Modelism - RHC Forum: Easy Star first person viewing(F.P.V.) - Modelism - RHC Forum
#1 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 29 November 2007 - 08:46 PM
Am achizitionat de la o firma din state(Hobywireless) un sistem video wireles ;
Transmitter 2.4Ghz 500mW (LM500) with built-in microphone
-High Sensitivity Receiver R8000 -Works with any camera PAL or NTSC
-Audio and video output cable with RCA connectors
-A set of two 3dBi antennas -5 volts switching voltage regulator 1 Amp.
-Cased SN-480 12 volts color camera ccd sony 480 lines
Receiver Specs:
- Operating voltage from 10.5 to 13 volts DC
- 240mA power consumption
- 2.4 GHz frequency band, 8 user selectable channels ,
O pereche de ochelari video (China)
*Display Size: 80" virtual screen
*Resolution: 640 * 480 (VGA)
*Color depth:24-bit input
*Viewing Angle:35° diagonal
*Audio: Dual-channel stereo
*3D Feature: Field Sequential 3D stereoscopic VGA signal
*Video input format: VGA (60Hz), Composite AV(NTSC/PAL/SECAM) input, S-Video (optional)
Astazi le-am montat pe easy star si le-am zburat, deocamdata cu ajutor deoarece la un moment dat devi dezorientat si nu prea sti unde te afli .Decolarea si aterizarea ,fara ochelari Captura este destul de slaba pt ca am facut-o pe un laptop cu un tuner tv extern
Aceasta postare a fost editata de Laur73: 31 March 2008 - 06:52 PM
Fotografie Aeriana
#2 Useril este offline   alexroad
  • Postari: 621
  • Inregistrat: 29-June 07
  Postat 29 November 2007 - 09:04 PM
E tare dar nu ne-ai spus pretul. :huh:
Hodina-i ca slanina
Sa te maturizezi e optional!
#3 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 29 November 2007 - 09:11 PM
A doua parte
Aceasta postare a fost editata de Laur73: 31 March 2008 - 06:53 PM
Fotografie Aeriana
#4 Useril este offline   Paul_L
  • Postari: 295
Postat 29 November 2007 - 09:13 PM
Camera ai montat-o fixa pe Easystar ? Cum ai avut ajutorul la pilotaj ? Trainer pe radiocomanda ?
#5 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 29 November 2007 - 09:14 PM
alexroad, la 29 Nov 2007, 21:04, a spus:
Camera,emitatorul si receptorul+ transport - $439.88
Ochelari video -1200Ron
Fotografie Aeriana
#6 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 29 November 2007 - 09:19 PM
Paul_L, la 29 Nov 2007, 21:13, a spus:
Da deocamdata este fixa camera,iar ca ajutor am avut-o pe nevastamea care striga la mine din curte cind avionul se indeparta prea tare ,ar fi fost bine daca avem pe cineva cu trainer pe radiocomanda.
Fotografie Aeriana
#7 Useril este offline   Paul_L
  • Postari: 295
Postat 29 November 2007 - 09:31 PM
Felicitari. Cred ca esti primul care a prezentat treaba asta pe forumul acesta. Cred ca e destul de ciudat sa vezi toate miscarile dar sa nu le simti. Poate si de aici senzatia de care ziceai ca te cam pierzi.
#8 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 29 November 2007 - 09:49 PM
te lasa genunchi dupa trei minute
Fotografie Aeriana
#9 Useril este offline   Paul_L
  • Postari: 295
Postat 29 November 2007 - 09:55 PM
Poate e mai bine sa pilotezi asezat pe un scaun.
#10 Useril este offline   fulgerica
  • Postari: 2235
  • Inregistrat: 31-July 07
  • Interests:vintage
Postat 29 November 2007 - 10:05 PM
mi-a placut. bravo Laur! politeaza si tu mai agresiv, sa-tzi creasca si mai mult adrenalina!
Laser frate!
#11 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 29 November 2007 - 10:21 PM
fulgerica, la 29 Nov 2007, 22:05, a spus:
Multumesc,dar este primul zbor,a fost mai mult de control,dar si asa cred ca aveam pulsul la120 .Mai i-mi trebuie un dspozitiv de inregistrare portabil ,o camera video cu av in sau ceva asemanator.Captura prin tuner tv are calitatea f slaba.
Fotografie Aeriana
#12 Useril este offline   TOMY
  • ex Nimsoc
  • Postari: 924
  • Inregistrat: 17-May 07
Postat 30 November 2007 - 12:41 AM
Felicitari!. In sfarsit o chestie mai demna de luat in seama .
#13 Useril este offline   alexroad
  • Postari: 621
  Postat 30 November 2007 - 12:30 PM
Esti tare dom'le.Mi-a placut si aterizarea da' adevaru-i ca si pretul e tare ca ajunge pe undeva pe la 1000 $.Pentru un modelist adevarat insa nu-i mult si oricum e o pasiune mult mai nonagresiva decit altele. :D
Hodina-i ca slanina
#14 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 30 November 2007 - 07:13 PM
alexroad, la 30 Nov 2007, 12:30, a spus:
Esti tare dom'le.Mi-a placut si aterizarea da' adevaru-i ca si pretul e tare ca ajunge pe undeva pe la 1000 $.Pentru un modelist adevarat insa nu-i mult si oricum e o pasiune mult mai nonagresiva decit altele. :rolleyes:
investitia de fapt este de 440 $ ,ochelari se pot folosi la foarte multe alte lucruri, si de fapt sistemul costa 330$, eu am mai luat si o lentila separat pt camera si niste cabluiri si o antena mai mare si am ajuns la 440$
http://www.hobbywireless.com/web/store/com...sp?idProduct=64
Fotografie Aeriana
#15 Useril este offline   Paul_L
  • Postari: 295
Postat 30 November 2007 - 08:14 PM
Ochelarii I-ai luat din tara? Sunt foarte interesat sa-ti calc pe urme dar mai intii trebuie sa termin EZ* si sa invat sa-l pilotez clasic. Eu am telecomanda in 2.4 GHz si-m trebuie emitator ori in 400 MHz ori in 900 MHz
#16 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 30 November 2007 - 08:41 PM
Paul_L, la 30 Nov 2007, 20:14, a spus:
din china (www.prober.cn)
Fotografie Aeriana
#17 Useril este offline   cucubauu
  • Postari: 63
  • Inregistrat: 10-October 07
Postat 01 December 2007 - 12:13 PM
super tare :lol: ...... totusi imi permit un mic sfat..... avand in vedere propagarea microundelor mi se pare o idee proasta o polarizare verticala atata timp cat tu esti cu mult sub antena -_-
cucu?
#18 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 01 December 2007 - 12:49 PM
cucubauu, la 1 Dec 2007, 12:13, a spus:
Adica ce trebuie sa fac ? si eu am observat ca apar interferente
Aceasta postare a fost editata de Laur73: 01 December 2007 - 11:27 PM
Fotografie Aeriana
#19 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 01 December 2007 - 12:57 PM
Un film facut astazi
Fotografie Aeriana
#20 Useril este offline   Paul_L
  • Postari: 295
Postat 01 December 2007 - 01:51 PM
Laur73, la 1 Dec 2007, 12:49, a spus:
Adica ce trebie sa fac ? si eu am observat ca apar interferente
Pui antena emitatorului TV inclinata. Chiar orizontala.
#21 Useril este offline   mihaimcg
  • Postari: 622
  • Inregistrat: 22-January 06
Postat 05 December 2007 - 05:45 PM
Ar fi interesant sa ne spui si cat cantareste tot ansamblul pentru ca in mod sigur este influentat si centrul de greutate al avionului.
#22 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2183
  • Inregistrat: 28-November 06
Postat 05 December 2007 - 07:48 PM
mihaimcg, la 5 Dec 2007, 17:45, a spus:
asha si e. dar ez e facut in asa fel incat saracu tot zboara. mai frumos sau mai urat ce-i drept. dar zboara. super avion
#23 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 05 December 2007 - 09:11 PM
890g cu acu lipo 1800 3cel , mai dificil este la decolare pt ca am nevoie de spatiu pt a-l ridica,la fel la aterizare.In aer se comporta la fel de bine ca si unul mai usor ,centrul de greutate a ramas tot acolo prin adaugarea unei bucati de plumb de 20 de g
Fotografie Aeriana
#24 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2183
Postat 05 December 2007 - 09:31 PM
Laur73, la 5 Dec 2007, 21:11, a spus:
pune un motor brushless. te mai du0ce la 1 mil in plus motoru si regulatoru. o sa fie un pic mai usor. motorul400 are vreo 80-90g si un brushless vreo 40-50g. se merita zic eu. o sa il ridici mult mai repede. la aterizare.... nu stiu cata experientza ai. dar din film am vazut ca faci picaju de la inaltime extrem de mare. e normal sa se duca mult deoarece are viteza. invatza sa zbori cu el la inaltimi mai mici. sa vezi apoi ca iti ajung vreo 20m sa il pui jos. poate chiar mai putzin. depinde de vant http://www.rhcforum....tyle_emoticons/default/smile.gif. bafta!
#25 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 06 December 2007 - 12:18 PM
hash84, la 5 Dec 2007, 21:31, a spus:
pune un motor brushless. te mai du0ce la 1 mil in plus motoru si regulatoru. o sa fie un pic mai usor. motorul400 are vreo 80-90g si un brushless vreo 40-50g. se merita zic eu. o sa il ridici mult mai repede. la aterizare.... nu stiu cata experientza ai. dar din film am vazut ca faci picaju de la inaltime extrem de mare. e normal sa se duca mult deoarece are viteza. invatza sa zbori cu el la inaltimi mai mici. sa vezi apoi ca iti ajung vreo 20m sa il pui jos. poate chiar mai putzin. depinde de vant :). bafta!
spatiu de aterizare este de100m ,iar in spate sunt case,de aceia vin in picaj, si inaltimea nu este mare ,asa se vede pe film . ma gindeam sa-i pun si eu un motor brushless dar inca nu stiu ce motor ar fi bun
Aceasta postare a fost editata de Laur73: 06 December 2007 - 12:19 PM
Fotografie Aeriana
#26 Useril este offline   modelnicson
  • Postari: 101
  • Inregistrat: 20-December 06
Postat 06 December 2007 - 10:31 PM
Felicitari pentru proiect.
Lucrez si eu la ceva asemanator dar am preferat sa folosesc module si componente electronice achizitionate prin magazine non-modelism din considerente de performanta si de pret. Initial, scopul a fost cel enuntat in subiectul urmator http://www.rhc.ro/forumrhc2/index.php?act=...hl=combat&st=40
Acum ma gandesc si la OSD cu informatii de stare, inclusiv GPS.
La puterea de 500 mW, poti aprecia la ce distanta receptia video (fara obstacole) ramane multumitoare?
Succes in continuare.
Aceasta postare a fost editata de modelnicson: 06 December 2007 - 10:33 PM
Sonic Low Wing
Multiplex AcroMaster
Multiplex EasyCub
Graupner MC-19 40 Mhz/2,4 Ghz (JETI)
#27 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 07 December 2007 - 12:00 AM
modelnicson, la 6 Dec 2007, 22:31, a spus:
producatorul spune ca o mila cu antena standard ,dar eu nu l-am dus mai mult de 5-600 de m ,
Fotografie Aeriana
#28 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2183
Postat 07 December 2007 - 01:12 AM
Laur73, la 6 Dec 2007, 12:18, a spus:
e mult 100 m:). o sa iti formezi manutza si o sa vezi cum e apoi :D. ca motor ti-as recomanda un bm2408-21 cu o elice 8x5 pe care o sa o tai ca sa nu loveasca corpul avionului. o sa ai o forta de tractiune cam de 500g la un consum de vreo 12A cred
#29 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 07 December 2007 - 04:27 PM
hash84, la 7 Dec 2007, 01:12, a spus:
Eu ma gindisem la un motor axi 2208/26 cu o elice de6x4 dar este destul de scump
Fotografie Aeriana
#30 Useril este offline   florin100%
  • Postari: 2685
  • Inregistrat: 20-June 06
Postat 07 December 2007 - 06:42 PM
nu are rost sa pui axi pe EZ! un tower pro e foarte bun.
Team Aeropower
13 useri citesc topicul
