • Interests:discussion
  Postat 29 August 2009 - 12:39 AM
Vezi postareacataWRC, la Aug 28 2009, 02:40 PM, a spus:
Daca cei de sus vor renunta la jante le vreu eu.
#457 Useril este offline   cataWRC
  • Postari: 1486
Postat 29 August 2009 - 02:20 PM
OK! Am notat si asta.
#458 Useril este offline   dramida
  • Postari: 599
  • Inregistrat: 05-November 08
  • Interests:filmari si fotografie aeriana, fpv
Postat 29 August 2009 - 02:23 PM
Giroscop Gy400 clona futaba 401 folosit pe eleroane la planor in mod rate si primit de la takeoff tot moca
Se ridica personal din Bucuresti, zona Titan-Auchan
caracteristici:
Control System :
Digital advanced PI (Proportional Integration) Control
Gyro sensor:
SMM (Silicon Micro Machine) system vibration gyro
Operating voltage:
+4 to +6VDC
Operating temperature range:
-10 degree to +45 degree
Function:
Gyro operation direction switch, Control delay trimmer, Limit trimmer Remote gain control, AVCS/normal mode switching
Dimensions:
21.8 X 21.8 X 19.00mm
Weight:
15g (including connector)
manualul poate fi downloadat de aici: http://www.rvminc.ne...s/rcps61801.pdf
Aceasta postare a fost editata de dramida: 29 August 2009 - 02:23 PM
#459 Useril este offline   furios
  • RAPTOR
  • Postari: 1172
  • Inregistrat: 30-May 08
  • Interests:Heli
Postat 29 August 2009 - 02:30 PM
Vezi postareadramida, la Aug 29 2009, 02:23 PM, a spus:
caracteristici:
Control System :
Gyro sensor:
Operating voltage:
+4 to +6VDC
Function:
Dimensions:
Weight:
Daca se poate,il iau eu sambata viitoare la 3D.....sau poate te grabesti sa scapi de el
T-REX 500 PRO
T-REX 600N/OS55HZ-R
T-REX 700X
T-REX 800 TOURBINE
RAPTOR 90 SE gasser
HENSELEIT 3DNT
Save the flybar !!
#460 Useril este offline   itoncu
  • Postari: 50
  • Inregistrat: 31-July 09
Postat 29 August 2009 - 02:32 PM
Vezi postareadramida, la Aug 29 2009, 03:23 PM, a spus:
caracteristici:
Control System :
Gyro sensor:
Operating voltage:
+4 to +6VDC
Function:
Dimensions:
Weight:
... Sa il ia cineva caruia ii trebuie cu adevarat! Bravo tie!
#461 Useril este offline   furios
  • RAPTOR
  • Postari: 1172
  • Interests:Heli
Postat 29 August 2009 - 02:39 PM
mersi
T-REX 500 PRO
T-REX 600N/OS55HZ-R
T-REX 700X
T-REX 800 TOURBINE
RAPTOR 90 SE gasser
HENSELEIT 3DNT
Save the flybar !!
#462 Useril este offline   blackheart
  • Postari: 113
  • Inregistrat: 28-May 09
Postat 05 September 2009 - 12:40 PM
Motor Brushless de 30A cu axul foarte putin indoit(nici nu e nevoie de schimbare ax). A venit cu un Acrobat RTF care acum nu mai exista. Trage in jur de 1kg.
Statie 72MHz 4 Canale Mode 2 fara antena si fara capac la locul unde se pun bateriile. Am si quartz la ea 72.210. Statia este de la TMPro, modelul Quest-4. Asta este statia. http://www.topmodelproduction.com/picselec...RTF-set-1-1.jpg
Prefer sa vina cineva sa le ia din Craiova, dar daca nu se poate si aveti nevoie o sa le trimit.
Toate cele bune.
#463 Useril este offline   Zeus
  • Postari: 2455
  • Inregistrat: 15-January 09
Postat 05 September 2009 - 12:49 PM
ptrr statie ma abonez, eu plssss
#464 Useril este offline   scimitar
  • Postari: 293
  • Inregistrat: 04-July 08
Postat 05 September 2009 - 12:54 PM
ma inscriu si eu la motor pls
Aceasta postare a fost editata de scimitar: 05 September 2009 - 12:59 PM
#465 Useril este offline   vgeorge
  • Membru Fondator MDT
  • Postari: 2700
  • Inregistrat: 31-August 09
Postat 05 September 2009 - 01:50 PM
daca se renunta la statie, as dori-o eu daca se poate.multumesc
Racing
-Mugen MBX5T - truggy nitro
-Mugen MBX6 - buggy nitro
-Kyosho MR03 - 1/28 box stock
-GLR racing - 1/28 mod
[center]Club
C.S.T.A. Bucuresti
#466 Useril este offline   incepatoru
  • Postari: 2863
  • Inregistrat: 30-May 09
  • Interests:aero
Postat 05 September 2009 - 06:15 PM
vreau eu motorul ...please e tocmai ce-mi trebuie ....
#467 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3622
  • Inregistrat: 09-June 07
Postat 05 September 2009 - 09:35 PM
Daca renunta ceilalti 2 la motor eu o sa fiu al treilea.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#468 Useril este offline   blackheart
  • Postari: 113
Postat 05 September 2009 - 10:56 PM
SORRY, motorul s-a dat cuiva din Craiova. Pentru statie maine se declara castigatorul.
#469 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3622
Postat 05 September 2009 - 11:22 PM
Nici o problema. http://www.rhcforum....tyle_emoticons/default/rolleyes.gif
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#470 Useril este offline   dramida
  • Postari: 599
  Postat 08 September 2009 - 12:11 PM
caracteristici:
Control System :
Gyro sensor:
Operating voltage:
+4 to +6VDC
Function:
Dimensions:
Weight:
merg de o saptamana cu giroscopul in torpedo. doar o suna cineva sa vina sa-l ia, impachetat si cu manual...chiar nu-l vrea nimeni? Cineva il vinde cu 150 ron pe forumul asta, eu il dau moca
Aceasta postare a fost editata de dramida: 08 September 2009 - 12:12 PM
#471 Useril este offline   Zeus
  • Postari: 2455
Postat 08 September 2009 - 12:14 PM
Eu chiar am nevoie, dar pot intra in posesia lui doar prin fan curier, sau orice curier rapid
#472 Useril este offline   incepatoru
  • Postari: 2863
  • Interests:aero
Postat 08 September 2009 - 12:15 PM
Vezi postareadramida, la Sep 8 2009, 01:11 PM, a spus:
salut eu ma bagam da ai zii ca nu trimiti prin posta nu gasesc pe nimeni din bucuresti......
#473 Useril este offline   blackheart
  • Postari: 113
Postat 08 September 2009 - 12:56 PM
VGeorge a castigat statia. Astazi o trimit prin posta. sa o folosesti sanatos.
#474 Useril este offline   dramida
  • Postari: 599
Postat 08 September 2009 - 02:19 PM
Victor alias "scimitar" a primit giro-ul gy400 pentru ca a fost primul care m-a contactat (5 minute de la postarea anuntului) si l-a si luat de la mine in o ora.
Sa-l stapanesti sanatos si ai grija ca doar in modul rate merge corect, desi si acolo are mici drifturi.
Aceasta postare a fost editata de dramida: 08 September 2009 - 02:21 PM
#475 Useril este offline   Primus
  • Postari: 3026
  • Inregistrat: 14-June 07
Postat 17 September 2009 - 09:05 PM
As dori sa cedez statia mea pistol in 27MHz, (HPI TF1 cu receptor, nou noute) unui club de modelism. As prefera sa se bucure de ele cineva care nu isi perminte sa le aiba.
Care ma puteti ajuta cu o informatie?
Aceasta postare a fost editata de Primus: 17 September 2009 - 09:08 PM
#476 Useril este offline   cipri_tezaur
  • Postari: 875
  • Inregistrat: 06-May 09
Postat 17 September 2009 - 09:09 PM
Vezi postareaPrimus, la Sep 17 2009, 10:05 PM, a spus:
aici la mine in dej daca binevoiesti platesc eu transportul multumesc
#477 Useril este offline   Primus
  • Postari: 3026
Postat 17 September 2009 - 09:53 PM
... o precizare, statia va merge la un club de modelism, poate sa fie si dintr-un oras de provincie.
multumesc
p.s. multumesc celor ce mi-au dat MI, sistemul RC se va da in schimbul informatiilor cu privire la numele clubului locatie, etc..
E inca disponibil
Aceasta postare a fost editata de Primus: 17 September 2009 - 09:56 PM
#478 Useril este offline   vgeorge
  • Postari: 2700
Postat 17 September 2009 - 09:57 PM
Vezi postareablackheart, la Sep 8 2009, 01:56 PM, a spus:
Statia am reconditionat-o cat am putut.o sa incerc maine sa ii fac si un capac de baterie.
Daca o vrea cineva o trimit prin posta.
Sper ca nu te-ai suparat blackheart.
Racing
[center]Club
C.S.T.A. Bucuresti
#479 Useril este offline   steli2k
  • Postari: 1136
  • Inregistrat: 05-May 08
Postat 17 September 2009 - 10:00 PM
Vezi postareavgeorge, la Sep 17 2009, 10:57 PM, a spus:
Aceasta postare a fost editata de steli2k: 17 September 2009 - 10:10 PM
#480 Useril este offline   vgeorge
  • Postari: 2700
Postat 17 September 2009 - 10:07 PM
statia pleaca la Zeus, care din cate mi-a spus, poate sa ajunga din nou la "moca" in 2-3 saptamani,dar nu se stie sigur.
Stelika poate sa ajunga la tine.
Multumesc si inca odata sper ca nu te-ai suparat blackheart.
Racing
[center]Club
C.S.T.A. Bucuresti
  • 51 Pagini +
  • 14
  • 15
  • 16
  • 17
  • 18
22 useri citesc topicul
