elicopter un sfat
Postat 03 December 2007 - 08:19 PM
http://www3.towerhobbies.com/cgi-bin/wti00...&I=LXRXF4**&P=7
http://www3.towerhobbies.com/cgi-bin/wti00...&I=LXLDP9**&P=7
daca aveti placerea sa-mi dati un sfat il astept aici. mersi frumos :D
Postat 04 December 2007 - 06:50 AM
La pretul unei statii Futaba $119, iti cumperi tot sistemul fara tranport.
20-1/4" main rotor diameter, 21" fuselage length, 9 oz. flying weight.
Honey Bee Mark 3 includes a 2-cell 800 mAh LiPoly battery pack and a dedicated LiPoly battery field charger.
Ready to fly within minutes of opening the box. Charge the flight pack and you are ready.
If you are a beginner, leaving the flybar weights at the outer position will dampen the controls and make the helicopter easier to fly.
As you improve, move the weights in for quicker response. The swashplate has a metal ball for reduced wear and precise control.
The servos are screwed to the frame for solid response.
Main rotor has a fiberglass plate reducing blade coning, which improves the helicopters forward flight.
Main and tail rotors are fixed pitch and are controlled by individual motors.
The mixing board controls mixing of the main and tail rotors.
The board also contains 2 speed controls, a peizo gyro for tail stabilizing and a battery-eliminator-circuit, which supplies power to the receiver and servos.
Postat 04 December 2007 - 01:36 PM
florica_ionutz e id-ul de mess
Aceasta postare a fost editata de RedBaron: 04 December 2007 - 02:07 PM
Postat 04 December 2007 - 02:34 PM
Barabula, la 4 Dec 2007, 10:19, a spus:
Ai perfecta dreptate. Cred ca-s bani aruncati. Dupa primul incident....si asta se va intampla repede....nu mai poti folosi nimic. Chiar daca are piese de schimb nu stiu daca merita sa-l repari....zic si eu.
Macar cu una din statiile pomenite ramane si le poate folosi si pe alte modele.
Aceasta postare a fost editata de Se poate si asa ?: 04 December 2007 - 02:34 PM
Postat 04 December 2007 - 03:46 PM
$129.00
- 2007 LATEST Version
- 100% Ready To Fly (No Assembly Required)
- Tail Rotor Drived By Belt & Controlled by Separated Servo
- Improved Body Frame, Very Strong & Light
- Easy to maintain and repair
- Separated Electronic Speed Control & Gyro
- Newest Transmitter: 6 CH with Gyro. Switch, Hov. Pit, Pit. Trim and Simulator Cable Socket
- 3D aerobatic action and inverted flight
- Spare Parts Available At Our Shop
- We recommend the HBK2 for the Intermediate Pilot To Stunt Flyer
About the Honey Bee King 2
For the Price vs Performance, the Honey Bee King 2 definitly wins 9 blocks than others, we got feed back from all around the world, they all amazed ESky made such a great helicopter. Few year ago, you couldn't find a helicopter this small with so fine electronics packed in it, now it's here, we proudly present to you, the Honey Bee King 2.This model is suitable for r/c helicopter intermediate pilot, 3D aerobatic action and inverted flight is possible! Stunt flyer! This is a Ready To Fly Kit, just charge the battery and fly out of box.
Atasat este un videoclip in care s-a schimbat statia de emisie si receptorul de la cea venita in pachet cu DX7. Deci modelul este destul de performant ca pilotul sa il modifice si sa ii schimbe Rx-ul cu unul computerizat pe 2.4Ghz.
http://www.youtube.com/watch?v=TyZbz42xg0w...opter-p-53.html
In cel de-al doilea videoclip este un model pilotat de un incepator.
http://www.youtube.com/watch?v=tytpNSOWdWU...opter-p-53.html
Mai multe detalii gasiti pe saitul http://www.rchelicop...op.com/catalog/
Daca cineva este interesat in acest elicopter sau altceva de pe acest site, contactatil pe domnul Camus Wong, head of sale department, la
info@rchelicoptershup.com. Mentionati in email numele meu, Igor si veti obtine un discount de 5% si set de pale plus training gear.
Chiar zilele trecute am vrut sa cumpar doua Honey Bee King 2 dar am gasit acelasi pret de $129 pe plan local si am scutit transportul, dar in trecut am folosit serviciile oferite de ei si recomand cu toata increderea.
Mult succes in continuare.
Aceasta postare a fost editata de Watt_the?: 04 December 2007 - 05:41 PM
Postat 04 December 2007 - 04:23 PM
Se cerea un sfat pentru un incepator si ca un incepator in elicoptere care sint si eu, am recomandat ce am folosit si nu ce am auzit. As fi putut cumpara unul de $300, $500 sau $2000 fara nici o problema, dar nu vad de ce as arunca la gunoi acesti bani atunci cind as avea o eroare de pilotaj.
Acelasi elicopter este si la pretul de $359... a, este din CF dar este mai bun decit cel de $129 deoarece... Sau daca il vei cumpara din Romania o sa fie mai ieftin?
Si pina la urma tot nu am inteles care este recomandarea ta... cumpara modelul "X" sau "Y"... deoarece eu sau prietenul meu, are unul si sint/este multumit de el... sau ce anume?
Aceasta postare a fost editata de Watt_the?: 04 December 2007 - 04:57 PM
Postat 04 December 2007 - 06:00 PM
Asadar cu cat heliul este mai mic cu atat este mai putin indicat pentru un incepator. Poate vi se pare aiurea si veti spune ca unul mare costa bani...dar este mai usor de tinut in aer si zboara mai ca la carte.
Postat 04 December 2007 - 11:41 PM
va multumesc mult pt. sfaturile date si imi cer scuze daca unii dintre voi s-au enervat. nu am vrut sa se intample asta. radio comanda vreau sa o folosesc si la navo. construiesc o barcuta pt. nadit.
un lucru am inteles clar : radio comanda futaba (de mai sus) nu se poate compara cu nici una din kiturile rtf prezentate. (daca gresesc va rog sa imi spuneti ). bafta :)
Postat 05 December 2007 - 12:21 AM
adresa mea e : popescuioan77@yahoo.com poate imi dai un nr de tel bafta :D
Postat 05 December 2007 - 01:38 AM
nelu bv, la 5 Dec 2007, 01:21, a spus:
Daca naste nu vei mai pleca un an. Dar fii linistit. Asa si trebuie.
Felicitari si sa fiti fericiti.
Postat 05 December 2007 - 04:34 AM
Si in al treilea rind, vrei sa faci pariu ca pina iti iei statia Futaba o sa iei "statia" Pampers... :)
Postat 05 December 2007 - 10:30 PM
1. sper sa ajung ca daca naste maine trebuie sa ma stea in maternitate cateva zile
2.statia futaba o sa o iau peste cateva zile dar "statia" pampers e deja luata
mersi inca o data
#20
Postat 06 December 2007 - 02:17 AM
Sper ca nu-i molipsitor......
#22
Postat 06 December 2007 - 06:05 PM
Primus, la 6 Dec 2007, 00:45, a spus:
..te urmez in cateva luni!
bafta multa si nastere usoara doamnei. al meu flacau inca nu a iesitpana acum (18.00) , dar daca pana maine nu vrea o sa il scoata doctorul. bafta http://www.rhcforum....tyle_emoticons/default/cool.gif
#23
Postat 06 December 2007 - 06:07 PM
protheus, la 6 Dec 2007, 16:24, a spus:
Stima si respect
salut protheus. cred ca mai corect era piloti IN pampers. bafta http://www.rhcforum....tyle_emoticons/default/cool.gif
#25
Postat 10 December 2007 - 07:11 PM
Ceea ce am spus in legatura cu mentionarea numelui meu este total adevarata. Trimiti un email si mentionezi numele meu, ca ti-am recomandat site-ul respectiv si ca ai vrea sa cumperi un HKB II dar sa iti dea cadou palele si trenul la fel cum i-a oferit si lui IGOR ( adica mie ), si in acelasi timp il poti intreba si de costul transportului.
Totul se rezuma la bani, trebuie sa sti cum sa scrii emailul si sa astepti cam doua saptamini pentru transport, dar repet, nu stiu ce taxe o sa ai de plata in vama.
In acelasi timp felicitari viitorilor tatici. http://www.rhcforum....tyle_emoticons/default/biggrin.gif
#26
Postat 13 December 2007 - 10:55 PM
Watt_the?, la 5 Dec 2007, 04:34, a spus:
salut baieti.
cat adevar au grait uni dintre voi. statia am reusit sa o comand dar elicopterul mai are de asteptat.
in schimb am acasa ceva mai de pret: un baietel de 3.4 kg. va multumesc ptr sfaturile de mai sus. bafta
#27
Postat 13 December 2007 - 10:57 PM
Watt_the?, la 10 Dec 2007, 19:11, a spus:
mersi si ptr eventualul ajutor dar nu il mai iau deocamdata
