Modelism - RHC Forum: Moskva Russian Navy Missile Cruiser - Modelism - RHC Forum
#1 Useril este offline   vasia
  • Postari: 1049
  • Inregistrat: 26-April 04
  • Interests:navomodelism
Postat 24 January 2008 - 06:22 PM
am primit un cadou de sarbatori asa ca sunt obligat sa ma apuc de treaba
Este vorba de Slava Class Moskva Russian Navy Missile Cruiser
modelul de la TRUMPETER
http://www.modelwarships.com/reviews/ships...ter-review.html
Asa ca m-am apucat constiincios de treaba
  • Imagine atasata: post-31-1201191767.jpg
#2 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:29 PM
scuze pentru calitatea pozelor dar sunt facute cu telefonul mobil si nu stiu sa-l folosesc
  • Imagine atasata: post-31-1201192191.jpg
#3 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:32 PM
si tot asa
  • Imagine atasata: post-31-1201192324.jpg
#4 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:34 PM
au umblat nepotii pe la telefon si s-au ingalbenit pozele....
  • Imagine atasata: post-31-1201192456.jpg
#5 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:35 PM
  • Imagine atasata: post-31-1201192546.jpg
#6 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:36 PM
  • Imagine atasata: post-31-1201192608.jpg
#7 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:38 PM
si ma chinuie chichitele de cativa milimetrii dar nu ma las
  • Imagine atasata: post-31-1201192719.jpg
#8 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:41 PM
#9 Useril este offline   vasia
  • Postari: 1049
si poza
  • Imagine atasata: post-31-1201192917.jpg
#10 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:43 PM
  • Imagine atasata: post-31-1201192989.jpg
#11 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:44 PM
  • Imagine atasata: post-31-1201193046.jpg
#12 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:45 PM
si tot decupand, lipind si debavurand am ajuns aici si la concluzia ca tre sa ma apuc sa mai si vopsesc daca vreu sa mai lipesc ceva
  • Imagine atasata: post-31-1201193134.jpg
#13 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:53 PM
ops,
daca trebuie sa vopsesc am o problema....
am aerograf dar nu am compresor asa ca daca nu vreau sa cumpar ma apuc de facut unul...
m-am inspirat din acest forum si m-am apucat de treaba nu fac un subiect nou am sa pun doar vro 2-3 poze cu ce am apucat sa fac
o butelie de freon de 14 litri un compresor de frigider mai mic, ceva fitinguri si teava de polipropilena si niste fitinguri pentru aer ...etc
  • Imagine atasata: post-31-1201193619.jpg
#14 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:54 PM
  • Imagine atasata: post-31-1201193668.jpg
#15 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:55 PM
#16 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:56 PM
mai uit cate o poza
  • Imagine atasata: post-31-1201193766.jpg
#17 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:57 PM
Cu un pic de vin fiert o cafea tutun si nitica rabdare incepe sa se vada ceva
  • Imagine atasata: post-31-1201193827.jpg
#18 Useril este offline   vasia
  • Postari: 1049
Postat 24 January 2008 - 06:59 PM
compresorul pornit in 12 minute ajunge la 5 atmosfere mai trebuie sa cumpar un presostat si un regulator de presiune cu ceva filtre pentru iesire, si dupa poza asta plec spre bucuresti am sa continui peste 3-4 zile
SPOR
  • Imagine atasata: post-31-1201193975.jpg
#19 Useril este offline   Paul_L
  • Postari: 295
Postat 10 February 2008 - 08:51 AM
Foarte frumos lucrat sasiul pentru compresor. Vezi ca va trebui sa pui o valva de purjare a apei acumulate in rezervorul de aer.
#20 Useril este offline   vasia
  • Postari: 1049
Postat 10 February 2008 - 09:43 AM
multam,
am cam terminat cu compresorul am sa pun o poza diseara cu el si cu primele parti ale navei vopsite
spor
#21 Useril este offline   vasia
  • Postari: 1049
Postat 10 February 2008 - 06:04 PM
o poza
  • Imagine atasata: post-31-1202659496.jpg
#22 Useril este offline   vasia
  • Postari: 1049
Postat 10 February 2008 - 06:05 PM
vopsit
  • Imagine atasata: post-31-1202659551.jpg
#23 Useril este offline   vasia
  • Postari: 1049
Postat 10 February 2008 - 06:21 PM
si coca vopsita
  • Imagine atasata: post-31-1202660491.jpg
#24 Useril este offline   vasia
  • Postari: 1049
Postat 10 February 2008 - 06:59 PM
vreau sa vopsesc suprastructura dar nu vreau sa vopsesc geamurile am inceput sa le acopar cu scoci de hartie, as incerca sa pun vaselina in loc de scoci si dupa ce vopsesc sa sterg efectiv cu carpa cum sa pocedez?
  • Imagine atasata: post-31-1202662764.jpg
#25 Useril este offline   Zue
  • Postari: 1495
  • Inregistrat: 05-January 07
Postat 10 February 2008 - 07:18 PM
eu as proceda tot cu schotch, cu vaselina nu prea ai precizie si daca gresesti este posibil nici sa sesizezi, pe linga fapsul ca atunci cind vopsesti cu aer comprimat este posibil sa sara stropi de vaselina si pe suprafetele pe care le dorsti vopsite
frumoasa lucrare
bafta
tel.0745026562
#26 Useril este offline   vasia
  • Postari: 1049
Postat 10 February 2008 - 07:44 PM
multam,
si io cred ca tot cu scoci am sa continui
si daca nu ajung la spitalul de nebuni dupa 60 de geamuri de 3mm/2mm o sa pun si niste poze
Aceasta postare a fost editata de vasia: 10 February 2008 - 07:47 PM
#27 Useril este offline   Zue
  • Postari: 1495
Postat 10 February 2008 - 08:50 PM
alege o suprafata de exemplu lucioasa fara apa si grasime pe care sa poti sa tai
desfa o bucata de schotch de 10 cm, lipeste-o pe acea suprafata, deseneaza schotch-ul la dimensiunile de 3mm cu 2mm apoi tai cu un bisturiu sau un cutter modelul desemat
cu virful cutterului pozitionezi bucatelele de schotch pe geamuri, te asiguri ca sunt lipite bine
spor la lucru
tel.0745026562
#28 Useril este offline   vasia
  • Postari: 1049
Postat 10 February 2008 - 11:48 PM
multam,
am folosit o bucata de sticla am masurat am taiat banda adeziva la dimensiuni am lipit la locul lor bucatelele cu varful cutter-ului am vopsit si am ajuns in stadiul asta:
  • Imagine atasata: post-31-1202680100.jpg
#29 Useril este offline   vasia
  • Postari: 1049
Postat 10 February 2008 - 11:49 PM
si tot asa....
  • Imagine atasata: post-31-1202680165.jpg
#30 Useril este offline   vasia
  • Postari: 1049
Postat 10 February 2008 - 11:50 PM
  • Imagine atasata: post-31-1202680245.jpg
13 useri citesc topicul
